RED RAY 2K, 3K & 4K disk drive announced by RED for 1Q09 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 73 Old 04-23-2009, 01:46 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
I read through the linked thread but didn't see anything to get excited about. It is very easy to arrive at a low average data rate. Just have 15 minutes of easy stuff and one minute of hard . So until someone tries to make real as opposed to demo tests, there is not much to be excited about.
Advancements in compression efficiencies come at 5 to 10% level/year, not 5 to 10X .
amirm is offline
post #62 of 73 Old 04-23-2009, 02:52 PM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
Remember that the (original) purpose of RED Ray is to have a playback facility to show a full lenght motion picture in 4K from a burnt DVD-R, then you will find the max bitrate right there.
RED Ray (a playback machine) will be out later this year (they claim) and will cost under $1000.
Then we will see what they got.
coolscan is offline
post #63 of 73 Old 04-23-2009, 03:04 PM
mhafner's Avatar
Quoted: 147 Post(s)
Liked: 55
I don't think the footage was doctored that way. If you think about it they 'only' did what AVC and VC-1 do all the time, taking material considered master quality (Digibeta, HDCAM SR...) and apply a compression factor somewhere between 10 and 80 or so and get a result that is +- visually lossless, although there are peeks required well above some average to keep the level of artifacts constant or at least not exceeding some threshold.
The only difference is that they start with a 4K 'lossless' master which is already very much compressed in itself (but still considered visually lossless at >= 24 fps). Whether they simply apply some variation of know techniques and treat their 4K frames like an AVC encoder treats its input or if they developed new methods to track wavelet coefficients directly from frame to frame and encode the differences efficiently we don't know yet. But it's no magic. I suspect there are either peeks required which are >> 10 Mbit/s for some types of footage or it's no longer visually lossless all the time, certainly not when watching a split screen with the original and definitely not with a full 4K res original (which Redcode from Red One is not).
But if they managed to squeeze it into Blu Ray parameters with all peeks then we can celebrate. 4K at home in Blu Ray quality, who would not want that?
mhafner is offline
post #64 of 73 Old 04-23-2009, 05:52 PM
amirm's Avatar
Liked: 739
Here is what we know from real experience. With clean sources, and three pass encoding for HD DVD/BD (i.e. a human involved), we can for 1080p content get down to 9 to 10 mbit/sec. But that is for consumer delivery at 4:2:0. Up that to 4K and 4:2:2/4:4:4, and auto-encoding, the math just doesn't work. Yes, if you have uniform parts of the image, you don't need twice as much. But there is no guarantee of that.
As to wavelets, again, I have not seen it applied with interframe compression. Intra works but of course, when pusehd softens the image. There has been research into interframe compression using wavelets but computationally, it is orders of magnitude more difficult than AVC/VC-1. And the gains are actually not that good.
So while I leave the door ever so slightly open that they have something new, there is no way to achieve those rates for studio work and for professional eyes.
The "2-hour" thing is likely a marketing claim. I suspect they will use a very high-speed red laser drive, and likely get 20 to 30 minutes. Why I would bother to use optical when I can use Flash, is beyond me. For this application, it makes no sense to me. Maybe they didn't predict Flash prices to drop so low when they started the project...
amirm is offline
post #65 of 73 Old 04-23-2009, 07:38 PM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Amir I think this codec is directly aimed for cmos footage. So its not 4:4:4 but more like 4:0:0 since you dont have to encode any colordata.
Of course 4K sound still heavy at 10mbs.
MovieSwede is offline
post #66 of 73 Old 04-23-2009, 10:04 PM
amirm's Avatar
Liked: 739
Good correction on terminology . But do they not use a Bayer filter? If so,then they do wind up with GRGB data to compress.
amirm is offline
post #67 of 73 Old 04-24-2009, 01:54 AM
mhafner's Avatar
Quoted: 147 Post(s)
Liked: 55
Bayer 4K sensor so they compress with wavelets a ~3.2K real resolution Bayer pattern that can be debayered to an RGB image afterwards (post wavelet decompression). Or further compressed intra- and interframe for a delivery version with real time decompression and debayering. Looks like they had some breakthrough doing this. 4K with the smaller pixels helps compression artifacts staying below the visibility threshold at real time.
mhafner is offline
post #68 of 73 Old 04-24-2009, 09:00 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Amir, I got this wild idea.
What about using a codec like this as a core, and then add an extension that is based on something VC1, that acts as a filling in the blanks. On the areas were the redcode deviate to much from the orginal source.
It could be the best of both worlds.
post #69 of 73 Old 04-24-2009, 10:26 AM
scaesare's Avatar
1) This was not an "unchallanging" demo reel.
2) The camera is indeed bayer, but the individual R,G, & B channels are wavelet compressed individually in the camera to REDCode, at about 35MBs.
3) The REDRay codec is not REDCode, but a distribution codec that delivers RGB.
4) These guys are picky. I suspect they will not be foisting substandard distribution of their images upon folks. Ask Stacy... he owns one of their cameras.
-Steve
scaesare is offline
post #70 of 73 Old 04-25-2009, 04:48 AM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
For those that want to see an example of what type of content that was demoed in Las Vegas, here is a download link to "Shot on RED" in VLC h264 720.mov.
I believe this is this year’s reel, the Reel 400, not last year's reel the Reel 300 that was compressed to 10Mb/s.
Looks very good compressed down to 720 for web delivery.
http://www.reduser.net/forum/showpos...5&postcount=21
coolscan is offline
post #71 of 73 Old 04-25-2009, 10:45 AM
mhafner's Avatar
Quoted: 147 Post(s)
Liked: 55
Damn, I just wanted to post this link. Now imagine watching this in 4K...
mhafner is offline
post #72 of 73 Old 11-30-2009, 05:56 PM
LexInVA's Avatar
Quoted: 539 Post(s)
Liked: 220
Today, RED Fire Chief Jarred Land via the official RED online forum gave some preliminary specs for the RED Ray Professional playback system (for use in production environments) and also stated that the Consumer playback system would follow sometime thereafter. Here is the information he posted:
RED RAY PRO
* Decode .R3D RAW files to 5K 30 fps
* Decode .RRD (RED RAY Distribution format) 4:4:4 files up to 4K @ 30 fps
* Up to 12 channels of compressed or uncompressed 24-bit audio
* Optional media and local link encryption
* Gigabit and Wireless 802.11b/g/n Ethernet
* Local Touch LCD UI and dedicated transport controls
* 4 x DVI-D Program Outputs (four 1080p / 2K image quadrants, A B C D)
* 4 x HD-SDI 3G Program Outputs (four 1080p / 2K image quadrants, A B C D)
* 1 x HDMI Preview Output with Audio
* 2 x DB-25 Digital Audio Outputs
* Rack mount
* Redundant power supply possible
* 4 x USB-2 ports
* e-SATA port
* GPIO and automation support
* FireWire 800 port
* 2 x Customizable front storage slots
* Compact Flash support
He gave the following information about the current launch times for their new formats:
RED Ray Pro- January- February 2010
RED Ray Consumer- Spring- Summer 2010
... unless we have major issues we don't anticipate.
These are expected to street around the same time as RED's new camera systems coming next year which offer higher resolution and the usual improvements over their current offering, the RED One system.
LexInVA is online now
post #73 of 73 Old 12-01-2009, 01:51 PM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
RED RAY PRO™ render
coolscan is offline
Reply HDTV Software Media Discussion
