ATI Pixel Format - AVS Forum | Home Theater Discussions And Reviews
Old 11-12-2008, 11:57 PM - Thread Starter
wiak's Avatar
what to chose?
i got a Sony KDL-40W2000 and a AMD 780G Chipset
and i can see a option in ATI Control Center, so what is it?
wiak is offline
Old 11-13-2008, 03:05 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Think it like this.
A BD movie is basicly 8bit 4:2:0, but your display is capable of showing greater then this. So the signal gets converted when it starts displaying. So what makes the best conversion your player or your display?
Its not so much different from upconversion of DVD. What makes the best upconversion, the player or the display?
Since I dont know much about your display, I can only recommend testing yourself and see if you can see any difference.
EDIT
Test YCbCr 4:4:4 Then the computer handles the chroma upsampling. In 4:2:0 there is just one chromasample per 4 luma samples. So basicly the computer recreate one chroma sample per luma sample.
MovieSwede is offline
Old 11-13-2008, 05:16 AM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
This is a simple option with very complex set of issues behind it. The video on blu-ray and other digital video is in YUV (YCbCr) domain. Computer screen/graphics however, is in RGB. One can convert from one domain to the other (as set up in this menu) but you lose something in translation.
Now, if you were just going to play movies on your PC, you would want the least number of translations. So best would be to select the YUV choices. Unfortunately, they do not give the option of what is on disc: 4:2:0 so you are stuck with interpolation to 4:4: 4 on the graphics card and hope that it is done right.
Alas the situation is more complicated. You need to know what pipeline the video player is using. If it is creating a YUV overlay plane for the video (because that is what is on disc), then the above works. But the player may operate in RGB domain when it mixes say, menus over video. In that case, you would want to output in RGB, and not format convert back to YUV.
Now, your display may take that YUV and convert it to RGB. So maybe you want to let the graphics card do it. Or maybe not .
Of course, if you deal with pictures and other graphics work on your PC, you want to run in RGB mode, not YUV. And for sure RGB 4:4:4 as 4:2:2 would reduce the color resolution so for example, red text on blue background would have softer edges.
Then there is the issue of "set-up." PC video has 8-bit samples which go from 0-255. Video however, can have "setup" so that it goes from 16-255 (what ATI is calling Limited RGB). If you try to expand this to 0-255 and don't dither, you get banding. So for video, you may want this with 16-255 but for graphics/PC use you want 0-255.
Quite a mess. No? It is very difficult to get a proper pipeline to work and work for all applications. So if you want one answer, I say use the one you have highligted.
If you want the right answer for video, put in a test disc and see which mode produces the best ramps, etc.
amirm is offline
Old 11-13-2008, 04:05 PM
leeperry's Avatar
so is this good or bad ? I can't tell
HDMI 1.0(possibly <1.3 as well?) is RGB24 TMDS.
my HC3100 manual says "HDMI(single link)"...so that means that it works internally in RGB24 0-255?
and this new CCC option basically gives a choice between YV12/YUY2/RGB24/RGB32 ?
my pj onboard IC simply sucks, so if I could get my PC to do an even bigger part of the work, that'd be most appreciated.
too bad I got an HDMI/DVI cable so CCC won't let choose these options(only available if using an HDMI/HDMI cable apparently? )
leeperry is offline
Old 11-13-2008, 07:06 PM
amirm's Avatar
Liked: 739
Sad thing is that with all I know, I can't tell either .
No, the two are seperate things. You need dual link to go to higher resolutions. Single/dual link doesn't change the color space.
Well, not those modes exactly but yes, it is essentially giving you the choice of two types of RGB and YUV.
It certainly is worth a try. The things I talked about, if set wrong, may not impact the picture as much as a poor scalar in the display.
amirm is offline
Old 11-14-2008, 03:40 AM
leeperry's Avatar
so the first option is YUY2, the second one is YV12....but what are "standard RGB" & "studio RGB" ? 16-235/0-255 ?
leeperry is offline
Old 11-14-2008, 04:45 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Wikipedia is great for this.
http://en.wikipedia.org/wiki/RGB_col...representation
Old 11-14-2008, 06:12 AM
FoxyMulder's Avatar
Wouldn't it be better to choose limited RGB if watching Blu Ray movies on your PC as choosing full RGB will result in black levels being off and details being clipped.
I know on my Playstation 3 that limited RGB is for movies and full RGB is intended for games although i choose not to use RGB...Is this not the same for your PC ?
FoxyMulder is offline
Old 11-14-2008, 09:29 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
If you use limited RGB, the player cut out information, it should better your display does it when you calibrate the display.
Old 11-14-2008, 09:37 AM
FoxyMulder's Avatar
Yes you cut out information but for movies you need to do this as the display will not be correct otherwise....Full RGB is for games and possibly graphic design programs but you don't use full RGB for movie watching ....There was a full explanation in the Playstation 3 thread about this and how black levels are incorrect if using full RGB for movie watching...Is it different for computers because i thought a Playstation was basically a computer.
My display is calibrated.
Old 11-15-2008, 04:40 AM
Seeco's Avatar
For ATI users there has been a lot of talk about color spaces, the HDMI dongle and a series of regtweaks. PhaedrusGalt's post here pretty much sums it up:
http://www.avsforum.com/avs-vb/showt...5#post14370685
So the solution for ATI users to get a consistent color space for everything has been to apply this regtweak, which expands everything to PC levels. The HDMI dongle then compresses (observe, not "cuts off") the signal to video levels, which can be correctly displayed on a TV set to video levels.
What I wonder now is what this Pixel Format-setting in CCC does in this equation. Does the compression in the HDMI dongle still happen independently of this, or does the Pixel Format-setting actually control what the dongle does? If I still want to let the dongle perform the compression, I guess I should set pixel format to full range, that is 4:4:4, correct? But which one of the two, RGB or YCbCr? This is very confusing...
Seeco is offline
Old 11-15-2008, 06:40 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
If your source is only going to be Blurays and DVD, then staying in the YCbCr format would do least conversions.
It gets more tricky when you have mixed sources on your display.
Old 11-15-2008, 06:43 AM
Seeco's Avatar
Aha, I see (or do I?). Well I use a lot of different sources, DVD, compressed h/x.264 and xvid, DTV, photos, games. I prioritize the look of h/x.264 material though.
So I take it then that the dongle will perform its compression regardless of what I set pixel format to?
Seeco is offline
Old 11-15-2008, 06:49 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
compression?
Old 11-15-2008, 07:01 AM
Seeco's Avatar
Yeah, that's what's mentioned in the post I linked to earlier. The DVI to HDMI converter that comes with modern ATI graphics cards supposedly compresses pc levels to video levels (without clipping them).
if you use the DVI->HDMI dongle supplied with the 4000 series cards, the dongle will compress (not clip) the colorspace from 0-255 down to 16-235, so by combining that with the registry tweak, you expand all sources on the PC to 0-255, then the dongle compresses all output on the line to 16-235, and your HDTV is happy
Seeco is offline
Old 11-15-2008, 07:16 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Aha, I dont know if I would call it compression, but I see a problem of converting 0-255 to 16-235 as a good thing. Since it would result in artifacting.
256 values dont fit well in 220 values.
Or am I missing something here?
Old 11-15-2008, 08:14 AM
Seeco's Avatar
Well, the video material is 16-235 to begin with, so I have always assumed that first converting it to 0-255 and then back to 16-235 would not make a very big impact, maybe this is wrong? Anyway I don't have many alternatives since my HTPC never is going to be dedicated to video playback only. I guess it might result in some lost tonality in material which is originally 0-255 (games, photos?), but that's the price I have to pay as far as I can understand.
ATI is a company which is all about producing graphics hardware for gaming, video editing, 3d modelling etc. The HDMI format is pretty much a standard nowadays. Wouldn't it be strange if they supplied a DVI to HDMI converter with their cards that ruins tonality in all material which isn't 16-235 video?
At least the way it is now I can't see any banding, and my blacks and whites look allright. I have checked it with both the DVE calibration DVD and a 720p x.264 calibration video, and I can see all the black and white levels fine with both.
Seeco is offline
Old 11-15-2008, 08:49 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Good link here
http://www.audioholics.com/tweaks/ca...els-xvycc-rgb/
apperently its the opposite what i thought, using full RGB draws the 220 values to 256 values.
Of course using YCbCr this isnt a problem.
Old 11-15-2008, 09:38 AM
amirm's Avatar
Liked: 739
The goals are good in that post. But there is not enough explanation to know if the right solution is found. For example, it is NOT sufficient to see levels below 16 to know that the conversion to video levels has been done correctly. Let me explain in detail.
To go from 16-235 video levels to 0-255, you first subtract the "setup" value of 16 and then multiply by 1.16 (ratio of 16 to 235 relative to ratio of 0-255). Let's do the math for a series of values starting from black. Since we are doing floating point (fractional) math but the target has to be fixed, integer value, I am going to show the math both ways: one in floating and second when rounded to an integer:
Code:
16      0               0
17      1.163636364     1
18      2.327272727     2
19      3.490909091     3
20      4.654545455     5
21      5.818181818     6
22      6.981818182     7
23      8.145454545     8
24      9.309090909     9
25      10.47272727     10
26      11.63636364     12
Do you see a problem? If I have a smooth ramp from black to white, as I get between samples 19 and 20 in video, I get a jump of 3 to 5 in graphics/RGB mode! Result is banding as we no longer have a proper gradient.
Solution is to dither. That is, add a random value to samples as to make that step between 19 and 20 be fuzzy. The end result is that we get our ramp back but we wind up with noise added to the video.
Now, if the dongle converts this back to 16-235, then it would need to not only perform the reverse math but also add more dither. Not adding dither causes banding to occur in that conversion. But adding dither means even more noise.
This is why I said if your main goal is to watch video on the PC, then damn the graphics mode accuracy and put the system end-to-end in YUV video mode.
The alternative is to have the conversion from YUV 16-235 to RGB 0-255 happen in one step. In that scenario, you still have to add dither but at least, you are doing it once, not twice (i.e. once in conversion to RGB and second in level range).
The only way to know if any of this is occuring correct is with a DVE like test disc and looking at the ramps on an accurate display that doesn't have banding itself.
amirm is offline
Old 11-15-2008, 10:01 AM
Seeco's Avatar
There's just no end to it, is there? I definitely accept your explanation, although it is quite discouraging. Going from 16-235 to 0-255 should be like Bilbo says in LOTR, "like butter spread over too much bread"
This dithering you mention, does that mean that if it (the codec?) didn't apply dithering when going from 16-235 to 0-255, then it could convert back to 16-235 without any loss whatsoever (it would just have to "do the math")?
Right now what I'm seeing is banding in PC games on my HTPC, what does this mean? If it works as it should, the games (which are 0-255 as everything else) should be converted to 16-235 via the HDMI dongle. How does this produce banding?
According to you and to what I can see myself, what I have now is video with noise and games with banding. I guess that if I applied the tweak setting everything to 0-255, didn't use the HDMI dongle and set my TV to 0-255, then everything would be perfect except for video which would show banding, right? I guess PC:s really aren't meant for this...
Seeco is offline
Old 11-15-2008, 10:55 AM
amirm's Avatar
Liked: 739
That is what I said in my first reply . Most people are not watching accurate video on their PCs. Sad, given where I used to work .
Yes and no. If like I showed, rounding was used, then inverse conversion works. But if the values were simply truncated, then accuracy is lost and inverse conversion gives you something different.
Well banding could be a function of your display not handling the source properly. That is above and beyond the case we are talking about here.
Now, if the display is set to 16-235 and proper conversion with dithering is not done, then that could be responsible for it.
If you do any conversion where there is fractional values, as is in this case, you are going to need to dither. If you don't dither, you get banding. In this case, you may also be going to YUV domain and as such, have color space compaction to boot. And dithering is required here too for proper operation.
PC is a multi-function device. Unfortunately, the people who designed video standards and PCs did not talk to each other much. The result is a complete mess as we have discussed.
In an ideal case, your display would go into RGB 0-255 for graphics/desptop/game work and YUV 16-235 for video. Even if it did this, then your video better be in full screen as otherwise, either the graphics of video would be wrong.
From memory, Windows Media Center gets around this problem by rendering its graphics in the same mode as video. That way, you can set up your display for video and have it all be right. Of course, that only resolves the graphics displayed while inside MCE, not outside.
So the best solution really is to dedicate a PC to video and have that path be correct. Or, just don't let the errors bother you .
amirm is offline
Old 11-15-2008, 11:20 AM
Seeco's Avatar
I see. Well I have fiddled about some more, and I have come up with even more strange fenomena. On my TV (Pioneer PDP-5080XA) I can set the colour space to either 4:2:2, 4:4:4, 16-235 and 0-255. Because I have assumed that the HTPC (via the HDMI dongle) delivers a 16-235 colour space, I have been using the corresponding colour space in my TV. There is also an "auto" setting, which is supposed to read the incoming colour space and match it. When I tried setting it to auto, all of a sudden I have grey blacks in DTV, better low levels in x.264 material, and a brighter picture (although still with good blacks and unfortunately still with banding) in games. I then tried setting it to the 0-255 mode manually and it looks excactly the same, obviously this is the mode it activates when set to auto. This just amazes me! Doesn't this imply that everything isn't really converted the way it should be with the regtweak? And that the signal coming out of the HTPC isn't really 16-235?
Seeco is offline
Old 11-15-2008, 11:36 AM
amirm's Avatar
Liked: 739
Sure sounds like you are in 0-255 RGB.
amirm is offline
Old 11-15-2008, 11:46 AM
Seeco's Avatar
This is so strange, I'll have to trace the information about whatever effect the dongle is supposed to have.
I'm having a hard time wrapping my head around all this, so many variables... If I change between 16-235 and 0-255 when watching something, the effect is very much different depending on what I'm watching:
- If I watch TV
16-235 produces banding and deep blacks
0-255 produces banding and grey blacks
- If I watch x.264 material
16-235 produces a rather dark picture with deep blacks, much detail is lost
0-255 produces equally deep blacks, but the picture is otherwise elevated and much more detail comes out
- If I play games it is the same as with x.264 material, setting 0-255 just makes the picture better (but here I also have banding).
But the whole purpose of the regtweak was to make everything equal to begin with! If now even the dongle isn't doing it's job, then what can I count on? I'm not even upset anymore, I can only laugh at all this
Seeco is offline
Old 11-15-2008, 12:23 PM
amirm's Avatar
Liked: 739
- If I watch TV
This is as it should be. TV has black = 16. If you force your TV to think levels are from 0 to 255, then "16" means something well above black = grey.
You never know how someone has encoded such material. Mistakes are made all the time when people don't understand the differences here.
Putting that aside, expansion of the range may cause such detail to be amplified but that is not necessarily how the material is supposed to be views.
For example, if you turn up the brightness above reference, you also see more detail in darker areas, but that doesn't make it correct. When the material was produced, it was viewed in a reference environment and as such, that detail was invisible to the person making the creative decision.
In this case, for sure you want 0-255. Setting it otherwise, forces compression of the range and detail is lost. Banding here I believe is due to your display not being able to handle full range of what a PC game can create on the fly.
Graphics can do things that never happen in real life. For example, the pixels you see on your computer can go from zero to black in one pixel. Such a thing never happens with video/film camera. So what looks good as a video signal, may not look perfect as synthetic graphics. Flat panels are still not perfect in how they handle gradients.
It is a tough problem. I think the solution starts with understanding what the sources are, and then searching for answers. People may have come up with configurations of PC/GPU/Displays that do the best here.
amirm is offline
Old 11-16-2008, 08:44 AM
Seeco's Avatar
Yes hmm, but I suspect that your answer is overly relativistic Even if there are limitations to how good it can get in the end, I know it can get a lot better than this. At least I would like to see what compressing everything to 16-235 really looks like.
I have now tried re-applying the regtweak, and this time it actually seemed to do it's job - now I have black crush everywhere, HD material, TV, pictures and games. As before though, setting the TV to 16-235 produces black (and I suppose white) crush, and setting it to 0-255 brings out much more detail without affecting the deepest black. I also have banding everywhere, even in HD material although it isn't as noticeable there for some reason.
Surely this must point to the fact that SD material now is indeed expanded to PC levels, but that the dongle isn't doing it's job. Nothing becomes re-compressed, therefore the 0-255 TV setting brings out all the detail but produces banding. I guess spreading the original 16-235 video spectrum across a 0-255 one would do that.
Of course, this doesn't explain why I get banding in PC games which should be happy with 0-255 all the way. I know for a fact that it isn't a matter of what my TV can reproduce, Before this I used an Nvidia 9600GT, and I never had any banding problems there (although due to the settings I used video looked off).
It is also still a mystery to me what the "pixel format" setting actually does. Does it control the actual output from the card, or does it control some pre-output conversion? To be honest I haven't been able to tell a difference at all when playing around with it.
Seeco is offline
Old 11-16-2008, 09:53 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Amir can this much better then me, but I can give a quick example.
4:2:0 (BD, DVD) is basicly one chroma sample per 4 luma samples. When you send out as 4:4:4 it sends one chroma sample per one luma sample.
So it creates 4 individual chromapixels from one big chroma pixel 2x2. And to do that it can do it differently. By just multipliying the chroma value you give the same colorvalue to all 4 pixels, or you can do the more advanced method when you try and use the surrounding data to upconvert the chroma. Just like any other upconversion. There is the quick and the good way of doing things.
Old 11-16-2008, 10:37 AM
amirm's Avatar
Liked: 739
So just checking, you have set the ATI output format to PC standard, RGB, 4:4:4 and you still get banding with games when you did not before?
amirm is offline
Old 11-16-2008, 11:04 AM
Seeco's Avatar
Well yes, but I have also discovered that the pixel format setting is unique to every resolution, I had to set it individually for each of my 24, 50 and 60 Hz 1080p resolutions. I play games in 1360x768 resolution, maybe the pixel format setting isn't effective then? Maybe I should create a profile with the right pixel format for this/other games? Or is the setting only for video? Anyway, the problem persists: Since the tonality of both SD and HD improves (not just improves, reveals detail that can't be seen regardless of how much I elevate brightness under 16-235) when I set the TV to 0-255, I can't see how that can mean anything else than my graphics card sending out a 0-255 colour space. If the dongle would just do what it's supposed to...
I haven't yet been able to spot any difference between the different pixel format settings (although one of them makes the whole screen yellow and green )
Seeco is offline
Old 11-16-2008, 09:37 PM
Atomic Skull's Avatar
Fyi on late model Samsung TVs the "HDMI black level" setting controls whether the TV expects the brightness brightness range to be 15-235 or 0-255.
"Normal" = limited, "Low" = full range
Naturally they had to give it a vague and completely unhelpful name rather than just saying what it is.
It looks like the pixel format setting controls the output of the video card. The same settings I use with a DVI->HDMI cable on my old ATI 1900xt (which is most definitely full range RGB because it doesn't support anything else) look exactly the same with the HDMI dongle on my ATI 4850 set to full range RGB in CCC. No banding in a test gradient when set to full range while setting it to limited shows very obvious banding, black point and white saturation adjustments are also exactly the same.
Atomic Skull is offline
