Can't put MP4 to DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-28-2009, 08:32 PM - Thread Starter
sammy004's Avatar
Hi can anyone tell me how I can convert MP4 to dvd I tried a program called ConvertXtodvd but it is limited to only 64 (I think) videos so I can't add all my videos on it. Can anyone please tell me a good program to convert to DVD or even to join MP4's. Any help will be greatly appreciated.
Thank you
Sammy
sammy004 is offline
post #2 of 9 Old 09-29-2009, 06:52 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2690 Post(s)
Liked: 1921
Thank you
Sammy
You might see if you can find something you like here: http://www.videohelp.com/convert
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #3 of 9 Old 09-29-2009, 06:51 PM
8:13's Avatar
You need to use virtualdub to make the file a avi, then encode the avi to mpeg2 using sw like hc enc.
virtualdub may not open the mp4 so you may need to install ffdshow and use that as the compressor codec.
In the ffdshow codecs is enable disable option, enable vc1 to wmv9 and the h.264 to enable.
In the ffdshow output make sure only yv12 is checked.
Then, when you can open your mp4 with virtualdub you can change compressed to direct stream copy so you don't lose resolution.
You may need to demux the audio and video before using the above proceedure: use tsmuxer to demux audio and video and run video through virtualdub as described above.
There is new, and then you are new.
This is a moral of the bears and their cereal.
8:13 is offline
post #4 of 9 Old 09-29-2009, 07:27 PM - Thread Starter
sammy004's Avatar
I only have H.261 option I don't see H.264 and I saw all the other options and changed them but I still can't open my MP4 files. I was hoping I can just grab my video from my samsung hmx-10 HD camara (all video in MP4 Format) and just be able to put them on dvd but it seams like there is more work then I thought
Any help or any step by steps will be greatly appreciated.
Thank You
sammy004 is offline
post #5 of 9 Old 09-29-2009, 07:44 PM
8:13's Avatar
See the tab called "Decoder"? Click that tab, and for the h.261 click "enable or libacodec, ffmepg, or libmpeg2", whichever is there.
Then scroll down and set raw video to all supported.
Then in the output tab set it to yv12 only.
Then try and open your video file and it should open.
If it doesn't then post in this forum and ask why: link
8:13 is offline
post #6 of 9 Old 09-29-2009, 11:06 PM - Thread Starter
sammy004's Avatar
I keep getting an error unknown or unsupported file type. Is there a good program where I can join a MP4 together without any degrade in video?
sammy004 is offline
post #7 of 9 Old 09-29-2009, 11:53 PM
8:13's Avatar
I read good things about a program called clown something: link
Go post there and tell them you want to use clown to join your mp4 together and they will tell you how.
8:13 is offline
post #8 of 9 Old 09-29-2009, 11:56 PM - Thread Starter
sammy004's Avatar
OK I just found a program that will convert my MP4 to AVI with OK quality however the sound is all crackly like tic tic click.
sammy004 is offline
post #9 of 9 Old 09-30-2009, 12:14 AM
8:13's Avatar
Go post a message here: link and tell them your mp4 files need to be joined and you want to use clown bd but don't know how and could they please help you.
Ok.
8:13 is offline
Reply HDTV Software Media Discussion
