MKV and M2ts on Samsung 55B8000 - AVS Forum
post #1 of 1 Old 01-10-2010, 12:16 PM - Thread Starter
saad3000's Avatar
Hello,
Am trying to play these 2 videos thru DLNA (network with laptop) But it says that the video is not supported. Any ideas how to play them or convert them to any playable videos without loosing quality?? Many thanks!!
***Note: I renamed the m2ts video file to avi and it played it but without a sound. However changing mkv to avi did not play the video nor the sound.
Here is the format of the mkv video file from MediaInfo software:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1mn 42s
Bit rate : 38.5 Mbps
Nominal bit rate : 40.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.619
Stream size : 468 MiB (97%)
Title : Video x264 1080p @ 40 Mbps
Writing library : x264 core 57 svn-709C
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / fpel_cmp=sad / subme=7 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=40000 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1mn 42s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 5.46 MiB (1%)
Title : Audio ingles AC3 2.0 @ 448 Kbps
Language : English
Here is the m2ts video file Info:
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 1mn 56s
Bit rate mode : Variable
Bit rate : 22.1 Mbps
Nominal bit rate : 22.0 Mbps
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.427
Stream size : 307 MiB (94%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 1mn 56s
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Stream size : 6.22 MiB (2%)
Saad
saad3000 is offline
Reply HDTV Software Media Discussion
User Tag List
