how do i convert this video? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-29-2010, 04:57 AM - Thread Starter
micks_address's Avatar
hi folks.
have trouble playing back a media file on my pc.
Here are the media info details
Video
ID/String : 4113 (0x1011)
MenuID/String : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 5 frames
Duration/String : 1h 26mn
BitRate/String : 4 641 Kbps
BitRate_Nominal/String : 4 531 Kbps
Width/String : 1 280 pixels
Height/String : 544 pixels
DisplayAspectRatio/String : 2.35:1
FrameRate/String : 23.976 fps
Resolution/String : 8 bits
Colorimetry : 4:2:0
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.278
StreamSize/String : 2.79 GiB (70%)
Encoded_Library/String : x264 core 65 r999M cc51047
Encoded_Library_Settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4531 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.0
Audio
ID/String : 4352 (0x1100)
Format : PCM
Format_Settings_Endianness : Big
Format_Settings_Sign : Signed
MuxingMode : Blu-ray
BitRate_Mode/String : Constant
BitRate/String : 1 536 Kbps
Channel(s)/String : 2 channels
ChannelPositions : Front: L R
SamplingRate/String : 48.0 KHz
Resolution/String : 16 bits
StreamSize/String : 946 MiB (23%)
The video/audio will play fine on my ps3.. but not my pc or Oppo BD83
I only get video on the Oppo and my Win7 pc media player/vlc
Is there any software i can use to conver the PCM soundtrack to dolby digital?
Cheers,
Mick
micks_address is offline
post #2 of 3 Old 05-31-2010, 03:04 AM
ChrisWiggles's Avatar
Where did you get it and what is it? What's the filetype? Is this on a disc? wtf?
It sounds like you downloaded something from somewhere (questionable), and I'm not particularly motivated to help with that.
I would just point you to VLC player, and one of the various forums out there that deal with these kinds of things.
And btw, this question is entirely in an erroneous forum, this has nothing at all to do with HDTV software media.
ChrisWiggles is offline
post #3 of 3 Old 08-19-2012, 10:19 PM
Brucew0617's Avatar
I don't get anything, and I suggest you to download a free Media Player, or install the media code.
Brucew0617 is offline
Reply HDTV Software Media Discussion
