The Hobbit 48FPS 3D where does BD Stand? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 99 Old 04-12-2011, 02:41 AM - Thread Starter
dvdmike007's Avatar
Liked: 50
So with the Hobbit confirmed to be shooting in 48FPS 3D can Blu handle that frame rate? and with 3D that much information?
Cameron is also talking about shooting at 48FPS for Avatar 2
dvdmike007 is offline
post #2 of 99 Old 04-12-2011, 10:33 AM
Lee Stewart's Avatar
Liked: 51
BD stands were it always has . . . a home video format.
Which is different then a professional cinema format.
Lee Stewart is offline
post #3 of 99 Old 04-12-2011, 11:16 AM
Sujay's Avatar
I believe he's asking if this can transition smoothly to the technical specs of the BD format, if they're not just going to remove every other frame.
Sujay is offline
post #4 of 99 Old 04-12-2011, 11:23 AM - Thread Starter
dvdmike007's Avatar
Liked: 50
Thanks for the contribution, glad you missed all the questions in the OP and thought being clever was more important
Araxen likes this.
post #5 of 99 Old 04-12-2011, 04:57 PM
Liked: 51
You missed the point Mike. BD is designed for the home. There is no transition to 48 FPS. BD can't handle that type of frame rate, especially in 3D.
Just because something comes available for professional cinema does not mean it will be brought over to home video. We are STILL watching HD (ALL HD) at 4:2:0 at 8 bit color space while professional HD is 4:4:4 at 10 or 12 bit color space.
post #6 of 99 Old 04-12-2011, 05:01 PM
Liked: 51
Yes - they will remove every other frame. Called; Skip Printing. They will also do that when they create 35mm prints for theaters when the movies are released in theaters.
post #7 of 99 Old 04-13-2011, 03:23 AM - Thread Starter
dvdmike007's Avatar
Liked: 50
I am aware of what BD can do and did not need patronising thanks, I am well aware that one does not always equate to the other but this could force a change in spec or a move to a new format
Araxen likes this.
post #8 of 99 Old 04-13-2011, 08:03 AM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
It can, at 720p50 or 720p60.
I agree.
I think they should add support for 1080p48/47.96, 1080p50 and 1080p60/59.94 too - and other formats too, otherwise BD is going to be outdated.
Also, what res are they shooting it at? 1080p? 2K? 5K?
Joe Bloggs is offline
post #9 of 99 Old 04-13-2011, 08:33 AM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
Have they said that anywhere?
Is each frame going to have the same amount of blur as current films?
post #10 of 99 Old 04-13-2011, 08:37 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
So people that already purchased 3D players need to upgrade once again. There is a limit before consumers start to avoid purchasing new equipment because of all the changes that seem to happen once a year.
Let the market mature, before making new changes, and maybe let them do more then 2 movies in 48fps 3D. For all we know this could be just as rare as Cinerama.
Still waiting for a scope standard.
MovieSwede is offline
post #11 of 99 Old 04-13-2011, 08:44 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
If they film with open shutters.
post #12 of 99 Old 04-13-2011, 08:56 AM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
Have they said that's what they're doing?
I mean Peter Jackson has talked about there being lot of blur in each frame with current films, if he films it like that, there's going to be the same amount - though maybe it will just look clearer when seen in motion because of the higher fps even though the blur per frame will be the same.
post #13 of 99 Old 04-13-2011, 09:04 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
The problem is if he shoot at higher shutterspeed then open shutter, the 35mm copy will look more or less like Saving private Ryan.
But you can test it for yourself, shoot with a 50i camera and open shutter and it will look close to what the Hobbit will look like.
post #14 of 99 Old 04-13-2011, 09:33 AM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
Actually I don't think they should use a shorter shutter, but if they want less blur than in normal films like he was saying, they should use a higher fps than 47.96/48 fps. Lets hope James Cameron and Douglas Trumbull etc. use >=60 fps instead.
post #15 of 99 Old 04-13-2011, 01:29 PM - Thread Starter
dvdmike007's Avatar
Liked: 50
There is another option
post #16 of 99 Old 04-13-2011, 01:37 PM
Jamie E's Avatar
48 fps is supposed to be very close in appearance to 60, according to Peter Jackson. And 48 makes a lot more sense for cinematography, since there are still a LOT of film projectors out there, and it would be a lot simpler and cleaner to turn 48 fps to 24 fps, rather than 60 to 24.
Movies look their best when they look like movies. More Patton-esque remasters!
Jamie E is offline
post #17 of 99 Old 04-13-2011, 01:52 PM
Liked: 51
So how does that apply to BD which you have voiced is your greatest concern?
post #18 of 99 Old 04-13-2011, 02:41 PM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
Douglas Trumbull is also going to do a film in 3D at a higher frame rate - he's currently writing the screenplay and has said it will be at high frame rate. If he chooses 60 fps instead of 48, it will be easier to encode onto Blu-ray at that frame rate than encoding a 48 fps film onto Blu-ray in a format which can hold at least that many frames in a second, without visible conversion artefacts. 720p60 3D is possible on Blu-ray, 720p48 3D isn't, so would need to be converted to 720p50 or 720p60 if you wanted it in 3D with about the same motion.
post #19 of 99 Old 04-13-2011, 03:00 PM
Liked: 51
Douglas Trumbull is also going to do a film in 3D at a higher frame rate - he's currently writing the screenplay and has said it will be at high frame rate. If he chooses 60 fps instead of 48, it will be easier to encode onto Blu-ray at that frame rate than encoding a 48 fps film onto Blu-ray in a format which can hold at least that many frames in a second, without visible conversion artefacts. 720p60 3D is possible on Blu-ray, 720p48 3D isn't so would need to be converted to 720p50 or 720p60.
LOL - so they are going to abandon "full HD" and go with 720P? I don't think so.
post #20 of 99 Old 04-13-2011, 03:03 PM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
They can choose to do whatever they want. They might release whatever they think best represents the look of the original. Some Blu-ray producers (which I've previously mentioned) have already chosen it over 1080p24. They could sell both if they wanted to, or have both in a disc set. I wouldn't be surprised if Douglas Trumbull decides to release a 720p60 version on Blu-ray. From the video above, which do you think Douglas Trumbull thinks is more important - higher spatial resolution or higher frame rates?
post #21 of 99 Old 04-13-2011, 03:10 PM
Liked: 51
You better read the specs again on 3D BD. There is but a single spec for movies . . . frame packed 1080x24P. Frame packed 720P is for video games for the PS3.
post #22 of 99 Old 04-13-2011, 03:23 PM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
Have a look at page 41:
http://www.blu-raydisc.com/assets/Do...ions-18780.pdf
Look at the specs of titles like the 3D FIFA World Cup Blu-ray or the 3D Blu-ray title(s) from AIX Records (Goldberg Variations Acoustica 3D Blu-ray) - which are not PS3 games.
post #23 of 99 Old 04-13-2011, 03:41 PM - Thread Starter
dvdmike007's Avatar
Liked: 50
Did you even watch the video????
They can cut the fames out and not turn it into blur o vision
Or are you just looking for an argument?
You won't find it, just a few ignore lists
post #24 of 99 Old 04-13-2011, 03:56 PM
Liked: 51
That isn't a movie. That was a sporting event that was shot in 720x50P and converted to 720x60P for the USA release.
Now . . . if you can show me a 3D movie that was converted to 720x60Px2 that's fine. But until then . . .
post #25 of 99 Old 04-13-2011, 03:58 PM
Liked: 51
Mike - what is your problem?
Maybe you would like to explain to all of us when shooting in 120 FPS how you are going to accomplish shooting for slow motion?
And how does that video releate to your OP? Are they going to increase the frame rate of 3D BD to 49 or 60?
post #26 of 99 Old 04-13-2011, 04:04 PM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
It wasn't shot in 720p, it was shot in 1080/50i, and encoded on Blu-ray at 720p60 3D.
Goldberg Variations Acoustica 3D Blu-ray was shot at 1080 resolution at 30 fps and converted to 720p60 3D for the Blu-ray.
You claimed that Blu-ray was not capable of encoding video - that is not a 3D PS3 game at 720p60 3D - that there was only one standard available ie. 1080p24.
I showed that it is in the 3D specs and is available to encode at - like those two titles above.
Producers can encode at anything in the Blu-ray specs. 720p60 (or more specifically, 720p59.94) is in the Blu-ray 3D specs. Producers have already encoded with it, so of course it's an option that Douglas Trumbull could use if he decides to, and has made his film at 60 fps.
post #27 of 99 Old 04-13-2011, 04:18 PM - Thread Starter
dvdmike007's Avatar
Liked: 50
The whole point of showscan digital is they can knock it back to 24fps without losing detail to motion blur
post #28 of 99 Old 04-13-2011, 04:19 PM
Liked: 51
My bad - it was shot in 1080i50 SbS:
As for the tech side of things, ESPN was taking in the 1080i50 side by side 3D signal and converting it to the US-friendly 1080i60 side by side,
http://hd.engadget.com/2010/06/11/es...verage-live-f/
I showed that it is in the specs and is available to encode at - like those two titles above.
Producers can encode at anything in the Blu-ray specs. 720p60 is in the Blu-ray 3D specs. Producers have already encoded with it, so of course it's an option that Douglas Trumbull could use if he decides to, and has made his film at 60 fps.
So the following means nothing huh?
"From a technological perspective, it is simply the best available platform for bringing 3D into the home," said Benn Carr, chairman, BDA 3D Task Force. "The disc capacity and bit rates Blu-ray Disc provides enable us to deliver 3D in Full HD 1080p high definition resolution."
http://www.blu-ray.com/news/?id=3924
post #29 of 99 Old 04-13-2011, 04:21 PM
Liked: 51
1. That doesn't add any frame rate to 3D BD. It will still be 24 FPS.
2. How will they shoot slo-mo?
post #30 of 99 Old 04-13-2011, 04:22 PM
Joe Bloggs's Avatar
Quoted: 432 Post(s)
Liked: 118
But anything they lower to 24 fps will either have the same amount of blur as current 24 fps films shot with a 180 degree shutter, or if they have less blur they'll have more strobing.
Reply HDTV Software Media Discussion
