powerdvd 10 ultra - AVS Forum | Home Theater Discussions And Reviews
Old 07-30-2011, 01:06 AM - Thread Starter
abxnightpilot's Avatar
I have Powerdvd 10 ultra and have been using it to play Blurays. I recently started using it to view 3D-movies. When I start a 3D-movie I get a note that says,
"Your 3D hardware only supports the viewing of 3D movies in full screen mode. Would you like to enter full screen mode? In full screen 3D mode some functions are temporarily disabled."
When I select "Yes", the 3D works but I can't see the mouse. Because of this I am unable to exit Powerdvd 10 without ending the program with Window's Task Manager. I have tried Esc, Ctrl X, F5, as well as about every key on the keyboard just to see if something will work. Is there something I'm missing? Thanks.
abxnightpilot is offline
