changing my blu ray video libary need help - AVS Forum | Home Theater Discussions And Reviews
Old 01-07-2012, 10:21 AM - Thread Starter
etrin's Avatar
Quoted: 25 Post(s)
I have all my movies on my nas. BUT since I was looking for an easy way to put them there I used anydvdHD. NO it worked great for what it does but I am now wanting to change it up.
When I ripped the blu ray I tried making iso's and also just ripped the entire thing. Great this way I will have it just like the disk.
BUT I have a big problem playing them back I can NOT skip to the bd menu to play I have to fast forward thru the DAMN previews.
What can I do to fix this?
Should I re rip them and use something different like makemkv and try to get only the movie or can I do something in place and get rid of these stupid crap ads.
START RANT_______________
WOW I think the disk should be free if I have to get ads. I pay and don't get them.
END RANT____________
any way thanks for any and all help with this. I have work ahead and I need to do it as painless as possible.
etrin is offline
Old 01-28-2012, 10:11 AM
SillyConVal's Avatar
Did you rip them with the box checked for "Feature Removal: Prohibited User Operations"?
If you have .ISOs, you can mount them one at a time and use ClownBD to make new .ISOs with only the feature and selected audio tracks. This will strip out the "mandatory" trailers.
SillyConVal is offline
