Best software for 7.1 playback? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-18-2012, 03:48 PM - Thread Starter
jasontaylor's Avatar
Wanted: good player for playing 7.1 surround sound video files. It should indicate if the source is 5.1, 6.1, or 7.1. It should tell you if it is unable to playback correctly.
VLC: Free. Sometimes m2ts files are silent on the primary LR or center channels. Not even sure it can decode 7.1 dts. Nice ability to select audio source and audio device however.
Boxee: Not tried. Does it work? New beta seems good.
XBOX media center. This is open source so I am assuming it doesn't work with stuff you can buy in a store. Am I wrong?
Free MPC: free, comes with some good k-lite codec tools, including one that let's you select # of speakers in your system. Invisible controls. No way to setup since it is a hodgepodge.
Non-free software: Ok obviously I need to buy this. Right? What do I buy? What are you guys using to play m2ts mkv files with a variety of audio channels. stereo, 5.1., 7.1, dd, etc.
Jason
jasontaylor is offline
post #2 of 3 Old 07-15-2012, 08:50 AM - Thread Starter
Update. I tried http://www.cyberlink.com/products/powerdvd/overview_en_US.html (PowerDVD by Cyberlink) but it downgrades 5.1 audio to like stereo if you are running XP!!! Like what is the point? Also it is hundreds of megs bloated. I don't need a facebook interface I need a player that can do surround sound. So I uninstalled it.
post #3 of 3 Old 07-16-2012, 05:24 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2684 Post(s)
Liked: 1920
DVDFab just announced a media player: http://www.dvdfab.com/media-player.htm.
I haven't tried it. Free trial. "powered by XBMC".
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Reply HDTV Software Media Discussion
