Bit rate vs 1080 or 720 - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2012, 08:51 PM - Thread Starter
mg777's Avatar
would it better to have a 720 p movie with a bit rate of between 4-8 kbps or 1080p movie with a bit rate between 2-5 kbps? I notice on my ps3 when i play a 720p movie i ripped myself it says the kbps is running between 4-8, but the 1080 movie is playing 2-5kbps? What's the deal? Any explanation would be greatly appreciated.
mg777 is offline
Old 02-19-2012, 10:17 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 581
The higher the bit rate the better the quality. Higher resolutions require more bandwidth and a higher rate, which if not high enough will introduce artifacts.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
