Ripping Blu-Rays with lossless audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-24-2012, 08:54 PM - Thread Starter
deadsix's Avatar
So I'm trying to rip my blu-ray collection to MKV's and I'm having trouble getting the lossless audio to stick. I grab the largest M2TS file (or collection) from the BMDV/STREAM folder of the Blu-Ray. I use MKV Merge to take out all the foreign audio tracks and subtitles. When I check the media with mediainfo and Media Player Classic - Home Cinema the DTS-HD MA bitrate shows up as 1561 / 1510.
Is their something wrong with my process? I'm wondering where the extra information is lost. Thank you for your help.
deadsix is offline
post #2 of 8 Old 05-01-2012, 03:08 PM
Epyon415's Avatar
Quoted: 649 Post(s)
Liked: 393
What software are you using to rip the BD? If you haven't already look into EAC3TO. Its command-line based (a gui version is AnotherEAC3TO) but from personal experience it does a great job of ripping the video and audio lossless.
PSN & XBL: Epyon415
Twitch.tv: http://www.twitch.tv/epyon415
Twitter: @roguengames
YouTube Gameplay Videos
I am the greatest MGO player eva!! - http://www.twitch.tv/epyon415/v/24236420
Epyon415 is offline
post #3 of 8 Old 05-02-2012, 05:38 AM
chucky08016's Avatar
Take a look at DvdFab HD. It will succeed in doing what you want to do, it's fast, and should you need to, shrink the files down or passthru the audio and video untouched... subtitles... etc.
This is the only program that I use and have been using it for years.
chucky08016 is offline
post #4 of 8 Old 06-17-2012, 09:51 PM
John Livings's Avatar
Check out MakeMKV. Works great! I ripped all my Blu-rays.
John Livings is offline
post #5 of 8 Old 06-21-2012, 08:39 AM
Aknot5's Avatar
^ Seconded. I've used MakeMKV on hundreds for the last year and it's worked well. eac3to is a very powerful tool, but I prefer stripping down to HD audio, untouched video, chapters and forced subs into an MKV in one step. Select BD iso or folder structure, outputs MKV- easy as that.
Aknot5 is offline
post #6 of 8 Old 06-21-2012, 08:09 PM
nateo200's Avatar
MakeMKV is great. I love it! I have a MacBook and it works great for DVDs and Blu-rays as well as HD DVD's (although I don't have an external Blu-ray drive any more :/). The bit rate should be correct as DTS-HD is Core + Extension which means the 1510 is the core and the 1561 is the difference between the core and the original PCM signal compressed losslessly. I have a ton of DTS-HD samples as allot of them display the same or similar bit rate. I uploaded an attachment of a screenshot of The Expendables that I ripped in MediaInfo. Screen Shot 2012-06-21 at 10.05.40 PM.png 101k .png file
Name:	Screen Shot 2012-06-21 at 10.05.40 PM.png
nateo200 is offline
post #7 of 8 Old 06-26-2012, 02:52 PM
trophybuck135's Avatar
what model blu ray drive are you boys usin
trophybuck135 is offline
post #8 of 8 Old 06-27-2012, 05:19 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2688 Post(s)
Liked: 1921
ASUS BC-12B1ST/BLK/B/AS OEM
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
Reply HDTV Software Media Discussion
