How to change audio codec? (FLAC to AC3 in a MKV file) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-18-2012, 05:51 PM - Thread Starter
yamilg's Avatar
I got a Philips BD player, which plays .mkv files, but it doesn't support some audio codes, like FLAC.
Trying to change the audio codec of my .mkv files (with FLAC audio codec) to something my player can support.
I'm looking a very good program that let's you change audio codecs for MKV, but letting totally untouched everything else, like video.
These are the audio codecs the player supports: PCM, AC-3, DTS core, MPEG, MP3, WMA, AAC, HE-AAC.
I'm not that good with these kind of things, so any help will be appreciated, like which codec mentioned you recommend or anything else (i've read AC3 or AAC are good).
Also i'm not sure if this is the right forum to ask.
Thank you all.
yamilg is offline
post #2 of 12 Old 05-20-2012, 05:18 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2682 Post(s)
Liked: 1915
This can be done with free tools, but it would be a multi-step manual process for each file:
  • extract the flac
  • convert it to wav
  • convert the wav to mp3 (or other supported codec)
  • create a new mkv file with the original video and new audio
I presume you want a one-step automated solution?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #3 of 12 Old 06-01-2012, 08:17 PM
phik's Avatar
Demux: mkvextract
http://sourceforge.net/projects/mkvextractgui-2/
flac.exe -d
to extract the wav
Convert: wav2ac3
http://code.google.com/p/wavtoac3encoder/
Remux: mkvmerge
http://www.bunkus.org/videotools/mkvtoolnix/
If you need to do a load of these, I'm sure if you are motivated enough, you can cook up a script to automate a whole folder full of mkv's
phik is offline
post #4 of 12 Old 01-18-2014, 02:17 AM
pamelar's Avatar
  • I agree with wmcclain. If you only want to change the audio format, I suggest you extract the audio from MKV file to MP3 format, then using video editor(windows movie maker) to add the converted audio to specified mkv file. Before adding the audio, you had better delete the audio file of the mkv video. I'm not sure if this is what you really want. It's just a suggestion.
  • Here is a link you can check to learn how to convert mkv file to mp3 directly.http://www.apowersoft.com/convert-mkv-file-to-mp3.html
pamelar is offline
post #5 of 12 Old 01-25-2014, 10:34 AM
isolar801's Avatar
Quoted: 12 Post(s)
http://www.videohelp.com/tools/PopCorn-MKV-AudioConverter
Can do individual files or folders.....works great
isolar801 is offline
post #6 of 12 Old 03-15-2014, 07:44 AM
batjac7's Avatar
PopCorn-MKV-AudioConverter worked. I did not know this existed.
batjac7 is offline
post #7 of 12 Old 09-06-2014, 10:10 PM
Nodscene's Avatar
Quoted: 123 Post(s)
Although I haven't had to test this feature out myself it looks like Handbrake does it easily and quickly. I use it when my media player doesn't play old xvid files etc so usually transcode everything to mkv. Usually only takes a few minutes or so and I know there is an audio tab where you can select which codec to use. A couple clicks and you are done.
Make something idiot-proof, and they will build a better idiot
Nodscene is offline
post #8 of 12 Old 09-10-2014, 07:24 PM
Luke M's Avatar
Quoted: 279 Post(s)
Liked: 79
ffmpeg can do this in a single step. For example:
ffmpeg -i infile.mkv -vcodec copy -acodec ac3 -b:a 640k outfile.mkv
Luke M is offline
post #9 of 12 Old 12-11-2014, 11:44 PM
Liked: 1
Originally Posted by wmcclain View Post
This can be done with free tools, but it would be a multi-step manual process for each file:<br><ul><li>extract the flac</li>
<li>convert it to wav</li>
<li>convert the wav to mp3 (or other supported codec)</li>
<li>create a new mkv file with the original video and new audio</li>
</ul><br>
I presume you want a one-step automated solution?<br><br>
-Bill
Could you recommend one that you have tried that worked? I am in the smae situation now.
emma24xia is offline
post #10 of 12 Old 12-12-2014, 05:08 AM
wmcclain's Avatar
Liked: 1915
I don't have a graphical tool for this. I use command-line ffmpeg as shown just above your post. Usage is going to vary depending on what you are trying to accomplish.
-Bill
post #11 of 12 Old 03-16-2015, 01:51 AM
Liked: 0
Just try Bigasoft Total Video Converter. I know little about commend line or something like it. So i found a program to help me convert the MKV FLAC to MKC AC3 without re-encoding the video part. it will take a few minutes to finish the audio re-encoding. Get more details about how to change audio codec easily.
Google bigasoft how to change audio codec.
Jordan Red is offline
post #12 of 12 Old 05-19-2016, 04:38 AM
Liked: 0
  • extract the flac
  • convert it to wav
-Bill
Faasoft Video Converter can do all the job for you.
plibemmer is offline
