Buying Blu Ray Discs, newbie ques: - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-11-2012, 10:51 AM - Thread Starter
debnova's Avatar
Ordering my First BD player. When I go about purchasing or renting BD's what do I look for in referrence to How it's recorded? I'm non-tech, but I seemed to have gleaned from the forums that the actual discs can vary in quality, some because their older, or just a manufacturers decision, and I want to at least have a way of identifying a disc that is better quality. Perhaps its indicated on the actual BD Box, etc.
the impossible happens everyday
debnova is offline
post #2 of 9 Old 06-11-2012, 11:09 AM
Selden Ball's Avatar
Quoted: 3079 Post(s)
Liked: 1507
You can only find out by reading reviews. The manufacturers really aren't interested in telling you when their workmanship is shoddy.
Ratings of picture quality can be found in http://www.avsforum.com/t/1168342/the-new-pq-tier-thread-for-blu-ray-rankings
Ratings of audio quality can be found in http://www.avsforum.com/t/1190265/new-audio-tier-thread
Selden
Selden Ball is online now
post #3 of 9 Old 06-14-2012, 11:01 AM - Thread Starter
debnova's Avatar
Thanks, I get what you mean. I was thinking when I see an older BD, it might be designated as a "re mastered" or some identification that it didn't start as a Blu Ray disc. Or even a referrence to a discs technical attributes, so to speak. Kind of like when I used to buy Telarc cd's cause of the better audio recording.
Thanks for the link, I will check the reviews and info. You've helped me quite a bit as I've been posting lately, really appreciate your expertise. I went ahead and splurged for the Panny 500, should get it today. Can't wait to listen to my cd's, then build a moderately priced surround sound system, then really enjoy BD movies since I've never seen a BD at home. Fun!
debnova is offline
post #4 of 9 Old 06-14-2012, 11:03 AM - Thread Starter
debnova's Avatar
Oh, quick update. The link you gave is really great, does speak to some of my "quality to look for" concerns. Leave to AVS forums to inform!
debnova is offline
post #5 of 9 Old 06-14-2012, 12:16 PM
Liked: 1507
You're very welcome!
Selden
post #6 of 9 Old 06-14-2012, 01:31 PM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
You may want to check out reviews here at AVS Reviews, Blu-ray.COM and High-Def Digest.
Wendell R. Breland is offline
post #7 of 9 Old 06-14-2012, 09:27 PM - Thread Starter
debnova's Avatar
Thanks for the heads up Wendell, I will. Nice feature here on the AVS.
debnova is offline
post #8 of 9 Old 06-16-2012, 08:28 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Also, Home Theater Magazine does monthly reviews of all the popular BD releases.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #9 of 9 Old 06-16-2012, 09:35 AM
Quoted: 288 Post(s)
Liked: 157
Correct, I subscribe to Home Theater Magazine and Sound & Vision print magazines. Both have Blu-ray reviews. Wide Screen Review used to have extensive Blu-ray reviews but I have let my subscription lapse so can not speak for current versions.
Reply HDTV Software Media Discussion
