Has anyone backed up their Lord of the Rings Extended blu rays? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-23-2013, 03:42 PM - Thread Starter
mirak's Avatar
Quoted: 46 Post(s)
I use Clown_BD to rip my blu rays to M2TS file structure. The Lord of the Rings EEs present a challenge because they are each split over two discs.
I've seen a number of threads on this topic, but they are all pretty dated and the advice is all over the place. I just want to merge the two streams together, without audio delay, preserving the subtitles and hopefully preserving chapters, too.
Have you successfully done this? If so, I'd appreciate advice on best software, steps, etc., or maybe just a link to the guide that worked for you.
Keep in mind, I'm really a novice at this, which is why I use Clown_BD to take the guesswork out. Thanks.
mirak is offline
post #2 of 2 Old 06-24-2013, 06:13 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2715 Post(s)
Liked: 1947
The best thread for this sort of question is probably: http://www.avsforum.com/t/1336046/ripping-blu-rays-ii
I believe tsMuxeR will do what you want, but I haven't tried combining two M2TS files; it's free.
M2TS doesn't support chapters, does it? Or are ripping the whole structure, not just the M2TS files?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Reply HDTV Software Media Discussion
