stream blu-ray to ipad or nexus? (airplay, maybe?) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-28-2013, 09:17 PM - Thread Starter
ivo welch's Avatar
hello, hollywood:
I am still looking for a way to stream blu-rays quickly to an ipad or nexus. I can't figure out how one could do this. (I do not want to take hours to rip a blu-ray first.) maybe airplay?
any solutions?
ivo welch is offline
post #2 of 6 Old 08-30-2013, 09:53 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Hollywood doesnt want you to be able to do that.
Rather, they want you to buy another copy off itunes or whatever, and buy a seperate copy for each and evey device you want to watch it on.....
Follow the money.
qz3fwd is offline
post #3 of 6 Old 08-30-2013, 04:37 PM - Thread Starter
ivo welch's Avatar
I think you are attributing too much intelligence here. many blu-rays now come with a free stream purchase, and some even with stream+dvd.
too many lawyers, bureaucracy, and status-quo...and quasi-monopolies over specific movies.
post #4 of 6 Old 09-02-2013, 12:01 AM
chadsdsmith's Avatar
Quoted: 31 Post(s)
Liked: 24
I think the op is asking to do this without using handbrake to convert it or having to use the digital copy etc. The only real way to do this that I know of is with an app like splashtop to remotely access your pc. I have tried it with blu ray rips using my android tablet (actually an hp touchpad with android ported over to it) but it is available for ios. This was playing my blu ray iso's via vlc video player on my pc (power dvd would not work). It works ok but I did have some audio synch issues that I would have to correct every time in the vlc setting to get it to work in synch. It really only works well from within my own network, though it might work okay with a really good wifi source as well. I didn't try it but it should also work directly playing the disk in your computers drive as well, assuming you walk over to your computer drive and drop in the disk of course. You are never going to find a way to play the blu ray files directIy on your portable device, as that would require the device to be able to decode and playback blu ray files, which requires more processing power than any of the current tablets,phones etc have. Even then playing blu ray files wirelessly is not likely to happen very efficiently, as it requires a ton of bandwidth to stream 20ish gb files like that in the first place. Personally, I just take my blu ray files and use handbrake to convert them to mp4 format. They are only a few gigs and look great on tablets/phones. They also stream over my network very well. Of course, handbrake takes time to do, especially with an older computer processor. Hope that helps.
chadsdsmith is offline
post #5 of 6 Old 09-02-2013, 10:37 AM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Yes-and there are usually/almost always multiple sku's at different price points, 1 of which does not contain the "extra" versions.
So you are paying more for them to sell you another format.
qz3fwd is offline
post #6 of 6 Old 09-03-2013, 08:22 AM - Thread Starter
ivo welch's Avatar
ironically, there are windows tablets, but none that come with a bluray player and good sound.
maybe the usb on a nexus may work with an external usb? (or even wireless usb?)
Reply HDTV Software Media Discussion
