Any appreciable difference in DVD and Blu Ray audio versions of same material? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-21-2013, 07:47 PM - Thread Starter
cruce's Avatar
Is there any appreciable difference in audio quality between DVD and Blu Ray versions of the same musical material--i.e., the same concert, etc. I'm not concerned with video quality, only 5.1 sound, usually of classical music. I'd just like to know if the greater price for the blu ray version is reflected in overall sound.
cruce is offline
post #2 of 2 Old 09-22-2013, 08:23 AM
Selden Ball's Avatar
Quoted: 3052 Post(s)
Liked: 1494
Yes.
Whether or not you can actually hear the difference depends on the quality of your listening environment, including (in rough order of importance) your own hearing, the room, the speakers and the audio and video electronics.
DVDs use lossy compression in their surround-sound Dolby or DTS audio tracks, although some include lossless PCM stereo tracks. Also, for Dolby, at least, they can use any of several different levels of compression and resulting loss of quality. Still, I was quite surprised at how good some of the early music DVDs sounded, even though they didn't use the maximum bitrate available. The psychoacoustic principles that the compression techniques are based on are quite effective. A simplistic example is that a quiet sound at one frequency is easily made inaudible by a very loud sound at another. Also, when video is included, many people are sufficiently distracted by what they see that they are much more forgiving of the sound.
Most (but not all!) BDs use lossless compression for their primary tracks, so you can be sure you'll hear every nuance included by the people who mixed the audio tracks. Which lossless compression is used doesn't matter, of course -- LPCM, Dolby TrueHD or DTS HD-MasterAudio -- lossless is lossless. What matters is the quality of the mixing performed on the audio by the studio.
Selden
Selden Ball is online now
Reply HDTV Software Media Discussion
