Dvhstool - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-01-2004, 11:04 AM - Thread Starter
Eugene157's Avatar
Quoted: 231 Post(s)
Liked: 41
Hi
I have a few HDnet DVHS tapes that are not copy protected and would like to make some back ups as recommended by the HDnet founder.
My plan was to use the JVC30k, play to the hard drive of my computer and then back to tape.
Can this be done and where can I download DVHSTOOL. The website mentioned is not working.
My computer is a P4 1.8Ghz.
Thanks, Gene
Eugene157 is offline
post #2 of 4 Old 11-01-2004, 08:34 PM
HDHTPC's Avatar
Yes, that can work - you need XP with Service Pack 1
http://www.kgbird.com/DVHSTool/
HDHTPC is offline
post #3 of 4 Old 11-17-2004, 06:31 PM - Thread Starter
Eugene157's Avatar
Quoted: 231 Post(s)
Liked: 41
Hello
I have not been able to record from my computer to the JVC 3k. Obviously I must be doing something stupid.
I can record to the computer from a HDnet tape and can control the tapedeck from the computer. Recordings to the HD play back ok via winDVD 6 platinum and I can , from the computer preview HDnet tapes via winDVD and the deck itself.
But recordings made to the deck from the PC HD just have a blank screen on DVHS pb.
Thanks for helping.
Gene
post #4 of 4 Old 11-18-2004, 10:25 AM - Thread Starter
Eugene157's Avatar
Quoted: 231 Post(s)
Liked: 41
I noticed that the JVC tape speed on playing a HDnet tape is set at HS, when trying to record to the JVC from the computer the tapespeed switches to STD. I wonder if that is too slow to accomodate the 45 MB data stream.
And what should the file extension be? TS ?
Hope someone can shed some light on this.
Gene
Closed Thread HDTV Software Media Discussion
