Industry Insiders Q&A Thread: only Questions to insiders please - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1531 of 4623 Old 08-16-2006, 01:15 PM
madshi's Avatar
Quoted: 500 Post(s)
Liked: 472
A simple question: How does the copy protection for the managed copy work technically? I mean how does it stop me from sharing the managed copy with the world?
madshi is offline
post #1532 of 4623 Old 08-16-2006, 01:26 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
AACS does not specify this. Instead, technology vendors provide specifications to AACS for approval. If such specification does not satisfy the requirements of AACS in this regard, it will not be approved.
In simpler lanugage :), the system will need to use some sort of copy protection system as to not allow unauthorized usage. This means some form of DRM system where the content is encrypted, and it usage rights decide whether it can be played or not. With a proper "license" (key), the file itself would be useless (assuming the system is not compromised).
amirm is offline
post #1533 of 4623 Old 08-16-2006, 01:32 PM
madshi's Avatar
Quoted: 500 Post(s)
Liked: 472
And "technology vendors" would be the HD player manufacturers? Or would that be third parties from which the HD player manufacturer would license such a technology? Do you expect that there will be multiple different/incompatible solutions?
I'm just thinking about the poor media player manufacturers. If they have to implement 20 different managed copy systems (because every HD player manufacturer uses a different technology) they'll have a *very* hard time.
madshi is offline
post #1534 of 4623 Old 08-16-2006, 02:26 PM
SpHeRe31459's Avatar
Quoted: 16 Post(s)
I think it is more like platforms. For example Windows Vista has its own DRM tech from the OS level up that I would assume is perfect for securing a managed copy. Then for example Toshiba would develop their own protection mechanim for their network enabled set-top player.
The mechanism itself doesn't matter to the optical disc or AACS itself, what matters is that there is an approved DRM system in place to prevent managed copy abuse.
Of course that still leaves your point about 20 different DRM systems a possibilty, but that only effects interoperability among devices that want to share the managed copy. Which I agree is hardly a ideal.
Did I get the gist of this right?
SpHeRe31459 is offline
post #1535 of 4623 Old 08-16-2006, 02:42 PM
amirm's Avatar
Liked: 739
It could be either. Most CE companies do not have this technology so it is more likely to be from third-parties. And yes, different systems mean incompatibility.
Fortunately, the situation is not that bad. Getting AACS approval is very difficult as the bar is quite high as far as robustness. So even common technologies such as Apple fairplay may not usable here. If I were to guess, I would say there are only 2-3 options right now.
Note that in our case, we license our DRM very broadly so it is relatively easy for other companies to support it. For example, the Pioneer BD player already has such support (although it requires more work to make it play managed copy content). So compatibility in our case is easier to achieve.
amirm is offline
post #1536 of 4623 Old 08-16-2006, 03:01 PM
madshi's Avatar
Quoted: 500 Post(s)
Liked: 472
Ok, after thinking about it a bit more, probably managed copy will be used a lot on computers. E.g. I could imagine having a HD-DVD drive and wanting to do a managed copy to the HTPC hard drive. Now the HD-DVD drive in the computer is probably not from Toshiba or LG or any such CE company, but it's going to be more from a more computer oriented company like NEC or LiteOn. Now who decides which managed copy technology is being used in this situation? Is it NEC/LiteOn? Or is it the studio which produced the HD-DVD I want to have a managed copy from? Or can I choose myself which of the approved technologies I can use?
Thanks Amir, your comments are very much welcome, as always!
madshi is offline
post #1537 of 4623 Old 08-16-2006, 03:08 PM
amirm's Avatar
Liked: 739
You are welcome :).
As to your other question, it doesn't matter how makes the drive for the PC as they are only component suppliers in that case. Other companies will write the software to play the content or make a managed copy.
BTW, TSST, the joint venture between Toshiba/Samsung will also supply PC drives.
amirm is offline
post #1538 of 4623 Old 08-16-2006, 03:12 PM
lymzy's Avatar
But the Sigma Design SoC needs to support MS-DRM to make this streaming of MMC work?
Also, we will see bluray CE players to play managed copy of HD DVD from the Vista MCE in the future, right? :)
HDPLEX
lymzy is offline
post #1539 of 4623 Old 08-16-2006, 03:12 PM
madshi's Avatar
Quoted: 500 Post(s)
Liked: 472
Yeah, but who decides which managed copy technology is being used:
(1) Can I choose myself?
(2) Does the drive supplier/manufacturer decide?
(3) Does the studio decide?
If I could decide myself, I could choose a technology that my media player device supports. If the drive manufacturer or if the studio decides, things are going to be more complicated, because then I'll eventually have to deal with multiple different managed copy technologies.
madshi is offline
post #1540 of 4623 Old 08-16-2006, 03:17 PM
amirm's Avatar
Liked: 739
It already does or the Pioneer player would not be able to play streamed WMDRM content :).
In theory it is possible. In practice, they may not do so for political reasons, or the extra engineering required to go beyond playing regular Windows Media content.
amirm is offline
post #1541 of 4623 Old 08-16-2006, 03:20 PM
amirm's Avatar
Liked: 739
Yes, among the approved technologies. And assuming you are a licensed developer of said DRM system.
Not in the case of PCs. Whoever writes that software devices. In case of home servers that are not PCs, then the developer of that system decides.
Nope. They have to allow all approved output protection systems.
Again, you can if are a developer. If you are an end user, you can only make this selection if your managed copy provider gives you more than one choice. Or you have access to multiple providers of such software (which is possible in the PC context).
amirm is offline
post #1542 of 4623 Old 08-16-2006, 03:24 PM
eq_shadimar's Avatar
Quoted: 26 Post(s)
Liked: 49
Thanks to the insiders who answered my question about firewire and 5C. In short it is possible and legal however very expensive to make it work (although still cheaper than a new TV I bet :) ) Perhaps this is a situation where a high end player can have some value added over a cheaper one.
Thanks again!
Jeff
...wake up to find out that you are the eyes of the world...
My HT Construction Thread - Updated Pictures 3/15/07
My 2.35:1 Discussion Thread - Updated Pictures 3/15/07
XBL = eqshadimar
eq_shadimar is offline
post #1543 of 4623 Old 08-16-2006, 03:29 PM
amirm's Avatar
Liked: 739
Thanks again!
Jeff
Jeff, I don't think a high-end player will attempt to do this either. Transcoding to other codecs will reduce quality and they would not like to be known for that. They would also have to compress menus which could make them look really bad as they are hard to compress losslessly with MPEG-2.
With HDMI around, there really is no reason to go this way.
amirm is offline
post #1544 of 4623 Old 08-16-2006, 03:38 PM
dialog_gvf's Avatar
I think he means given a list of approved DRM systems for MC out there, does the consumer have the choice of which will be used? Or will the choices be limitted to the specific set for which the device maker of the MC originating device has chosen to support?
Gary
- Don't trust sigs
dialog_gvf is offline
post #1545 of 4623 Old 08-16-2006, 03:47 PM
Mark Zimmer's Avatar
Why is it that some SD DVDs from smaller studios will upconvert over component at 1080i (a lot of Anchor Bay, most everything from MPI, for example)? What are they lacking that most other DVDs have in place to preclude that upconversion?
Not that I'm complaining, you understand. :)
Check out my DVD Reviews at http://www.digitallyobsessed.com
Mark Zimmer is offline
post #1546 of 4623 Old 08-16-2006, 03:54 PM
amirm's Avatar
Liked: 739
Basically, they are too small of a fish for someone to go after them. They can also hide under the provision for professional applications. This is how some companies use SDI digital video output without copy protection. So I would not publicize their names too much if you want them to stay around :).
So you won't find top brand names going this way.
I am with you :).
amirm is offline
post #1547 of 4623 Old 08-16-2006, 03:55 PM
amirm's Avatar
Liked: 739
Gary
As a practical matter, you are stuck with the choice made by whoever implements managed copy. This is not like selecting one of two audio formats in a player. Software needs to be written to securely convert AACS content to target DRM. And end users can't do this.
amirm is offline
post #1548 of 4623 Old 08-16-2006, 04:13 PM
dr1394's Avatar
Quoted: 108 Post(s)
Liked: 57
I am with you :).
Sorry Amir, but I contend that's not a good answer. It's actually very simple. These studios chose not to use CSS copy protection on their DVD's. In addition, almost all music/concert discs are unencrypted. It's a cost cutting measure.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is offline
post #1549 of 4623 Old 08-16-2006, 04:17 PM
amirm's Avatar
Liked: 739
Sorry Ron. I though he was saying some *players* have that option. I now realize he said some discs. You are right that if the disc is not using CSS, then the player can upsample if it wants.
amirm is offline
post #1550 of 4623 Old 08-16-2006, 05:14 PM
trbarry's Avatar
Anyone willing to say when the final AACS specification is likely to be approved?
I thought many things about managed copy were sort of speculation until that happened.
- Tom
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors?
Tom Barry - Find my video filters at www.trbarry.com
trbarry is offline
post #1551 of 4623 Old 08-16-2006, 05:20 PM
Topweasel's Avatar
This is the type of signal that really bothers me because its the people who are coping movies and therefore removing the copyright protection and being able to upconvert, where as a owner of said disc if they don't have HDMI or DVI is then stuck with 480p. Amirm, how long do think it will take studios to figure out that the problem with piracy has to do with the actual a copy of the disc itself and not the signal? Why didn't that go with something like the Protection on DVD players where if hooked to a recording device it would screw with the signal? I guess I am just frighten of piraters getting full use of the media, while owners of the media are still severely limited.
Topweasel is offline
post #1552 of 4623 Old 08-16-2006, 05:24 PM
amirm's Avatar
Liked: 739
People tend to not like technologies that "screw up" the signal as it can degrade the experience just the same for legitimate users. And the royalties for them can be high (both on content and players).
Anyway, we would need insiders from studios to answer your question which we don't have. I suggest if there is interest in discussion this topic, we create a seperate thread as I am sure the follow up responses will derail this thread :).
amirm is offline
post #1553 of 4623 Old 08-16-2006, 05:53 PM
Penton-Man's Avatar
Why? Did they think one sounds better than the other?
“Different strokes for different folks†:)
Penton-Man is offline
post #1554 of 4623 Old 08-16-2006, 05:55 PM
amirm's Avatar
Liked: 739
Let's hope they don't encode the same movie in all three video codecs in BD-25 for the same reason :).
amirm is offline
post #1555 of 4623 Old 08-16-2006, 06:06 PM
Penton-Man's Avatar
Come, come Amir, you know they're referring to utilizing the BD50 venue with this stuff.
I'm back on that 4hr. thread trying to catch up. :o
post #1556 of 4623 Old 08-16-2006, 06:25 PM
darinp2's Avatar
Quoted: 1129 Post(s)
Liked: 1765
Is Disney planning on featuring 3 lossless tracks for some of their titles(and I aint necessarily talking the kiddie movies)?
Interesting non-answer. Can you give a straight answer now? If you honestly want to claim that you don't know why studios put different language tracks on disks then somebody could explain that first.
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #1557 of 4623 Old 08-16-2006, 06:34 PM
amirm's Avatar
Liked: 739
I respectfully request that we keep this kind of tone out of this thread. And I was not giving answers but asking questions.
He said nothing about "different" langauge tracks. He said three lossless tracks. I assumed he meant PCM, DTS HD Master Audio and TrueHD. If he does mean different lanagues, then you should ask him more questions on it because he is the one with answers here, not me.
amirm is offline
post #1558 of 4623 Old 08-16-2006, 07:28 PM
dlb99's Avatar
Just re-pinging my question (in-case it slipped through the cracks). Don't worry I won't ask again.
To HD-DVD insiders,
Say I have a Home-theater PC. I set my nvidia HDMI card to 24Hz (yes this can be done). I set my software HD-DVD player to "ignore flags/detect-24p" mode.
I am now getting 24p from HD-DVD content into my Pioneer 24p capable plasma.
Excellent.
Question.
I now enable PiP which is 60i based. What will I see on my screen (note I am forcing my output to 24p)? I am curious.
Dennis.
dlb99 is offline
post #1559 of 4623 Old 08-16-2006, 07:36 PM
amirm's Avatar
Liked: 739
Dennis, saw your question first time :). Ironically, I have a Vaio BD laptop but not a Toshiba HD DVD! So can't test your scenario. I asked the guy who has one and he is on vacation for a week.
Just guessing for now, I would say the GPU in the laptop will frame rate convert it (i.e. the PiP video) to progressive. It does that today when you mix video and your desktop graphics. Note that our folks are running it at 72hz to get better compatibility with monitors out there. And that I don’t know what architecture the current software players use.
amirm is offline
post #1560 of 4623 Old 08-16-2006, 07:56 PM
dlb99's Avatar
Amir, that's cool.
When an answer is available can you post it in this thread, much appreciated.
Dennis.
dlb99 is offline
Closed Thread HDTV Software Media Discussion
