HD DVD movie data base software? - AVS Forum | Home Theater Discussions And Reviews
Old 02-02-2007, 12:31 AM - Thread Starter
Robert D's Avatar
I'm looking for some software to keep track of my HD DVD and DVD collection. It would be great if the program allowed for adding new fields and re-naming fields plus do Internet lookup for filling in the data. Any recommendations?
Robert D is offline
Old 02-02-2007, 05:42 AM
GJN
GJN's Avatar
DVD Profiler from Interactive (http://www.intervocative.com) works well for me. And the basic version with most capabilities is free.
GJN is offline
Old 02-02-2007, 06:22 AM
GDusty's Avatar
I like Ant movie profiler. It is also free, very customizable, and interacts well with Xlobby (which is a great free front end).
edit: "Ant movie catalog" is actual name.
GDusty is offline
Old 02-02-2007, 12:05 PM
csmith75's Avatar
My suggestions:
PC - DVD Profiler
Mac - Delicious Library
csmith75 is offline
Old 02-02-2007, 12:07 PM
dpags's Avatar
Movie Collector. Made even better if you know some XML/HTML for customization!
dpags is offline
Old 02-02-2007, 12:32 PM
miata's Avatar
Quoted: 65 Post(s)
DVDpedia - Do you know where your DVDs are? is another nice option for the mac that has integrated html export.
miata is offline
Old 06-19-2008, 06:52 PM
Wendell R. Breland's Avatar
Quoted: 288 Post(s)
Liked: 157
My vote is for Movie Collector as well.
Has anyone tried Movie Collector and the Centurion carousel or the Ziotek carousel device?
The CueCat barcode reader can be purchased on eBay for about $15.00 delivered!!
Wendell R. Breland is offline
Old 06-23-2008, 03:58 PM
Dennis1951's Avatar
Yes, here is how I store up to 1500 movies. I catalog them here:
Then store them here:
If I need more space, just add another stack. I can eject them through the computer or manually. Works great for me. Right now I use six for DVD's, 2 for HDDVD's & 2 for Blu-Ray.
I have used this setup since Xmas. It works great except for the occasional glitch of not recognizing a USB connection in WindowsXP, which is easily fixed.
Dennis
Dennis1951 is offline
Old 06-23-2008, 04:05 PM
Corellianrogue's Avatar
How much do those things cost and what's Darth Vader's eBay ID? Lol!
Stacy>>>>>>>>>>Fergie http://www.youtube.com/watch?v=ne0rqn_VAOE
Kids Incorporated (original members)>>>>>>>>>>Any band since! http://www.youtube.com/watch?v=0gbcgNhYC7M
Corellianrogue is offline
Old 06-23-2008, 04:10 PM
Dennis1951's Avatar
I paid $118.80 ea. from cyberguys. I believe that was with 10% off for signing up on their site.
Dennis
Old 06-23-2008, 04:30 PM
Cool. A bit expensive for me at the moment though.
Old 06-23-2008, 11:19 PM
Quoted: 288 Post(s)
Liked: 157
Thanks Dennis. I too use Movie Collectorz with a CueCat scanner. For space reasons I have been looking into storing via the carousel method.
BTW, that is an impressive array of carousels!
Old 06-23-2008, 11:37 PM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 46
Thanks Dennis1951. I learned something new from you today.
Blu-ray : 340
lgans316 is offline
Old 05-11-2009, 10:38 PM
threefirstnames's Avatar
www.getlibra.com
--kevin--
threefirstnames is offline
Old 05-12-2009, 12:46 PM
Everdog's Avatar
Quoted: 20 Post(s)
You can take it a step further and try this AVS touted app:
http://www.avsforum.com/avs-vb/showthread.php?t=1146273
Also go to the HTPC section and search on MediaPortal. HDD space is cheap!
Everdog is offline
Old 11-18-2011, 09:44 AM
maritimer555's Avatar
Hi Folks
I am looking for up to date information and reviews for software that would enable me to easily catalogue music and movies, concerts etc.
I have done a search of AVS and many of the treads (incl this one) are quite old.
A search of download.com etc shows me all my movies, collectorz, and a few others.
Is there a thread that i missed that's recent and might do a comparison and enable me to make an informed decision.
At this point i'm not 100% clear on what i want, except the basic ability to easily key in the meta data, maybe have imdb complete the entry and then be able to sort, print or export the info.
Any help would be appreciated.
Yamaha HTR-6063- receiver (or RX-V667)
Sony Bdp-s590
Panasonic VT60 65
maritimer555 is offline
Old 07-09-2012, 09:36 AM
dhodory's Avatar
Old thread, I know, but this space seems to be consolidating a bit - if based on nothing else other than which applications are continuing to be developed/improved. I recently installed and am using Delicious Library 2 for my iMac and have been very happy with it
dhodory is offline
