1080i vs. 1080p, any visible difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 03-01-2007, 12:33 AM - Thread Starter
Krout's Avatar
I'm wondering if there is any difference in picture quality between 1080i and 1080p in terms of HD-DVD/Blu-ray. And if there are differences, are they visibly apparent? Thanks for the help.
Krout is offline
post #2 of 33 Old 03-01-2007, 01:02 AM
Mr. Hanky's Avatar
Quoted: 80 Post(s)
Liked: 75
You have to specify for a film-based source or a video-based source, first. Otherwise, the answer could be yes or no, and both answers could be correct. Then once you get past that, there is a difference between theoretically and in-practice. Once again, the answer could be yes or no, and both answers could still be correct. How's that for an answer that takes you nowhere?
Margot Robbie is THE most exquisite human creature on the face of the planet, in this moment in time.
Mr. Hanky is offline
post #3 of 33 Old 03-01-2007, 01:17 AM
Star56's Avatar
Location: In my armed redoubt deep in the mountains of northern Ohio
Quoted: 107 Post(s)
Liked: 69
No.
These Links will answer your questions
http://blog.hometheatermag.com/geoff...061080iv1080p/
http://gizmodo.com/gadgets/home-ente...ork-160103.php
42" in the dining room.50" in the bedroom 80" in the living room 65" in the family room 70" in the family room 106" in the family room "There is another system" Video Modes: SDTV-EDTV-XGA-HDTV-4K
Star56 is offline
post #4 of 33 Old 03-01-2007, 05:43 PM
Spektricide's Avatar
Most everyone on this forum will tell you.
720P looks better than 1080i.
1080i=1080p virtually unnoticeable
THEREFORE.....
720P looks better than 1080p............
I'm sure anyone can see the issue here..
Spektricide is offline
post #5 of 33 Old 03-01-2007, 05:46 PM
vurbano's Avatar
I doubt that. For a still image 1080i blows 720p away. 720p's advantage is its progressive nature in motion scenes. Once you apply progressive scan to 1080i you get something that is not only sharper than 720p during stills but also has all of its advantages during fast motion.
vurbano is offline
post #6 of 33 Old 03-01-2007, 07:31 PM
HPforMe's Avatar
THEREFORE.....
I read sarcasm...
HPforMe is offline
post #7 of 33 Old 03-01-2007, 10:27 PM
dwisniski's Avatar
I'm one person on this forum who will disagree with this statement. To my eyes and on my display (HD DVD + Blu-ray, Panny AE900u) 1080i most definitely looks better than 720p. But to each his own...
dwisniski is offline
post #8 of 33 Old 03-02-2007, 05:04 AM
I personally don't have a 720o/1080i source to judge on other than OTA broadcast signals so I can't dispute or verify the 720p > 1080i claim. However, it doesn't take much of a math genius to know that 1080p > 720p.
I think a lot of people try to explain 1080p as being equal to 1080i want to rationalize themselves into not owning another TV.
It's kinda like the people who talk about getting 1:1 pixel mapping on their 720p TV for Blu-Ray and HD-DVD sources. It's all encoded in 1080p so your never getting a 1:1 pixel map to the source. So even if your TV does 1:1 pixel mapping, the signal is still getting scaled at the player.
post #9 of 33 Old 03-02-2007, 05:12 AM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
1080i and 1080p are virtually indistinguishable on a 1080p TV using a 1080p source. In terms of the player outputting 1080i you won't see a difference being that the source is 1080p. However if you were saying that a 1080i source and a 1080p source are indistinguishable then I would have to cry foul.
wormraper is online now
post #10 of 33 Old 03-02-2007, 10:17 AM
Sketcha's Avatar
Originally Posted by HPforMe View Post
I read sarcasm...
Max your volume and click...
http://youtube.com/watch?v=tWWHi7aYTyU
Sketcha is offline
post #11 of 33 Old 03-02-2007, 10:25 AM
Sketcha's Avatar
So...
Given a 1080p source (software w/capable player) and display with 1080p input capability....
1. Set the player to 1080i and let the display deinterlace.
2. Set the player to 1080p.
Can you see a difference?
My guess is, unless you have a very capable deinterlacer in your display, you might see the difference.
Seems like why introduce another link into the digital chain?
But in practice, I don't know... So I'm askin'.
Sketcha is offline
post #12 of 33 Old 03-02-2007, 10:29 AM
PeterS's Avatar
Quoted: 124 Post(s)
Liked: 41
This is simple - I don't see why this issue keeps coming up.
First - Almost EVERYONE misses the point. Are you talking about TRANSMISSION or DISPLAY??? These are two different issues.
Second - ALL digital displays which are 1080 are 1080p at the panels - regardless of the input limitations (if they only take in 1080i). 1080i in display technology is limited to scanning rasters - or CRT-based systems. There is no 1080i digital display.
Third - in TRANSMISSION, you can send the signal as either 1080i or 1080p (or 1080psf - which is getting too complicated). The issue is what then hits the panel.
The difference between (i) and (p) is wether or not the signal comes from two different moments in time (i) or one (p). However, if the difference in time is not relevant (such as in film where the actual source rate (24fps) is lower than the display rate 30 or 60fps, then there is no difference in 1080i vs. 1080p from a TRANSMISSION/SOURCE perspective.
Note - from video sources, the issue of (i) can make a greater difference as the two fields are offset in time from each other, and the field rate is equal to the display rate.
In Film however, if you look at it properly, I am either scanning and transmitting the film as:
(Progressive)
Line 1
Line 2
Line 3
Line 4
or (Interlaced)
Line 1
Line 3
(all odd lines)
Line 2
Line 4
(all even lines)
However, so long as the deinterlacing circuits putting the signal back together work as they should (and this is one of the easist tasks for them to perform), then when the image hits your screen, it should be
Line 1
Line 2
Line 3
Line 4
Regardless of how they were sent.
So, the long and short of it is, so long as your deinterlacer (built into the set) is working properly, then NO there should be no difference at all.
"Read Less, More TV." - Dr. Gregory House
"That which can not be questioned, can not be trusted." - Me
The Metropolis Home Theater
Blue Smoke Entertainment Systems - Affiliated
PeterS is offline
post #13 of 33 Old 03-02-2007, 02:21 PM
Sketcha's Avatar
Originally Posted by Sketcha View Post
So...
PeterS answered a few of my questions in PM. With his permission, I am posting them here, for reference.
If you can go TRUE 1080p from source to display, than this is of course best.
However, most, if not all, 1080p sources ARE NOT TRUE 1080p. Since there is no broadcast or recording standard for 1080p, almost all of the 1080p output sources you see - such as BluRay, actually, internally deinterlace a 1080i signal and send it out 1080p. This is fine if the 1080p in your player is better than the one in your display, but this is RARELY the case (a notable exception it the deinterlacer in the Toshiba HD-XA2 player).
In general, you will find that the deiniterlacer in your display is better - and better tuned to the specifics of your display - of which it has intimate knowledge.
Remember, the key here is that there are really no 1080p native sources on the market.
Both HD-DVD and BluRay are ENCODED on the disc as 24p - however, so far, only the Pioneer can actually output the 24p encode. All the rest must reinterlace to do 1080p60.
Sketcha is offline
post #14 of 33 Old 03-02-2007, 06:42 PM
TheLion's Avatar
How about this excellent thread for a start:
http://www.avsforum.com/avs-vb/showthread.php?t=808958
TheLion is offline
post #15 of 33 Old 03-13-2007, 12:08 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
You are 100% wrong. And you're also right, but it REALLY depends. My 1080p LCD does NOT deinterlace, so 1080i has nasty artifacting occasionally (moire, aliasing etc), whereas 1080p is clean as a whistle. I could point out 1080i vs 1080p every time (Samsung LN-S4695D).
So, if your 1080p display does NOT deinterlace, you want to feed it 1080p as much as possible.
WilliamG is offline
post #16 of 33 Old 03-13-2007, 12:47 PM
Sketcha's Avatar
Originally Posted by WilliamG View Post
My 1080p LCD does NOT deinterlace.
I've never heard of such a thing. How does an HDTV signal look?
Sketcha is offline
post #17 of 33 Old 03-13-2007, 01:05 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
Pretty good, though I'm going on a friend of mine's 1080i experience because I don't have any HDTV hookup whatsoever. I just use my TV for DVDs, video games, HTPC, Blu-ray and HD-DVD.
But yep, I can tell the difference between 1080i and 1080p. There are some scenes in Mission Impossible 3 HD-DVD that show significant moire and aliasing in 1080i on my XBOX 360 HD-DVD drive AND my Toshiba HD-A2 (both outputting 1080i), and via my HTPC at 1080p there are no issues at all. I can also see the difference on my PS3 when I switch the dashboard from 1080p to 1080i.
Also, PS2 games look like total ass on this set because 480i is not being deinterlaced. This causes all kinds of graphical issues - vertical bars in FMV sequences, etc. Just nasty. Never had any of these problems on my old plasma.
But yep, my set is not a good set for 1080i, or any interlaced signal.
WilliamG is offline
post #18 of 33 Old 03-13-2007, 01:07 PM
Slim GoodBooty's Avatar
What is the model of this mystery display?
Slim GoodBooty is offline
post #19 of 33 Old 03-13-2007, 01:10 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
You just quoted me, and the model.
Samsung LN-S4695D, which is a 46" 1080p LCD. Great TV (absolutely love it), but boy does it blow with interlaced sources.
WilliamG is offline
post #20 of 33 Old 03-13-2007, 01:12 PM
Damn, I guess I blew that.
Why do you believe that it doesn't deinterlace?
post #21 of 33 Old 03-13-2007, 01:20 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
I can see with my own eyes, and also the HDTV Guru (I think that was his name) said the TV failed all deinterlacing tests, as I recall. Someone here will know what I'm talking about.
WilliamG is offline
post #22 of 33 Old 03-13-2007, 01:25 PM
Super Moderator
markrubin's Avatar
Quoted: 1037 Post(s)
Liked: 2273
Gary Merson did a series of articles about this: basically many displays dropped half of the resolution in deinterlacing some signals
However newer displays using newer processors do better
Most of his tests are dated now
If I can find the threads, I will post a link (I had started one in the LCD & Plasma forum a year ago)
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #23 of 33 Old 03-13-2007, 01:32 PM
That just means it sucks at it. The reason why it failed is because it was deinterlacing poorly.
post #24 of 33 Old 03-13-2007, 01:36 PM
WilliamG's Avatar
Quoted: 303 Post(s)
Liked: 172
However you want to put it, basically, I can see the difference between 1080i and 1080p, and you better believe that if this relatively nice Samsung looks craptastic at 1080i, other TVs will too. THEREFORE, 1080i vs 1080p is not a simple question.
WilliamG is offline
post #25 of 33 Old 03-13-2007, 01:53 PM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 103
Here's a post with three links to Merson's evaluations. -- John
John Mason is online now
post #26 of 33 Old 03-13-2007, 02:07 PM
schticker's Avatar
All this effort and expense to get a picture that actually rivals a calibrated CRT.
The First Clarke Law states, 'If an elderly but distinguished scientist says that something is possible he is almost certainly right, but if he says that it is impossible he is very probably wrong.'
schticker is offline
post #27 of 33 Old 03-13-2007, 02:39 PM
abr27440's Avatar
Why cant people understand the difference between 1080i transmission of 1080p source, and true 1080i source?
abr27440 is offline
post #28 of 33 Old 04-01-2014, 12:20 AM
Sabidox's Avatar
to cut this short and based on a personal experience...yes 1080p looks better, its smoother and sharper than 1080i , i kept on switching between signals on my 4k TV using a handy cam and  i can tell 1080p looks better.
the reason i am reading all these threads about 1080p and 1080i is because i might be wrong (maybe its only me or my brain telling me 1080p is better), i wanted to verify from somebody else but unfortunately i didn't find a decisive answer all tons of blab-la so i think i am going to trust my instinct on this.
Sony XBR-65X9004A 4K - Toshiba Qosmio i7 - PS3 - PS4 - Sony BDV-E6100 Home Theater - Sony Xperia Z1-Sony HDR GW 77v -  IPad Air - IPad Mini Retina - Macbook Pro Retina - Iphone 5S  - Lenovo Idea Pad S - Dre Beats Studio - Dre Beats Pill
Sabidox is offline
post #29 of 33 Old 04-01-2014, 06:03 AM
Joe Bloggs's Avatar
Quoted: 433 Post(s)
Liked: 118
You don't mention frame rate. Interlaced shot content has twice the number of samples taken per second. So 1080p24 has 24 pictures per second, 1080p25 has 25 pictures per second, and interlaced 1080i25 (50i) has 50 pictures per second. So when, at the same frame rate, interlaced has twice as many pictures of the scene taken per second, why do you say progressive is smoother? If you're using progressive at 60 fps that will look just as smooth as 60i, and should look better, depending on bitrate. But you need to say more about the content type and frame rate. On Blu-ray, 1080p24 is the only full HD progressive format currently, which will give a lot less smooth motion than 1080i25 (50i) or 1080i30 (60i).
Joe Bloggs is offline
post #30 of 33 Old 04-02-2014, 12:24 AM
RLBURNSIDE's Avatar
Quoted: 1540 Post(s)
Liked: 1218
Interlaced is sending 1/2 the vertical resolution on each frame (odd lines) and reconstructing full frames prior to display. It is really that simple. Effectively it means a 1080i 60hz interlaced signal is only effectively showing you the equivalent 1080p / 30 at most. Probably actually 24p, which means you get the full 1080p/24 in a broadcast signal, but the cadence is off and it's up to the TV or set top box to make it progressive again and do the pulldown from 30hz to 24hz. (if at all. cadence can be changed prior to broadcast at the source).
As others have written here, all LCDs and plasmas and so on display progressive scan. Interlaced signals take 2 frames to make 1 final one.
RLBURNSIDE is online now
Reply HDTV Software Media Discussion
