Industry Insiders Master Q&A thread III: ONLY Questions to Insiders - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Closed Thread
post #91 of 3651 Old 05-28-2007, 08:59 PM
PARASITE's Avatar
Paidgeek any news on when sony is gonna fix the rgb full bug?
Surely its been passed on to them now.
PARASITE is offline
post #92 of 3651 Old 05-28-2007, 10:06 PM
paidgeek's Avatar
Originally Posted by Jack-Bauer-24 View Post
Hi paidgeek,
Sony has been releasing blu rays pretty consistently every month, but I wonder is this the pace they prefer? What I mean is come autumn will they start pumping out more catalog releases like Universal or continue with the current rate of release?
There will be a couple of months before the end of the year with many more titles released than usual.
Sony Pictures BD Insider
paidgeek is offline
post #93 of 3651 Old 05-28-2007, 10:07 PM
paidgeek's Avatar
It has been discussed, but I don't have a schedule for a new firmware release.
paidgeek is offline
post #94 of 3651 Old 05-28-2007, 10:21 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
Originally Posted by hellokeith View Post
TrueHD & WMA Lossless insiders,
I was speaking with an audio encoding programmer, and he said it was quite difficult to compare channels and losslessly extract identical information. For example, taking L & R and losslessly redirecting only the indentical material to the Center channel. Or when comparing back-left to back-right, or side-left to side-right.
Is this actually difficult? Could someone give me a little more detail on the process and difficulties/shortcomings? I would assume extracting identical material from stereo pairs would be one of the primary methods for lossless compression.
MLP and TrueHD use a lossless matrix technique. It's what enables lossless reconstruction of 5.1 audio from the delivered substreams containing a stereo downmix plus 3.1-ch extensions, for example. It's not particularly difficult, but does require care in design to ensure lossless operation.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #95 of 3651 Old 05-28-2007, 10:24 PM
Liked: 711
Originally Posted by vancouver View Post
Would anyone be able to answer this for me?
Does DPLIIx process 5.1 Dolby Digital Plus or 5.1 TrueHD into 7.1? Or Can DPLIIx process 5.1 Lossless 24 bit PCM into 7.1?
thanks
Yes, PLIIx, technologically, can do all of the above, up to 192 kHz. Whether a specific product can do it depends on it's design choices and DSP resources.
post #96 of 3651 Old 05-28-2007, 10:28 PM
Liked: 711
great. So lossless should stay lossless even though PLIIx makes it 7.1?
Nope. Any process that alters the data is, by definition, not lossless. Bass management, channel balance, D-A conversion, PLIIx, none of it is lossless. That is not to say the quality is degraded necessarily. Done right, DSP processing is well able to preserve all the quality of the source.
post #97 of 3651 Old 05-29-2007, 12:55 AM
Paul Cordingley's Avatar
Now that's taking things to extremes, isn't it? I would call that pedantic!
Cheers,
Paul Cordingley
Paul Cordingley is online now
post #98 of 3651 Old 05-29-2007, 01:19 AM
Krobar's Avatar
Quoted: 17 Post(s)
Hi Roger,
I was just thinking, older amps could decode MLP passed over ILink. Is the only real difference between TrueHD and DVD-A the higher bit rates and availability of higher multichannel sampling rates? If a modern receiver is receiving a bitstream of DVD-A or TrueHD over HDMI 1.3, can it tell the difference?
Krobar is offline
post #99 of 3651 Old 05-29-2007, 02:54 AM
zambelli's Avatar
Originally Posted by vairulez View Post
ATI is claiming VC1 full hardware decoding support for its 2400 and 2600 to be released in july. How is it possible?
Support, yes. But with which decoder? With what player software? The devil is in the details. Microsoft's WMV9/VC-1 decoder currently in Vista will only go up to Profile C which isn't full hardware decoding (that's Profile D). But nothing is to prevent ATI from adding Profile D support and testing (or even shipping) with a completely different VC-1 decoder. DXVA is a public API so it's not like they are required to only work with Microsoft's decoder.
Originally Posted by madshi View Post
I'm usually converting all my movies to MKV - including my HD-DVDs. And as far as I can see, VC-1 in MKV through the MS decoder works just fine for me. What problems could I expect due to the missing ASF metadata?
In that scenario, there's a good chance the Vista WMV decoder will fail to identify non-square pixel video and interlaced video as such before passing it on to the renderer. As a result, deinterlacing and square-pixel resizing won't happen in the renderer. The decoder currently relies on ASF Data Unit Extensions to retrieve this information, though it might pass it on from the upstream filter (i.e. Haali splitter) if the information is present there. It's really an untested scenario since, like I mentioned, we shipped it as a Windows Media decoder meant to work primarily in a Windows Media environment. The fact that it works fairly well with VC-1 streams in EVO, MKV, AVI, MPEG-TS and whatnot is a nice bonus - but not something that we intentionally targetted.
P.S: Well, there's one problem: I get good playback only if I set the graphics card to 59.94Hz. With 23.976Hz, the VC-1 video is stuttering quite badly (and yes, of course the video is marked as 1080p23.976 in the MKV container). Don't have this problem with any other codec. Could that have to do with the missing ASF metadata?
First of all, who's to guarantee that the tool which extracted the VC-1 elementary stream from the EVO and stuffed it into the MKV container correctly translated the timestamps? They could've just been guessed assuming a fixed frame interval (i.e. 1/24 = 41.67 msec). It's hard to say once it's done. The error could've been introduced in the parsing/muxing step.
That said... Your video card outputs 23.976 Hz? Do you have a display which works at 48 Hz or 72 Hz? Most digital displays refresh at 60 Hz.
zambelli is offline
post #100 of 3651 Old 05-29-2007, 03:10 AM
1031982's Avatar
To any insider who works on the HD-DVD add-on,
When using the VGA cable with the 360 on a computer monitor, is the picture being displayed at 24FPS or 30FPS?
HD DVD - 13
Blu-Ray - 88
1031982 is offline
post #101 of 3651 Old 05-29-2007, 04:59 AM
teknoguy's Avatar
You're not missing anything. Just remember that relatively few AVRs can apply bass management to the analog inputs. They need 6 A-D converters to do that.
Roger,
Very interesting discussion wrt Bass Management, but I need to ask a question...
I get the feeling from what you've written that Bass Management is non-existent with analog signals. Say from a CD and/or Phono stereo outputs ?
-t
teknoguy is offline
post #102 of 3651 Old 05-29-2007, 06:39 AM
momaw's Avatar
Sir Paidgeek
Any chance of The Emperor and the Assassin on BD?
Thankyou
momaw is offline
post #103 of 3651 Old 05-29-2007, 08:51 AM
PARASITE's Avatar
thanks for looking into this. So even tho you dont know when a fix is coming, is it safe to say that a fix will be in the next firmware update?
PARASITE is offline
post #104 of 3651 Old 05-29-2007, 09:02 AM
paidgeek's Avatar
Originally Posted by momaw View Post
Sir Paidgeek
Thankyou
It is not on the current schedule. I'll see what I can find out about it.
paidgeek is offline
post #105 of 3651 Old 05-29-2007, 09:04 AM
paidgeek's Avatar
To the best of my knowledge, yes.
paidgeek is offline
post #106 of 3651 Old 05-29-2007, 09:13 AM
Ian_S's Avatar
Any news from anyone as to when we can expect to see 50Hz playback on either HD-DVD or BD players? Will it also be able to do 25p playback seeing as some cameras are now recording in such modes?
Ian_S is offline
post #107 of 3651 Old 05-29-2007, 09:39 AM
Robert George's Avatar
Location: Trapped in time. Surrounded by evil. Low on gas.
To Paidgeek:
Despite my reputation with some here, I firmly believe in giving credit where due. That said, my compliments to the Playstation team, both in general and particularly on the new 1.8 firmware update. My feeling is, a remarkable piece of technology has been made even better. I enjoy mine immensly, and expect to continue enjoying it for a long time. I'm looking forward to viewing many of my favorite movies on Blu-ray disc on this terrific MEDIA HUB.
You can forward my apologies to Chris Walker at Pioneer as I no longer need his new BD player .
Robert George is offline
post #108 of 3651 Old 05-29-2007, 10:08 AM
PARASITE's Avatar
Thanks again for tending to this matter. Your willingness and commitment to us on this forum is greatly appreciated. I for one cant wait to have full rgb on 1080p movies.
PARASITE is offline
post #109 of 3651 Old 05-29-2007, 10:21 AM
DaViD Boulet's Avatar
Liked: 41
I listened to the extended and theatrical mixes for "Step Into the Bad Side" on HD DVD, on an XA2 decoding the DD+ to PCM and feeding into an Anthem D2...
Besides the level difference (around 2-3db, the extended scenes being louder ) and the bump in the sub track on the extended versions, I don't hear the differences as being dramatic. The extended versions sound compressed to me, with the theatrical sounding more airy, and less smashed (listen to the high hat on Bad Side on the right side, it's got a little more hash on the extended version)... however, I was reaching to hear this difference, and it's impossible to know if it's the placebo effect since you have to go to the main menu to switch, and you are at least 20-40 seconds away everytime you switch and get back to the same scene.
In my professional opinion, and speculation, I suspect that the extended scenes were mixed for home video using near fields, and the mixer would've made some compromises knowing that the new extensions would only be heard in the home environment, and also might have been hearing the effects of bass redirection and adjusted accordingly....
I'll ask the mixer sometime this week if I can get a hold of him.... but I have to say I disagree with your assessment that the tracks are miles apart.
I know my Anthem has a display for the dialog norm setting, but since I am using the HD DVD and PCM for this, it does me no good
Filmmixer,
much-appreciated. I'll listen again to make sure I'm not hearing the "improvement" of a more compressed sound which might simply sound more rhobust and temp my ears to perceive a benefit of some kind.
Roger,
thanks for you input on that perspective. I share the same philosophy (ie, that "lossless" means "bit for bit output" and not just "avoided psychoacoustic modeling").
Question: wouldn't that then mean that any Dolby TrueHD stream with a dialog normalization flag setting to anything other than minimum (off) mean that the Dolby Decoder isn't capable of delivering "lossless" performance from a Dolby TrueHD stream with DN? Since data-recalculation is required to adjust the level of the waveform, it would seem to fall into the same category as the DSP items you listed above.
Note: this confession isn't intended as an admittence to degraded audio quality: merely to apply consistently the principle of "lossless" playback to what's delivered from the output of the Dolby decoding engine.
1080p and lossless audio. EVERY BD should have them both.
DaViD Boulet is offline
post #110 of 3651 Old 05-29-2007, 11:09 AM
TheLion's Avatar
Dear paidgeek,
first of all let me say thank you and congratulations on the latest PS3 firmware update. This full featured update including 24p support was propably the most pleasant surprise I have ever enjoyed with any of my AV gear. Kudos to your mother company.
Now DTS-HD MA decoding is the only thing left to long for...
Now on to my question: I, as well as many others, have a serious issue with the 24p support as it is implemented in the PS3. If I connect the PS3 directly to my 1080p/24 capable front projector (Sharp Z20000 1080p DLP, latest firmware) the 24p output works like a charm - my projector displays it @ 48HZ and the 3:2 pulldown judder is finally an annoyance of the past.
BUT when I use my receiver (Yamaha RX-V1700) as HDMI hub in order to get sound output (which comes in quite handy...) there seems to be just another odd HDMI handshaking problem. The PS3 (with the 24p option set to "Auto") suddenly doesn't recognize the availability of an 24p capable display unit anymore and all I get is mere 60Hz output. The only solution I can think of right now is to buy an $$ HDMI splitter that magically allows for correct 24p HDMI handshaking.
This problem is surely not isolated to the Yamaha lineup of receivers and is a real issue for many, many users out there. Sadly just a few selected receivers allow for correct 24p handshaking. Even Sony's own lineup of HDMI recievers doesn't support the PS3 24p feature btw...
The problem is not the 1080p/24 signal passthrough (this is supported by just about any recent HDMI hub/receiver) BUT the handshaking.
Solution: If the PS3 would allow for a "native/DIRECT/forced 24p" option in addition to the auto setting this problem would not exist. This forced setting would avoid the 24p handshake and just output 1080p/24 whenever the source is accordant.
Please make this serious issue known and considered by those responsible for PS3 firmware updates.
Some threads discussing the issue:
http://www.avsforum.com/avs-vb/showthread.php?t=851667
http://www.avsforum.com/avs-vb/showthread.php?t=851797
Thank you very much for your time and consideration!
TheLion is offline
post #111 of 3651 Old 05-29-2007, 01:53 PM
cwichura's Avatar
A question to anyone on the 360's HD-DVD add-on team:
Right now, if you go to the system blade on the 360 and select the memory option and then pick the HD-DVD add-on, all the files stored there are named "Unknown Title". Thus, it is impossible to know which file is for which movie. Surely HD-DVDs must have some textual identifier in the header metadata that could allow these files to have a meaningful name?
Would it be possible for a future update to the player to give these files names based on the title (even if its just a catalog number rather than the movie title itself)? Or does the HD-DVD authoring specification somehow prohibit this?
cwichura is offline
post #112 of 3651 Old 05-29-2007, 01:54 PM
wickedbob's Avatar
Thanks to whoever made the free Matrix HD clips, trailers and Animatrix episode on xbox live available to the global audience. The image quality is stunning - detail and color saturation is spot-on - and I can't wait for my hd-dvd set to arrive.
Obviously this release will make hd-dvd a more favorable option for many consumers (I can imagine waiting six months for a movie trilogy on bluray leaves a bad taste in people's mouths).
How many units of the recent Matrix release have been sold so far?
Is there an organization or website which tracks overall sales for HD media and makes it available to the general public?
wickedbob is offline
post #113 of 3651 Old 05-29-2007, 06:59 PM
darinp2's Avatar
Quoted: 1129 Post(s)
Liked: 1765
paidgeek,
I saw on thedigitalbits that Sony is expected to release The Lives of Others (Das Leben der Anderen) on DVD in August. Any chance of a Blu-ray release? I hadn't heard of this movie and didn't realize that it had been reviewed so well (95% thumbs up on rottentomatoes.com and currently #74 all time on imdb.com).
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #114 of 3651 Old 05-29-2007, 07:19 PM
MarkH's Avatar
Paidgeek: Any comments on whether a "fix" is in the works? I would imagine so as even the current Sony amps seem to suffer the same issue.
MY THEATRE ROOM, LIVING ROOM and BEDROOM SYSTEMS THREAD
http://www.avsforum.com/avs-vb/showthread.php?t=1105927
MarkH is offline
post #115 of 3651 Old 05-29-2007, 09:17 PM
Liked: 711
This is a technical forum for the extreme of heart. If there is some groundswell that the definition of lossless should be expanded to include any processing at all except low bitrate compression, I guess we could entertain that.
post #116 of 3651 Old 05-29-2007, 09:21 PM
Liked: 711
Originally Posted by Krobar View Post
Hi Roger,
There are no products that output the MLP stream. It was always decoded first. So, yes, the PCM from MLP looks no different from the PCM from TrueHD. It will probably be a while before the 96/24 x6 ch limits of MLP are exceeded by HD DVD programs.
post #117 of 3651 Old 05-29-2007, 09:23 PM
Liked: 711
Originally Posted by teknoguy View Post
Roger,
-t
That depends entirely on the AV processor. There are some that can apply bass management to 2-ch signals. It may be the majority. It costs nothing to do so.
post #118 of 3651 Old 05-29-2007, 09:31 PM
Liked: 711
Originally Posted by DaViD Boulet View Post
Roger,
The job of the lossless codec is to deliver the same bits that it encoded. It does that regardless of what follows, be it room EQ, mixing, dialnorm, PLIIx, or myriad other things. Dialnorm is a post-process, after lossles decoding is finished.
In my post, I was careful to note that while, speaking as a pedant, one cannot claim a signal is lossless once the data is changed, the sonic performance need not be impaired at all. So it is still fair to say the lossless performance (meaning what is heard) is still preserved even though subsequent to lossless decoding, the audio is modified. As you yourself have pointed out, the sonic subtleties of PCM sources come through with PLII decoding applied.
post #119 of 3651 Old 05-29-2007, 10:50 PM
rover2002's Avatar
Hi Amir,
When can we expect to see a remote hack to enable multi-region SD-DVD playback in Tosh units? I recall last year a Tosh rep in Europe claim there E1 units would have region free SD-DVD playback at some point. I know you can't give dates as such so maybe a quick yes or no its possible or not this side of 07?
Will
rover2002 is offline
post #120 of 3651 Old 05-30-2007, 01:46 AM
SquirrelPhister's Avatar
I don't know if anyone here can shed light on this, but I just read about this product on Kotaku.com that bypasses HDCP encryption for transmission to non-HDCP compliant monitors. Here's the link:
http://kotaku.com/gaming/hack/strip-...ion-264264.php
It's called the 'GameSwitch' and it says 'Play PS3 on DVI monitor' on the side of it. Would this really make it possible to transmit an unencrypted video signal that could be easily copied with the right equipment? AACS and BD+ don't come into play at this point in the chain do they?
Post-Production/Technical Guru for DTV production company
Film Collection -------- DVD: 181 ------------------ HD DVD: 19
TV Show Collection --- DVD: 24 (48 seasons) ---- HD DVD: 2
SquirrelPhister is offline
Closed Thread HDTV Software Media Discussion
