Blood Diamond+Toshiba HD-E1 KE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-17-2007, 06:46 AM - Thread Starter
new_in_hd's Avatar
I have updated my firmware today of my Toshiba HD-E1 hd-dvd player, and then I tried Blood Diamond for the first time.
When I went to use the internet features, I instantly get a message saying there was a problem, quoting an error number of 'f003' and suggesting I go to www.hddvdadvice.com.
Than it gest very annoying, because this site doesn't exist. How is it possible that disk which is sold in UK doesn't play on the player which is also sold in UK?
I hope that it is only problem with my setup (network).
Any suggestions?
new_in_hd is offline
post #2 of 3 Old 07-17-2007, 06:59 AM
Jiffylush's Avatar
Any suggestions?
My first suggestion would be to call the player manufacturer's tech support.
Are you able to update the player over the internet with no issues?
You may want to see if anyone in the HD DVD section is having a similar problem.
Jiffylush is offline
post #3 of 3 Old 07-17-2007, 07:33 AM - Thread Starter
new_in_hd's Avatar
I've spent more time and I've just fixed the problem.
I went to settings and start persistent storage.
That should be described in small manual which comes with disc.
It works fine, now.
Reply HDTV Software Media Discussion
