Any Dual Format Supporters With Non HDMI Receivers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-08-2007, 09:21 PM - Thread Starter
ILJG's Avatar
Any of you sending in multiple sets of 5.1 analog cables? How are you doing it if your receiver only has one set of 5.1 inputs? Via a switch? Does all that extra cabling cause any interference?
Still looking for a movie theatre that shows movies the way they're SUPPOSED to be viewed...
...with a bitrate meter and screencaps.
ILJG is offline
post #2 of 7 Old 08-08-2007, 11:16 PM
rdjam's Avatar
I used analog for a brief while, but mostly used the SPDIF before I got my HDMI AVR. At the time, the A1 wasn't decoding 5.1 TruHD, so I wasn't losing anything.
In general, you should be reasonably careful where you run analog cables to ensure that you don't pick up interference, and you should run your gear from the same sources to avoid ground loop issues.
Other sections of the AVS Forum might be a better place to get help on setting up analog connects, tho.
rdjam is offline
post #3 of 7 Old 08-09-2007, 05:31 AM
Beastus's Avatar
I had my HD DVD player connected with 5.1 analog cables. When I got my Blu-ray player, I just moved those to that, and has connected my HD DVD player with a coaxial cable for now. I have a new receiver on it's way, so it's only temporary. But before I bought the receiver, I was thinking about getting some kind of switcher for the analog cables.
Beastus is offline
post #4 of 7 Old 08-09-2007, 10:42 AM
djsmokyc's Avatar
There is a thread on the Dual-Format Players category about this.
http://www.avsforum.com/avs-vb/showthread.php?t=865576
There is discussion about using switches, but there isn't a good solution mentioned.
For my setup, I just hook up my PS3 using optical to my non-HDMI receiver.
djsmokyc is offline
post #5 of 7 Old 08-09-2007, 11:34 AM - Thread Starter
ILJG's Avatar
Ah, it feels like the AVS of old, here. Question asked, question answered... and by multiple helpful people.
*sniff*
Thanks for the help, guys!
ILJG is offline
post #6 of 7 Old 08-09-2007, 12:35 PM
BGLeduc's Avatar
Quoted: 1477 Post(s)
Liked: 1320
I have shared multiple analog 5.1 sources before, and used two A/V switches to do it. A bit of a PITA, and it looks like a kludge, although it worked fine.
But today, I placed an order for the Zektor 4 to 1 component switch, to be used for 5.1 analog audio duties. It should be much more user friendly, since it can be programmed to resond to any key on my universal remote.
Pricey to be sure, but it appears to be of very high quality.
Brian
#JB17
BGLeduc is online now
post #7 of 7 Old 08-10-2007, 08:14 AM
ComputerCowboy's Avatar
Check my attached diagram. Switching is a pain but it is the best I can do on my budget.
ComputerCowboy is offline
Reply HDTV Software Media Discussion
