HDM Rumor thread! Put all rumors here. - Page 25 - AVS Forum | Home Theater Discussions And Reviews
Old 09-11-2007, 11:25 AM
dobyblue's Avatar
In not so good Blu-ray news, Batman Begins from Warner has been pushed back to May/June release to coincide with The Dark Knight theatrical window.
TDK is opening July 18th.
For Warner it is not a delay of the title as it has never officially been given a date.
This has nothing to do with IME, simply the timing makes more sense for Warner with all the other titles already scheduled for Q4/07.
Terminator 3 looks very likely to have PCM and TrueHD on the Blu-ray release and is currently planned for Q4/07
dobyblue is offline
Old 09-11-2007, 12:22 PM
scaesare's Avatar
Was there some discussion if bandwidth there that I missed?
That's what I'm asking about.
-Steve
scaesare is offline
Old 09-11-2007, 12:28 PM
Lee Stewart's Avatar
Liked: 51
No - bandwidth is a total unknown. We do not know if it will increase or stay the same - at least it has not been announced.
Lee Stewart is offline
Old 09-11-2007, 12:33 PM
scaesare's Avatar
Originally Posted by pteittinen View Post
All video (including PiP), audio and subtitles are muxed (multiplexed) into one data stream. In other words, all video, audio and subtitles are read into player's memory simultaneously, even though only the ones chosen by the user are displayed/played. The bitrate limit for this data stream is 30 megabits per second.
Some see this as a problem with the HD DVD format, since the maximum bitrate allowed by Blu-ray is quite a ways higher.
Imagine a situation where the HD DVD title contains several audio tracks and PiP feature for In-Movie Experience/U-Control. Subtitles are not really an issue because their bitrate requirements are rather insignificant. For example:
Audio1: Dolby Digital Plus @ 640kbps CBR (constant bitrate)
Audio2: Dolby TrueHD @ VBR (variable bitrate), bitrate depends on content, let's assume 100kbps-3500kbps
PiP: averaging 1Mbit (a guess on my part)
For example's sake, let's assume that during an intense action scene TrueHD track is clocking in at 3500kbps. In those scenes audio+PiP are already hogging more than 5Mbps of the 30Mbps maximum, leaving less than 25Mbps for video encode peaks. The more audio tracks you add, the less bandwidth there's available for video's bitrate peaks.
During "quieter" scenes there's more room for higher video peaks, naturally.
Hope this explanation helped.
The logic behind all of this is correct.
However with current tools, all track bandwidth allocations are made statically. After the individual tracks are encoeded (video, audio, PiP, etc...) they are then multiplexed (aka "mux'ed") into to a single stream.
What this means is that even though DD+, or the PiP video, may not be at peak bitrate, the space "carved out" of the overall bandwidth budget is the peak value. So if your audio stream hit's 1.5Mbps only ONCE in the move, you have to carve out 1.5 for the WHOLE movie.
It's anticiapted that a tool upgrade will bring dynamic allocation capability to the multiplexor. "Dynamux"!
-Steve
scaesare is offline
Old 09-11-2007, 12:43 PM
IRockSoAwesome's Avatar
Can I ask where you got this info from?
IRockSoAwesome is offline
jmpage2's Avatar
Quoted: 12 Post(s)
Liked: 80
That makes a lot of sense. You could encode the audio first, then as the compressionist is working with the video he could see how much of his budget is being allocated to the audio at any point in the movie.
jmpage2 is offline
Old 09-11-2007, 12:47 PM
cdzie1's Avatar
With 51 GB of space, would it not be possible to encode most movies twice on the same disc, once with a TrueHD audio track and once with a DD+ & PiP? Seems that would be a way to get around any bandwidth constraints.
Don’t they do this on some Blu-ray discs? The movie is encoded twice, once with the normal film and once with PiP previously embedded on top of the film.
cdzie1 is offline
Old 09-11-2007, 12:51 PM
jmpage2's Avatar
Quoted: 12 Post(s)
Liked: 80
Don't they do this on some Blu-ray discs? The movie is encoded twice, once with the normal film and once with PiP previously embedded on top of the film.
Well you'd have 25.5 GB for the feature instead of 30GB.
No thanks. It's akin to what they've done to get PiP on some 50GB BD releases, doing two entire versions of the same movie on one disc.
That's a huge step backwards.
jmpage2 is offline
Old 09-11-2007, 01:06 PM
Woodshed's Avatar
Quoted: 14 Post(s)
The bandwidth cap is the bandwidth cap, regardless of whether you are putting something on the 1st, 2nd, or 3rd layer.
You could record 5 minutes of the movie, if the bandwidth cap is hit, you still couldnt fit lossless on the 5 minute clip.
Woodshed is offline
dobyblue's Avatar
No I'm afraid I cannot answer that question.
If you want a good read from December 2006 which should prove credibility, you can read this:
http://forums.highdefdigest.com/showthread.php?t=1439
dobyblue is offline
Old 09-11-2007, 01:09 PM
Everdog's Avatar
Quoted: 20 Post(s)
Thankfully there are a lot of HD DVD movies that have lossless audio and 1080p video so we do not have to argue about that.
Everdog is offline
Old 09-11-2007, 01:11 PM
Woodshed's Avatar
Quoted: 14 Post(s)
I was explaining this to him, I wasnt slighting HD DVD, stop putting words in my mouth.
Woodshed is offline
Old 09-11-2007, 01:12 PM
tteich's Avatar
I may be wrong, and I don't want to offend Doby, but something out of my stomach tells me he is working for Panasonic. Don't know why this is popping off my head, probably due to some categoric statements regarding Pana production things in the insiders thread...
Just my two cents, I believe Dobyblue has some kind of inside knowledge.
Edit: Doby, are you a BD insider, or am I totally off the track?
Laserdiscs: ~350
HiVision LDs: 42
HD DVD count: 379 / still 20 on the wishlist
tteich is offline
Old 09-11-2007, 01:15 PM
jmpage2's Avatar
Quoted: 12 Post(s)
Liked: 80
Man, everyone's so touchy last couple of years. You'd think there was a war going on or something.
jmpage2 is offline
Old 09-11-2007, 01:24 PM
Woodshed's Avatar
Quoted: 14 Post(s)
That, or I get 3 fanboys elbow deep every time I post something because they don't bother to read 3 posts up.
Woodshed is offline
Old 09-11-2007, 02:00 PM
LP30's Avatar
Where have you read anything on this that addressed bandwidth?
Everything thus far in print/online has been silent on the subject it seems.
The rest has been from discussions at the show that some folks here had.
FWIW, there previously has been a brief discussion about bandwidth and the TL51 by insiders here and here.
I don't know if this applied to the final submission. But together with comments concerning likely compatablility with current players, it is interesting.
I do remember another discussion about TL51 indicating there were 2 ways to proceed being considered. The primary concern between the 2 was the ease with which to maintain compatability.
LP30 is offline
Old 09-11-2007, 02:10 PM
patrick99's Avatar
So you are saying that there is a very slight possibility that at some unspecified time in the future HD DVD might attain the technical capabilities that BD has currently?
patrick99 is offline
Old 09-11-2007, 02:13 PM
xradman's Avatar
Probably before BD attain the technical capabilities that HD DVD has currently
Addicted to shiny round discs with HD content
My Home Theater
My Movie Collection
BDP-83 EAP (second group)
xradman is offline
Old 09-11-2007, 02:22 PM
LP30's Avatar
You clearly misread my username and that of the linked posts. I am not saying anything. I am providing information relevant to the exchange I quoted in my post within the context of the "rumor thread", nothing more nothing less. Your purpose?
LP30 is offline
Old 09-11-2007, 02:24 PM
Everdog's Avatar
Quoted: 20 Post(s)
Scary. HD DVD holds more data, and has same bandwidth as BR.
With HD DVD PiP and Internet connectivity on ALL players and EVERYONE would finally agree! There would be no more reason for Blu-Ray, right?
Sure its a big IF, but HD DVD would be superior in every way.
Everdog is offline
Old 09-11-2007, 02:26 PM
Woodshed's Avatar
Quoted: 14 Post(s)
YYYEEEESSSSSS!!!
Increase capacity, but more importantly bandwidth so there is no longer need for a "war".
Woodshed is offline
Old 09-11-2007, 02:45 PM
patrick99's Avatar
And when can we expect all this to come to pass?
Old 09-11-2007, 02:47 PM
BagMan's Avatar
YYYEEEESSSSSS!!!
Or better yet, just go with blu-ray, they already have the space and bandwidth...there you go, no war.
BagMan is offline
Old 09-11-2007, 02:50 PM
Woodshed's Avatar
Quoted: 14 Post(s)
I could deal with that too!! )
Woodshed is offline
Old 09-11-2007, 02:52 PM
patrick99's Avatar
Sounds good to me!
Old 09-11-2007, 02:57 PM
Talkstr8t's Avatar
Originally Posted by rdjam View Post
Sorry talk - I don't believe you unless you post proof, as you have posted opinion as fact too often.
Sorry, RD, next time I'll try to provide a conference call dial-in number so you can listen in.
When the Superbowl Half Time Party is sponsored by Michelob, it means it's paid for by Michelob. It means the same thing in almost every application of the term and I think you are just posting the above in the belief that everyone will just believe you because you say so.
Are you kidding me? You think the "Disney Magical Blu-ray Tour" is entirely paid for by Panasonic? You really stretch your already wafer-thin credibility with this one.
Why do you think that Panasonic sponsoring the tour reflects Disney in a negative light???
The reality is that Disney is spending millions on this, a clear show of commitment to the format. Your implication is that Panasonic is the only one making a financial commitment here.
How is it we are supposed to believe you were in these meetings, when you say in previous posts that you have no knowledge of BDA activities.
Please provide a single link where I stated or implied I have "no knowledge of BDA activities". I said I had no knowledge of one or two specific items I was asked about. I participate at all levels of the BDA and will likely be aware of virtually any official BDA business. In this case, however, the Disney mall tour is not BDA business; I know the details as a result of my company being given the opportunity to serve as a sponsor. Sorry that I'm unwilling to share the sponsorship proposal with you in order to provide the "proof" you demand (which is particularly ironic considering your penchant for stating incorrect information as fact).
Blu-ray Insider
Speaking solely for myself, not the BDA
Talkstr8t is offline
Old 09-11-2007, 02:59 PM
Nescio's Avatar
And you get the scratch resistant discs.
Nescio is offline
Old 09-11-2007, 03:02 PM
Talkstr8t's Avatar
Originally Posted by Michael Mullis View Post
So you've never heard of RCA, Onkyo, Integra?
RCA = rebranded Toshiba (and no longer in the market)
Onkyo = upgraded Toshiba.
Integra = upgraded Onkyo = upgraded Toshiba.
Blu-ray Insider
Old 09-11-2007, 03:03 PM
Talkstr8t's Avatar
Originally Posted by Lee Stewart View Post
Wow! below $400!
How about the $199 Venturer HD DVD player? That doesn't count?
As a name-brand player? No, it doesn't count as name-brand. Have any retailers even confirmed they'll carry it?
Blu-ray Insider
Old 09-11-2007, 03:06 PM
Talkstr8t's Avatar
If TL51 proves compatible with existing players;
And if TL51 spec includes bandwidth increase;
And if bandwidth increase is compatible with existing players (very unlikely);
And if TL51 proves economically manufacturable.
And then you'll still be ignoring HD DVD's failures with regards to recordability (which TL51 has no impact on).
Blu-ray Insider
