Can't update front row? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-10-2008, 08:21 PM - Thread Starter
speters's Avatar
I have a 3.0ghz 8 Core Mac Pro and I noticed that my Front Row was only version 1.0. So I downloaded the Front Row 2.1.3 update and installed it. After the install I checked to see if my Front Row had been updated and it had not. So then I checked to see if maybe it just installed it and it did not. Anyone have any ideas? I did try to install FR update 1.3.1 but I got a message saying it can't install on a computer with out IR.
speters is offline
post #2 of 6 Old 09-10-2008, 08:48 PM
jason75's Avatar
Are you running Tiger? Tiger doesn't support Front Row on Macs without IR.
jason75 is offline
post #3 of 6 Old 09-11-2008, 12:27 AM - Thread Starter
speters's Avatar
I am actually using Leopard.
speters is offline
post #4 of 6 Old 09-11-2008, 05:12 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
where are you looking to see if the updates installed? I just checked in "About this Mac" and Front Row 1.0 should be here:
/Applications/Front Row.app
and then updates like 2.1.3 or the most current 2.1.6 should be here:
/System/Library/CoreServices/Front Row.app
1.3.1 was pre-Leopard, right? So that's too old anyway...re-try 2.1.6 which works with any Mac that Leopard can officially be installed on. It's also tied to newer versions of Quicktime and iTunes, I think.
chefklc is offline
post #5 of 6 Old 09-11-2008, 08:51 AM
jason75's Avatar
Ignore the Front Row in the Applications folder. It's just a helper to launch the real Front Row in the System folder. Front Row 2.1.6 requires QuickTime 7.5.5. You won't be able to install it until you update QuickTime.
jason75 is offline
post #6 of 6 Old 09-11-2008, 10:40 PM - Thread Starter
speters's Avatar
Got it working, thanks.
speters is offline
Reply HTPC - Mac Chat
