In praise of the Griffin Firewave for surround sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-27-2008, 08:08 AM - Thread Starter
Georgio's Avatar
Hi all,
I've been meaning to tell you all about the unusual but effective surround sound setup that I've cobbled together for our Mac Mini-based HTPC system.
I finally got around to making a web page about it with a couple of illustrations. Although the page's focus is on the sound system, it ended up pretty well covering our entire system.
- George
Georgio is offline
post #2 of 3 Old 11-27-2008, 10:04 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
George, I enjoyed reading about your setup and I'm very glad that you're happy with the choices you made. That you're hearing beautiful sound out of those Spendors is what's ultimately important. (That I wouldn't have made any of the choices you did and disagree with much of the rationalization behind them, is a topic to explore in a bit.)
Questions:
1) you have an Intel mini, yet opted not to use its built-in optical out?
2) how much, so we have a ballpark amount, did you pay for the "kit" you cobbled together: the Aiwa, plus the FireWave itself, plus Quad 303 stereo power amp plus Quad 33 preamp plus all the strange minijack cables required by the Firewave plus the 303 refurb kit?
3) I'm not familiar with the 410 or what it records, since I'm USA-based, but does your DTT programming come with DD 5.1 audio or just DD 2.0?
4) and just to make sure I understand how you're using the FireWave, every audio signal you feed through it, from every application be it EyeTV or Apple dvd player or Front Row or VLC, forcibly gets "mixed" and internally processed by the Firewave, right? That's because the Firewave doesn't have a "passthrough" mode, doesn't have an optical or digital coax out and, as a result, even when it gets AC-3, DD 5.1 and DTS it doesn't know what to do with it, i.e. it forcibly mixes all AC-3, DD 5.1 and DTS down to "something else" before it sends it out. Is that your understanding as well?
chefklc is offline
post #3 of 3 Old 11-27-2008, 11:05 AM - Thread Starter
Georgio's Avatar
Questions:
Yes. With the Denon receiver I used before it broke I used the optical out. But as I see it, a digital stream over FireWire is just as good as a digital stream over Toslink.
FireWave ~$50 US - closeout price for end-of-line product
AIWA ~$60 - eBay
I didn't pay for the Quad 303 but there is a market in them and I guess it would go for £150 UK and I spent another £100 on components to refurbish it and about £30 on cables so that gives:
Quad ~$450
Total: ~ $560 or £400 UKP
I think it's similar to your EyeTV 500, but DTT programs here are 2-channel only.
I think it does have a passthrough mode. Every time I change from 2-channel sound for music to surround sound I turn on "Prologic II" in the FireWave app. And I turn it off again for music.
No optical or digital coax out and if there was I wouldn't have a use for it. The FireWave's purpose is to convert the sound from the digital to the analog domain.
But isn't Prologic II a form of DD 5.1? It doesn't mix the Prologic II stream, it just decodes it and feeds the 5.1 streams to the amps (except that for my weird speaker config, it mixes some of the centre stream and the subwoofer strean in with the left and right, but that is my choice in the 'Speakers' config panel of the FireWave app.) I'm not sure what it does with DTS, since the docs explicitly say that the FireWave can't handle it.
- George
Georgio is offline
Reply HTPC - Mac Chat
