AVCNoodle - STB Recording via Firewire - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2009, 01:05 PM - Thread Starter
stoth's Avatar
@gugy, your STB will appear in the UI list. Right click on it, select record.
- Steve
stoth is offline
Old 09-29-2009, 01:35 PM
gugy's Avatar
- Steve
Thanks, I will try that.
gugy is offline
Old 10-08-2009, 06:28 AM
larsonian's Avatar
I'm now having a consistent problem with my recordings getting overwritten by the next recording. What makes this worse, is the second recording will still be tuned to the previous recording's channel, so the second recording does not work correctly either.
When will the next version be released that fixes this issue? Since I tend to record multiple programs over night, I can't move a file once it's done recording so that it isn't overwritten.
I can't use this software anymore until this is fixed. I realize this is beta software, but incorrectly-overwriting existing files is a fatal problem that should be addressed quickly.
larsonian is offline
Old 10-08-2009, 07:00 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
Which STB model are you using, is it on Steve's list supporting channel changing and, if not, how are you changing channels?
You say that this is a consistent problem for you now--does that mean at some point previously AVCNoodle was working properly for you?
chefklc is offline
Old 10-08-2009, 07:08 AM - Thread Starter
stoth's Avatar
I have a newer dev build with this issue resolved. Contact me privately if you'd like an early preview build which should resolve your issues.
stoth is offline
Old 10-08-2009, 11:45 AM
larsonian's Avatar
It's a motorola box that is on the list (I'm not at home and I don't remember the model number 6200 maybe?). I've been using FireRecord for a couple years with this box and channel changing has never been an issue.
When I first bought the AVCNoodle software it worked great. Then I started having overwriting issues and I trashed the prefs, cleared out iCal and basically started fresh. It worked well for a few days, but then it has happened every time I try to record something since. I've only had the software about 3 weeks.
Last night I recorded a show and double checked to make sure it was recording. It stopped and completed successfully. I scheduled 2 more items to record overnight, one on the same channel, and one on a different channel. When I checked this morning, I had ONE file on my hard drive. It was recorded at the time of the last scheduled recording, but was on the original channel.
Old 10-08-2009, 11:49 AM
larsonian's Avatar
I've contacted the Dev to get an updated version of the software. One thing I'm happy to report is the developer's support is great!
Old 10-08-2009, 11:56 AM - Thread Starter
stoth's Avatar
Thanks larsonian.
I should be able to get you the latest beta very shortly, it fixes this issue for sure.
stoth is offline
Old 10-10-2009, 03:37 PM
gugy's Avatar
stoth,
I made it work. Thanks for the right click tip.
One more question. During the 1 minute recording, I notice quite a few garbage and pixel issues during playback, is that normal? If I purchase the full version, is that going to disappear?
My stb is SA 8300 from Time Warner.
gugy is offline
Old 10-11-2009, 07:21 AM - Thread Starter
stoth's Avatar
Garbage is not normal and not something a fully paid version will fix.
stoth is offline
Old 10-11-2009, 11:24 AM
gugy's Avatar
so what do you think is the reason this is happening?
I have a MacBook Pro with Snow Leopard and like I mentioned a SA 8300 STB.
Here are couple stills from the moments I get garbage pixels.
gugy is offline
Old 10-11-2009, 12:36 PM - Thread Starter
stoth's Avatar
It's probably the STB dropping packets or generating bad packets. It wouldn't be the first time we've seen this happen. I've looked at custom streams a number of times (From AVCNoodle and other apps), in all cases the STB wasn't generating the packets correctly (or Apple's firewire driver was trashing them).
- Steve
stoth is offline
Old 10-11-2009, 12:50 PM
gugy's Avatar
OK,
So I guess is something I just have to live with. I believe I have the latest firmware for firewire.
I am wondering what I could do to make this happening less frequently. It is not like is very bad but in 1 minute clip it happened 4 times.
gugy is offline
Old 10-15-2009, 10:28 AM
dcj
dcj's Avatar
Before I report the problems, I'll note that I have a Motorola DCT 3416 I PVR connected to an iMac running 10.5.8 via a 10 meter Firewire cable (actually two 5 meter cables, one of which has a built-in repeater).
I started using AVCNoodle this morning, having just received the license key. Recording of SD channels happens correctly with a VLC display. However, HD channels cannot be understood by either VLC or MPEG Streamclip. VLC reports the following:
main error: no suitable decoder module for fourcc `undf'.
VLC probably does not support this sound or video format.
Channel changing works correctly.
As a comparison, AVCVideoCap recorded identical streams, i.e. same channels and identical length, that could be understood and displayed correctly by VLC and MPEG Streamclip.
dcj is offline
Old 10-15-2009, 10:36 AM
dcj
dcj's Avatar
I thought I would post a separate message for features wanted to keep the thread distinct from problems.
1. I cannot find a way to record the stream from the PVR when it is replaying something it has recorded. Is that on a particular channel? This is important for me because I would like to edit and preserve certain recordings on my iMac while using the PVR for the original recording.
2. I would also like a way to begin recording immediately rather than have to set up a scheduled recording a minute or so in the future.
dcj is offline
Old 10-23-2009, 09:45 AM
Tigidal's Avatar
I'm also not able to record off of the PVR on my 3416. I'm attempting to record to a MB Pro 10.6.1... and when I try to record from the PVR, data seems to be coming in, but all I get is a black screen when replaying the file in VLC. Would like to purchase AVCNoodle to get this data off of my PVR, but need to get past this hurdle. Thanks!
Tigidal is offline
Old 10-23-2009, 12:14 PM
gugy's Avatar
stoth,
I have a question, when you buy the AVC Noodle software I understand the license is tied to a specific STB.
Once you upgrade the STB or change service to a new cable provider, do I have to buy again AVC or just switch the serial of the STB on the software to make it work?
gugy is offline
Old 10-28-2009, 06:27 AM - Thread Starter
stoth's Avatar
dcj: Can you send me a sample of the recording from AVCNoodle via ftp? If yes I'll PM you the ftp server details. This isn't something I've seen before so I'd like to investigate this.
stoth is offline
Old 10-28-2009, 06:29 AM - Thread Starter
stoth's Avatar
Tigidal: Does AVCNoodle show the channel as Copy Freely? If not, it's possible that the STB is refusing to decrypt it. You could also try this with a regular 'network' channel and see if the same behavior exists.
stoth is offline
Old 02-08-2010, 02:28 PM
bab5925's Avatar
Using a Moto DCT-6200 - many - but not all - of the HD channels look like they're recording - but files will not playback either in VLC or Plex (or anything I've tried). Yet, the same channels recorded using AVCapture DO record and playback. Not sure what to try next. Using version 1.0.0-b1
bab5925 is offline
Old 02-09-2010, 05:25 AM
MissionD's Avatar
I recently purchased AVCNoodle and am having a hard time with the scheduling. I use titantv, and when I open the tvpi file, AVCNoodle tells me it could not be opened. If I open the file a few times in a row it eventually works. Then the show will come up in the scheduled recordings, but the time is always 00:00 so nothing records.
I'm using a 2.53 GHz Core 2 Duo Mac Mini running Snow Leopard with a Motorola DCT 6416. Channel changing seems to work ok with it.
MissionD is offline
Old 02-17-2010, 11:37 PM
MissionD's Avatar
Just wanted to follow up on a solution to my problem. I think it had something to do with OSX short time or whatever it's called and the time TitanTV was giving. Got them both on 24 hour time and it schedules fine. Still have the issue with the tvpi files not opening on the first try though.
MissionD is offline
Old 02-18-2010, 07:54 AM - Thread Starter
stoth's Avatar
Can you PM me the tvpi file?
Thx
- Steve
stoth is offline
Old 03-08-2010, 09:40 AM
DaveGee's Avatar
delete this
DaveGee is offline
Old 03-09-2010, 09:24 PM
Trebly's Avatar
I am still having issues with AVCNoodle not adding scheduled recordings to iCal and would like to try a fresh install. What do I need to remove in order to accomplish this? Do I need to remove anything iCal wise?
I noticed references to a updated version awhile back. What is it's status?
It's good to see that AVCNoodle is working for some, so I hope it is just something messed up on my computer.
My current status is that I can't record immediate or scheduled recordings. AVCNoodle sees the Motorola DCT-6200 STB. I am running 10.6.2 on a 2 GHz Core 2 Duo Mini.
I am able to still use AVCVideoCapture but can't really schedule recordings because it's calendar doesn't extend past 2008.
FireRecord doesn't appear to like Snow Leopard.
Any help will be greatly appreciated. Thanks.
Trebly is offline
Old 03-09-2010, 09:26 PM
teague's Avatar
I haven't had any trouble with FireRecord and Snow Leopard on my Mac Pro (Early 2008).
teague is offline
Old 03-09-2010, 09:43 PM
Trebly's Avatar
That's interesting. It doesn't find my STB. It seems strange that AVCVideoCapture always works. It may be what ever issue I am having with AVCNoodle is also affecting FireRecord. Thanks for the info.
Trebly is offline
Old 03-11-2010, 08:40 PM
DaveGee's Avatar
Silly and useless info about what cable companies can and can't do to data being output from a fw port removed. As the author of this post I am formally requesting that it not be reproduced without my written consent.
DaveGee is offline
Old 03-12-2010, 06:20 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
Dave, if I could make a request as a fellow user in the forum, this thread is about AVCNoodle--and only AVCNoodle--and we're lucky that the developer drops in and out of here to help troubleshoot his software. Let's not turn this into another general recording over firewire thread. We already have one of those.
chefklc is offline
Old 03-12-2010, 10:30 AM
DaveGee's Avatar
This is an odd request since on the face of it this thread seems to be more often then not dealing with problems recording from a users FW port on their cable box and the information I provided showed some potentially valuable information about the things cable franchices can and cant do..
I'll bow to your best judgement and keep the information off the forums and further ask that it not be restored without my consent.
Have a good day!
DaveGee is offline
