Mac Mini and Onkyo 706 Success Stories? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-19-2009, 12:27 PM - Thread Starter
Knowledge_Seeker's Avatar
Has anyone heard of success stories with an Onkyo 706 receiver (606? 806?) and a Mac Mini?
I've seen a number of posts related to potential issues related to output of the custom resolutions required to get properly aligned 1080p output. What I haven't seen is any success stories.
The Onkyo 706 looks to be the best bang for the buck for my receiver budget and needs, but it will be a no-go if it won't work with the mini.
In that case, does anyone have a suggested receiver in the $600-$700 range that will play nicely with the mini?
If it helps, everything will be outputting to my Sharp Aquos LC-46D64U.
I appreciate the help.
Knowledge_Seeker is offline
post #2 of 2 Old 05-19-2009, 02:24 PM
gomez1856's Avatar
I've got the 806 and it works great with my Mac Mini. No issues at all.
Audio from the 1/8th inch optical, using TosLink adapter from monoprice.com, into optical in.
Video is connected with a DVI -> HDMI cable from monoprice.com. No adapter. Plugged it in and it worked right away.
Not much more to add as I have had zero issue with either display or audio.
Rick
gomez1856 is offline
Reply HTPC - Mac Chat
