PLEX? Anyone using it? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 08-21-2009, 09:26 AM
Immaculate Grand Phoobah
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Quoted: 40 Post(s)
Liked: 32
Originally Posted by Further View Post
Are you aware that VLC was updated several weeks ago (version 1.0.1) with many new HD codecs? If you haven't upgraded yet, it might be worth trying it again.
Yes. I have it notify me automatically. No joy.
Not my president!
grubavs is offline
Old 08-23-2009, 11:38 AM
grubavs's Avatar
Quoted: 40 Post(s)
Liked: 32
Originally Posted by dancinbear View Post
I'd recommend checking their wiki, or posting your question in the Plex forums. It's a great community and their very helpful (just like AVS!).
Originally Posted by grubavs View Post
Thanks. I did post there (after searching their forums for subtitles and trying all the suggestions available) prior to posting here. Their answer was to do what I'd already tried, so it appears even though MakeMKV says it has ripped the subtitles, either Plex cannot access them or MakeMKV actually never ripped them.
OK. Finally found out (thanks to the very helpful folks over in the MakeMKV (Mac) forum):
Originally Posted by tuyenvo View Post
That's correct. Plex and VLC cannot play PGS subtitles. These are the subtitles you rip using the MakeMKV software. Check out this thread on another forum:
http://www.videohelp.com/forum/archi...e-t368209.html
I appreciate you folks' input, BTW!
Not my president!
grubavs is offline
Old 08-24-2009, 07:55 PM
longranger's Avatar
I have tried the last two builds of Plex. In all honesty, it's not for me. Scraping issue after scraping issue. Just when I get it running ok, all of a sudden it's forgotten which tv episodes or movies I had.
The navigation is nuts. I really tried hard to sell my wife on this. Let's face it guys, if the wife's not happy....ain't nobody happy. It was just too much work for her to learn it all and then have it break down or have a plugin go on the fritz. It's just gotta work...all the time, not sometimes.
Plex was fun to play around with and a great tinker toy for the Man Cave, but it's nowhere near ready for prime time.
Sorry Plex developers. I think you're on the right road, but this family has gotta flush it.
longranger is offline
Old 08-26-2009, 10:10 PM
LewisD's Avatar
Did you try out the plex-friendly Aeon skin? It is 10 times better than MediaStream, which is the default skin. I think your family would like Aeon a lot more.
LewisD is offline
Old 10-28-2009, 09:04 AM
Nathan_R's Avatar
0.8.3 is out and it addresses some of the SL issues-- particularly the audio issue. Apparently it also fixed the IMDB scraper uselessness under Leopard and SL. Yay!
PSN: KyFriedNate
Nathan_R is offline
Old 10-30-2009, 09:36 PM
nightowl's Avatar
Originally Posted by whodean View Post
I tried several media center front end apps last year and decided I liked Boxee the best on my Mac, could someone that has tried both Plex and Boxee explain why they prefer Plex?
The manner in which Boxee scrapes audio, in particular, was extremely frustrating for me. It constantly gave wrong information on various audio tracks, and there was no way to change it. Also, I wasn't necessarily a big fan of the social integration of Boxee. If there was a way to turn that off, it might be better. Also, no way to change the skin, you are stuck with what they give you.
With the addition of the app store in Plex, it's just about perfect. There are still some scraping issues with TV Shows in particular, but it's very usable for my entire family, and nearly all necessary features are mapped into my Harmony One remote.
The biggest problem I have with both of these programs is the overall "clunkiness" of the online content. I don't want to view by provider, I want to view by program, or even type, similar to the EPG on a cable or satellite box. If I'm looking for "Chuck", I just want to select it and watch, not figure out which plugin it's a part of.
I'm not sure how anyone is planning to bridge that issue, but it will be welcomed by me when it's solved.
nightowl is offline
Old 10-31-2009, 11:15 AM
mikefl52's Avatar
I wonder if this means that they will carry 2 versions into 9 (with the database changes) or just proceed with with the SL version. I did not want to upgrade to SL so I hope they will support both since at this time I really do not want to switch to SL.
One good thing about music, when it hits you, you feel no pain.
~Bob Marley~
mikefl52 is offline
