MakeMKV beta for OS X - AVS Forum | Home Theater Discussions And Reviews
post #1 of 54 Old 07-21-2009, 07:35 AM - Thread Starter
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
Has anyone here tried the MakeMKV beta for OS X? Booting into Windows in order to run AnyDVD HD never appealed to me, and as a result I haven't picked up a blu-ray drive yet, but this app just might move me forward:
http://www.makemkv.com/
Nascent thread about it here:
http://forums.macrumors.com/showthread.php?t=748615
If you do succeed with the beta, please post which Mac and which model blu-ray drive you used...
chefklc is offline
post #2 of 54 Old 07-26-2009, 08:29 AM
mrjinglesusa's Avatar
There are several posts in that forum thread you posted that list BR drives, enclosures, and Macs that work. It appears that any BD-ROM drive that also burns DVDs will work. Seems to be a nice solution for transcoding Blu-ray discs to MKV containers which can then be encoded to H.264 with Handbrake on OS X.
mrjinglesusa is offline
post #3 of 54 Old 07-27-2009, 09:21 AM
Russ Younger's Avatar
I've tried it with LA Confidential and Cars and everything worked like a champ. I am using an LG combo drive that is also a bluray burner. Doesn't work with any of my HDDVDs though.
Russ Younger is offline
post #4 of 54 Old 07-27-2009, 05:04 PM
Andrew67's Avatar
I wasn't able use my 360 HD-DVD drive under OSX or Windows to rip the only movie I happen to have on hand (King Kong). Under OSX, a RW drive is required by MakeMKV.
Andrew67 is offline
post #5 of 54 Old 07-28-2009, 10:15 AM
rottnpup's Avatar
Hmmmm, funny thing I just ran into this program a couple of weeks ago and have been using it since to rip to my macmini. I have ripped about ten movies (from my collection. for backup) so far with no hitch seems to work great. I have plenty of storage space right now so I have just been leaving them raw with DTS track and they seem to average in the low 20 gigs. I plan on leaving them that way in hopes that bdr's will come down in the near future and I can burn them to the media in native format.
I am also using and LG multi burner I have put in external case so I can move back in forth between my pc's and mac.
rottnpup is offline
post #6 of 54 Old 07-28-2009, 01:46 PM
timgrady's Avatar
I've been using it. It works great for making mkv's of DVDs using my MBP's internal superdrive. I tried it with a bluray or two in an external drive, but no luck so far. I'm also having trouble with AnyDVD HD on that external drive though...
Tim
timgrady is offline
post #7 of 54 Old 07-28-2009, 03:12 PM
I also have been able to play these mkv files without any problems in PLEX.
post #8 of 54 Old 07-28-2009, 05:30 PM
dbfreq's Avatar
Do you mean that you've been ripping them straight to your hard drive using makemkv and storing them uncompressed and they play without issue in PLEX? If so, that's great news! How long, on average, does it take to rip a full-length disc?
dbfreq is offline
post #9 of 54 Old 07-28-2009, 08:19 PM
rottnpup's Avatar
Yes......thats the way it has been for me. And it takes me about 45 minutes for a rip play's in plex just fine no problems. Like I said before I am using a macmini 1.83 upgraded to 2 gig mem and 500 gig internal hard drive and 1 tb external hard drive. I have put an LG GGW-H20L drive in a Bytecc ME-535XU external enclosure. So far working great.
rottnpup is offline
post #10 of 54 Old 07-29-2009, 03:42 PM
Andrew67's Avatar
It's fantastic for regular DVD's.
Andrew67 is offline
post #11 of 54 Old 07-29-2009, 04:48 PM
It takes about 40 minutes or so. The only deal is that I believe BD+ discs are a no no. I tried to rip Kill Bill 1&2 yesterday with no success, but Close Encounters worked fine. This program is great when the discs are compatible. Anyway the program downrezes the DTS and Dolby TrueHD tracks into DD and DTS core tracks so they play fine in PLEX. It sure is handy not having to boot up the PC side.
post #12 of 54 Old 07-30-2009, 10:03 AM
stillbreathing's Avatar
I have been using MakeMKV to rip movies from DVDs, and it works really great. It is nice to have a FAST way to move a DVD movie to the hard-drive. 15-30 mins? I have transfered some 40 movies and they all seem to be working great. (This is just dvd's. have not tried blue ray, don't have a drive yet) Really nice program.
stillbreathing is offline
post #13 of 54 Old 07-30-2009, 10:03 AM
BTW this looks to be a nice $110 BlueRay Drive - http://store.fastmac.com/product_inf...roducts_id=406
post #14 of 54 Old 07-30-2009, 02:45 PM
Andrew67's Avatar
It is, but as a side note, to use MakeMKV under OSX you need to have a BD burner. It's part of the security restrictions inherent in OSX that creates this requirement. When you try to use a read only drive, that's the error and explanation that MakeMKV reports. I don't know if the ability of this drive to burn DVD's removes the restriction of having a BD burner or not.
Well... it looks like this drive should work just fine with MakeMKV
"On Mac OS X access depends only on the drive type. If the drive is a read-only device that can't write to any media ( either CD-ROM, DVD-ROM or BD-ROM) then access is blocked. The rationale is that direct access is dangerous and application may request drive to perform any action, like eject the disc (one really can't erase a disc in a read-only device). However, if the drive is capable of writing any media (for example Blu-ray reader that can write CD and DVD media) then all access is allowed to any user. This policy is beyond our comprehension - our only explanation is that weed is really easily available to designers in Cupertino, CA. Practically that means that if you have any drive that is read-only device, then it will not be accessible to MakeMKV. Luckily most modern drives usually are combo drives that can write at least CD media - these drives are accessible to MakeMKV. Even if the drive is not accessible there is a way to enable access to all drives - that requires changes to the system plist file and rebooting the system. Please see our forum for details. "
http://www.makemkv.com/osxmmc/
As an additional note, whatever plist file that can be edited has not been documented as of yet.
Andrew67 is offline
post #15 of 54 Old 07-30-2009, 06:40 PM
rottnpup's Avatar
It is my understanding that as long as the drive writes in any format the one shown does write dvd that Leopard should set the permissions correctly and it should work.
rottnpup is offline
post #16 of 54 Old 07-30-2009, 07:13 PM
Immaculate Grand Phoobah
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Quoted: 40 Post(s)
Liked: 32
Well, I got a OWC external BD/DVD/CD R/RW (contains an LG GGW-H20L) and downloaded MakeMKV & Plex. The external drive has eSATA/FW800/FW400/USB 2.0 interfaces. I first tried the eSATA interface through a Syba SD-EXPC34-1S2 JMB Chipset 1x e-SATA Ports, 34mm, Up to 3.0Gb/s ExpressCard in my MacBookPro 2.33 GHz Intel Core 2 Duo. The drive showed up in makemkv, and I started to open the MiB BD, and my MBP froze. Happened twice. Then tried FW800, but Makemkv would not recognize that the drive was connected. Then tried FW400, worked like a champ, so I went back to the FW800 and then could access the drive.
I ripped (FW800) MiB BD and For All Mankind BD to my MBP's HD. Fired up Plex and both rips played flawlessly (no HD audio though ). I then transferred the rips to my Mac mini (1st gen Intel Core Duo upgraded to 2.33 GHz Core 2 Duo), fired up Plex, and the rips looked great (compared to the BDs) on a 52" Sony XBR5 (I had to bump up the mini's fan speed to 4500 RPM, and the CPU temps were still around 60°C ).
From now on I'll do all rips on the mini and store them on HDs in my G4 Quicksilver.
I do miss the high-rez audio, though.
I'd sure like to be able to record the main feature in <4GB packets. Then I'd be able to drop the rip onto a USB drive formatted in FAT32 and see what the Oppo BDP-83 does with the video...
Not my president!
grubavs is offline
post #17 of 54 Old 08-01-2009, 10:27 AM
Nathan_R's Avatar
I gave this a shot last night with a spare BD-ROM/CD-writer I had lying around and fully expected to be completely underwhelmed. I'm eating crow today-- this is an incredible development on the Mac front! I hated having to open up an XP instance in Parallels and use AnyDVD and Ripbot264 to convert my discs to mkv, but this is much, much faster and requires little to no user involvement. I would gladly pay a premium to get this out of beta at this point.
PSN: KyFriedNate
Nathan_R is offline
post #18 of 54 Old 08-01-2009, 12:30 PM
grubavs's Avatar
Quoted: 40 Post(s)
Liked: 32
My BD rips are taking about 1.3-hours, whether I use FW800 or FW400. MakeMKV indicates 2.3x read times, so I'm not sure why a 2-hour BD would take 1.3-hours (give-or-take)...
Still, the PQ is great from my mini. Glad chefklc posted this!
Not my president!
grubavs is offline
post #19 of 54 Old 08-02-2009, 02:30 AM
NewOrlnsDukie's Avatar
Liked: 29
Any reason this drive wouldn't work? I think it would probably be one of the cheapest and best solutions for those of us w/ mac pros...
NewOrlnsDukie is online now
post #20 of 54 Old 08-02-2009, 07:57 AM - Thread Starter
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
No reason why not if you mainly want to rip--that Pioneer drive, and the LG GGC-H20L, seem to be good bets--BD-ROM with regular dvd burning capability. I've seen them both recently for $109 shipped.
The LG GGW-H20L was just $139 at newegg, that model can burn, rather than just read, blu-ray discs. I bet a lot of Mac users bought this drive in the past few days...
chefklc is offline
post #21 of 54 Old 08-02-2009, 10:52 AM
Liked: 29
And I think there's about to be one more.
post #22 of 54 Old 08-04-2009, 10:28 AM
Nathan_R's Avatar
Has only run a resulting 1080p mkv from MakeMKV through Handbrake to get a 720p mkv file (as the forum link the OP suggests)? If so, what have your experiences or results been so far?
PSN: KyFriedNate
Nathan_R is offline
post #23 of 54 Old 08-04-2009, 10:42 AM
IndyLions's Avatar
So far I've only gone from 1080P MKV to 720P M4V with a tweaked AppleTV preset with the HandBrake version mentioned in the other forum. I've done so on two movies, with quick, great results both times. About an hour (give or take) with MakeMKV to backup, and 4 or 5 hours with HandBrake to transcode. File sizes have been great - about 3GB with both movies. No complaints on quality either. On my 60" Sony 720P rear projection, they look and sound really good.
A nice compromise between Quality and File Size with very minimal hassle.
I hate all this downtime in between drafts...(unidentified Lions loyalist '2004)
IndyLions is offline
post #24 of 54 Old 08-04-2009, 06:15 PM
Nathan_R's Avatar
Would you mind sharing your 720p preset info with me? I haven't had much luck finding a really good handbrake setting yet in my experimentation.
PSN: KyFriedNate
Nathan_R is offline
post #25 of 54 Old 08-04-2009, 08:05 PM
IndyLions's Avatar
Sure...
1. Using HandBrake version SVN2592. Supposedly this has had some nice enhancements for high res sources...
2. Set the 1080P MKV file as the source...
3. Select the AppleTV preset (the one with SVN2592), that means:
a. Video Code H.264 (x264)
b. Constant Quality 60.78%
c. Make sure Large File Size is selected
4. Change Framerate (FPS) to 24.
5. For the Picture Settings (moved to the top area with this version of HandBrake), I change anamorphic to none, leave "Keep Aspect Ratio" checked, and then adjust the width to 1280 pixels. I've always left the cropping to Automatic - and it seems to work - although when I try to calculate it manually it doesn't seem like the numbers they come up with ought to work.
6. Since my target is an AppleTV, Track 1 is set to AAC (Audio Codec) and Dolby Pro Logic II (Mixdown). Samplerate is 48kHz, and Bitrate is 160 kbps. Track 2 is set for AC3 Passthru (Audio Codec) and AC3 Passthru(Mixdown).
7. I never touch anything on the Subtitles (none), Advanced, or Chapters (create chapter markers) configuration pages.
Edit: I've had one encode with these settings (Hotel for Dogs) that stuttered badly/froze periodically on the AppleTV. I'm in the process of completing some test encodes with different settings, and I'll post the results when I'm done...
post #26 of 54 Old 08-05-2009, 11:56 AM
tommylotto's Avatar
Has anyone had any luck with HD-DVD disks. I have a few I bought before the format war was lost. I would love to rip them and hide the disks so that no one would ever know I was duped by the wrong format...
tommylotto is offline
post #27 of 54 Old 08-05-2009, 07:10 PM
PAP
PAP's Avatar
I recently bought a BR drive on e bay for ~ $75. You can search for item # 250468867331 to see which one. It's a very slim external USB drive. It does not burn BR, but does burn other formats, which is the key for osX to let it work.
I just ripped my first BR with MakeMKV and it worked great. Approx 1hr45min for handbrake to encode for aTV 720p.
Haven't played any yet, but as a data point the above drive is cheap and seems to work fine, and easy to add because it's USB powered to not even a wallwart to deal with, just plug and play.
FWIW.
Oh, and the documentation states HDDVD is "very limited" and wont' be supported, so i don't think that this program will work in that format. AnyDVD is probably best for that.
Good, cheap, easy - pick any two.
PAP is offline
post #28 of 54 Old 08-05-2009, 08:54 PM
Andrew67's Avatar
I haven't had any luck under OSX (as my drive isn't supported) and while my drive is supported under Windows it has failed to rip the two discs I've tried.
Andrew67 is offline
post #29 of 54 Old 08-06-2009, 12:25 AM
Nathan_R's Avatar
Originally Posted by IndyLions View Post
Handbrake settings
Awesome. Thank you! I'm curious if one really needs to change the framerate to 24 (rather than leaving it as-is), but I'll play around with both options.
PSN: KyFriedNate
Nathan_R is offline
post #30 of 54 Old 08-06-2009, 08:19 PM
Liked: 29
Well, I got a new GGW-H20L w/ mac pro kit from OWC, and, though it was a little more expensive, the included instructions and cables were quite helpful. Of course, the instructions failed to mention that you need to remove the bezel on the front of the drive in order for the drive to open in your mac pro, as they probably assumed no one would be idiotic enough to forget such a thing. Little did they know that NOD, Lord of the Idiots, was on the case. So, I ended up having to go back in to fix it. But anyway...
Archiving my discs has gone off w/o a hitch. About 30-45 minutes per BR on my 8-core 2.8GHz.
Now I just need to get ANOTHER 6TB of HDD's or so...
Reply HTPC - Mac Chat
