Plex Hulu Plug in - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-27-2010, 11:35 AM - Thread Starter
wvick's Avatar
Anyone having issues with the Hulu plug in on Plex? All I'm getting is the audio and no video at all. I do have my log in and password set up and can access the Hulu menu just fine. Any ideas?
wvick is offline
post #2 of 5 Old 08-31-2010, 02:37 AM
lovekeiiy's Avatar
Liked: 30
I personally haven't used it in quite some time. It worked fine for me, overall. I just did not like the fact it didn't use my default resolutions (set on Hulu.com) which I always set to the highest available. I use the Hulu desktop app.
No video? Are you getting video for other online video apps? What about Hulu.com or the Hulu desktop app? From the brief information, I'm thinking it's the machine or a video driver issue.
lovekeiiy is offline
post #3 of 5 Old 08-31-2010, 06:15 PM
madSkeelz's Avatar
Plex [even today's .9 release] still doesn't get along well with Flash 10.1. One of the common symptoms is audio without video. Downgrade to Flash 10.0, and you should be ok. [The Plex forums have links to older versions of Flash for download.]
-mS
madSkeelz is offline
post #4 of 5 Old 09-02-2010, 07:17 PM - Thread Starter
wvick's Avatar
Thanks for the tip, I will give it a try.
wvick is offline
post #5 of 5 Old 09-09-2010, 06:35 AM - Thread Starter
wvick's Avatar
It worked! Thanks!!!
wvick is offline
Reply HTPC - Mac Chat
