Dying disk replacement suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-17-2012, 08:24 PM - Thread Starter
Ted Todorov's Avatar
My iTunes disk is almost dead -- moral of story here -- run SMART Utility proactively -- don't wait until things are very wrong to figure out what's what.
Disk Utility is useless -- verification tells me that the disk is fine.
the nearly dead disk is a 3TB WD Caviar Green -- I need to replace it with another 3TB drive. I am looking, above all for reliability. With the Thailand floods, things are bad in the HD market...
Basic choices seem to be sticking with the same or getting a Seagate Barracuda ST3000DM001 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive or a HITACHI Deskstar 0S03230 3TB 5400 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive.
Price wise the WD is the cheapest (double + the price of a couple of months ago), the Seagate $40 more, Hitachi in between.
Any words of wisdom welcome.
Ted Todorov is offline
post #2 of 3 Old 01-18-2012, 05:41 AM
dknightd's Avatar
Hopefully you have a good back up.
Assuming so, return the WD for warranty replacement.
I don't know if any of those disks are more reliable than the others. Disks die.
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #3 of 3 Old 01-18-2012, 05:50 AM - Thread Starter
I'll get the warranty replacement of course, but I need something I can use immediately, and my backup disk isn't suitable (it is in an external USB 2.0 enclosure).
Backup -- could be better, could be much worse -- the last full backup is from 2.5 months ago, which in my scheme of things is pretty good. Worse case I'll lose a few podcast episodes, a couple of TV shows* and have to re-import some CDs. The thing I'm losing the most of is time and enjoyment of my home theater until everything is fixed...
*Did Apple allow you to re-download TV the way it does with music these days?
Reply HTPC - Mac Chat
