OS X software for WinTV-HVR-1950 - AVS | Home Theater Discussions And Reviews
Old 01-29-2012, 05:33 PM - Thread Starter
StantonGuy's Avatar
I bought a Hauppauge USB TV tuner from a guy off of Craigslist thinking the company was Mac-friendly and I could use it on Mac OS X (hopefully either OS 5 PPC or Snow Leopard Intel), but I can't easily find any Mac drivers and my EyeTV Lite isn't recognizing it (I already have it set up for a different USB stick so that might be the problem).
Any suggestions?
StantonGuy is offline
Old 01-30-2012, 06:26 AM
AVS Club Gold
chefklc's Avatar
Quoted: 18 Post(s)
That WinTV-HVR-1950 seems very similar to what El Gato has sold as the 250+...
but El Gato didn't provide blanket support for all of those Hauppauge tuners, it was usually on a case by case basis. According to this page:
http://www.hauppauge.com/site/suppor...ab=6#operating
it doesn't list EyeTV under 3rd party support, so you may be out of luck. Here's a Hauppauge tuner that is officially supported by EyeTV, the WinTV-HVR-950Q, and you'll see that it is mentioned under the 3rd party tab:
http://www.hauppauge.com/site/suppor...t_hvr950q.html
In any event, I suspect you'd need a real version of EyeTV rather than a "Lite" version.
chefklc is offline
Old 01-30-2012, 08:57 AM
rpineau's Avatar
There is a list of all the compatible tuners for EyeTV on Elgto's website :
http://www.elgato.com/elgato/int/mai...oduct3.en.html
Rodolphe
rpineau is offline
Old 01-30-2012, 10:15 PM - Thread Starter
StantonGuy's Avatar
Thanks for the responses and links. I'm wondering now if the Mac version of Sage might do the trick...
Old 12-28-2013, 07:43 AM - Thread Starter
StantonGuy's Avatar
Any update on this? Mac only house but I have one too from an old housemate.
