Mac mini 2007 - Yamaha receiver - Philips tv. No sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-29-2012, 03:19 PM - Thread Starter
mats.olsberg's Avatar
Hi there.
I just bought a new receiver and tv but can not get the audio working.
My set up is a mac mini from 2007 connected with dvi - hdmi and optical to a Yamaha RX-V371 and that is connected with hdmi to a Philips 46PFL6606H.
I have set the audio input for hdmi 4 to av 4 which is where i connected the optical sound.
I had my mac connected to a older denon before whit sound working.
Tried a new cable, no luck.
Connected my MacBook Pro with thunderbolt to the Yamaha with hdmi and that works.
I do not know what else to try. I really like my mini but this is frustrating.
mats.olsberg is offline
post #2 of 4 Old 03-01-2012, 01:56 AM
geeji's Avatar
Did you check that "Digital out" (= bitstream) is selected on the Mac, and not "System out" (=PCM) in Audio & Midi Utility or your Application sound preferences ?.
I have a similar configuration which works, but my Yamaha RX-V3800 AVR was somewhat finicky with sound inputs, and while it would upconvert stereo->HDMI, it would not downconvert optical bitstream->stereo.
May be you have a similar compatibility problem, since your MacBook Pro/DVI/HDMI/RX-V371/46PFL6606H works.
You could also try AV1 instead of AV4, in case there is a problem on AV4 reception.
geeji is offline
post #3 of 4 Old 03-01-2012, 03:57 PM - Thread Starter
It is on "Digital out" but on the Yamaha it says PCM on signal info.
I tried to change to HDMI 1 and AV 1 but no luck there either.
I also tried to go with analog audio but that did not work either.
post #4 of 4 Old 03-02-2012, 08:59 AM - Thread Starter
Did some more testing, this time I connected a speaker to my Yamaha and that seems to work, so it seems to be the output to the tv that is not working.
Reply HTPC - Mac Chat
