1280x720p 50hz - with Switchres X (works on windows) not on osx - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-01-2012, 01:57 AM - Thread Starter
Chris Kuhl's Avatar
Hello,
I have an ATI 6850 with VGA output to a Loewe Xelos 32 HD ready tv which runs the 50hz mode (1280x720p) fine in windows, but when i go to osx and create a 1280x720p 50hz resolution with Switchres X i get a black sometimes flicker screen, actually it says the right details on tv (1280x720p 50hz) but no visible image...
strange because in windows it works fine with 50hz..
can anyone help?
Chris Kuhl is offline
post #2 of 2 Old 08-09-2013, 07:51 PM
macman13's Avatar
Originally Posted by Chris Kuhl View Post
Hello,
can anyone help?
What kind of Mac are you using? Mac Pro I assume if you are using a 6850.
The 6850 is not entirely supported in the Mac OS, and I assume that is where the fault is at. If you can, try to use an HDMI cable and see if that works.
2x HDHomeRun Prime - 3CC
Sharp 65" TV; Sharp 46" TV; Panasonic 42" TV; Sony 40" TV; Sony 32" TV
WMC HTPC Server: Intel Celeron G1840, 4GB RAM, MSI H81M-P33, 1TB
Main HTPC: Mac Mini 2.3Ghz i5, 8GB RAM, 500GB, 1TB, 2TB, 3TB
XB360 WMC Extender, Ceton Echo, Roku 3, Apple TV 3
macman13 is offline
Reply HTPC - Mac Chat
