Saving DVR content? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-02-2012, 06:57 PM - Thread Starter
eljayebee55's Avatar
I haven't seen anything on this topic, so maybe everyone but me already knows the answer - is there a way to save/download content from my Comcast/Xfinity DVR to my Macintosh computer? Brand new, state of the art iOS Mac and Apple TV, in house WiFi and HDMI cable. That's my hardware. A techie guy at work said he was pretty sure it was possible, then a Geek Squad guy told me 'no way'. Who's right?
eljayebee55 is offline
post #2 of 5 Old 08-02-2012, 07:43 PM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
If you have a FireWire port on both the Comcast DVR and Mac it is theoretically possible. It's been a few years since I did it last, and never with a DVR, only an STB. This is what I used back then
http://www.ammesset.com/firerecord.html
If you'd like control over what you record after you record it, to be able to transcode those recordings for iOS devices and Apple TVs and to add that content to iTunes, instead of using Comcast's boxes, it's better to rely on EyeTV or TiVo or boot into Windows in order to record with a CableCard tuner like the HD HomeRun Prime.
chefklc is offline
post #3 of 5 Old 08-03-2012, 10:56 AM
lsilvest's Avatar
I use an Avermedia HDDVR card to capture from a DVR (has worked with Comcast, DirecTV and Dish). You have to use a component input with separate audio (analog) to avoid the HDCP errors. Does good HD in various formats (I use Mpeg) but the audio is only stereo. It's a less expensive alternative to the Homerun or Prime is all you want to do is capture and not do the original recordings.
Not sure if it's compatible with Mac without a Windows OS.
lsilvest is offline
post #4 of 5 Old 08-03-2012, 11:38 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
Good catch, lsilvest, the EyeTV HD and Hauppauge HD PVR both work over component in OS X; of the two only the latter device can handle digital audio.
chefklc is offline
post #5 of 5 Old 08-11-2012, 08:58 PM
ultimate's Avatar
I use a Happauge! HD PVR to capture stuff using the component outputs on my Dish 211K satellite receiver with EyeTV. I've captured hundreds of hours and am able to save it without decompressing saving a lot of time.
Dennis
Dennis Whiteman
Check out HDTVOK.COM
ultimate is offline
Reply HTPC - Mac Chat
