5.1 dolby digital surround sound from imac - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-13-2012, 07:39 AM - Thread Starter
hochun0809's Avatar
Hi everyone, I am very very new to this forum so if I do something inappropriate, I apologize for that. =)
Here are my questions.
I have got a mid 2007 iMac and a Creative inspire p7800 7.1 speaker.
What I want to do is to hear 5.1 dolby digital surround sound from the creative speaker (which does not support DD and DTS like Logitech z5500 and Logitech Z906 do).
I have done tons of research and spend a lots of time in the internet to look for answers. I did find some solution on this issue but I am not 100% sure. And some more questions pop up. So I am hoping that some expert here can clear my mind. Thank you so much ^^
So, here is some solution that I got from the internet. (please correct me if I am wrong)
1. Buy a Griffin Firewave and connect it to my mac and thats all I need to do. As Griffin Firewave has dolby digital processor, so I think I will be getting 5.1 DD surround sound from the speaker. (Am I right?)
http://www.amazon.com/Griffin-4019-FIRESS-FireWave-Surround-Sound/dp/B000A09IUS
But the problem is, there is only one firewave listed on amazon and one listed on ebay. The amazon one is really really expensive that I think it is really unreasonable to buy it. So as I may not able to get a Griffin Firewave, this lead to my second solution.
2. Buy a external sound card like this:
http://www.amazon.com/Diamond-External-Xtreme-7-1-Channel-Device/dp/B0046B9O9W/ref=pd_cp_e_0
and connect it to the mac. But my question is, As I do not have any Dolby decoding device connected, will I getting 5.1 DD surround sound in my speaker? Or the program in my mac (i.e: VLC) already done the decoding and output as 5.1 multichannel analog so I don't need a extra decoding device?
3. As I am not sure about those method on the above will get 5.1 DD surround sound in my speaker, I keep digging and find out there is actually one more option.
Since the iMac supports s/pdif output, what I need is to buy a Digital to Analog converter(DAC) and use the mini Toslink to connect my mac with the DAC. Then connect my speaker to the DAC. Some DAC I found:
http://www.amazon.com/Digital-Analog-Audio-Decoder-Converter/dp/B0057UNPVO/
http://www.amazon.com/Digital-Analog-Audio-Decoder-Converter/dp/B007UQE5LW/
http://www.amazon.com/gp/product/B005D8YTKQ?tag=at055-20
and most of DAC support DD/DTS decoding, I should be able to get 5.1 DD surround sound at the end. Is it correct?
My question is, is this the right solution to get 5.1 Dolby?
If Griffin Firewave is available, will the result of method 1 same as the result of method 3?
Or is it better to use a receiver instead of DAC?
I know I have so many questions, I hope I did not make it too troublesome. But I really want to know the answer from you guys. I really appreciate for those who read through this. I know my english sucks and cannot express myself very well. I do apologize for that. Anyway, please leave any thought on this, even a sentence or yes/no XD
Thank you sooooooo much
Frank
hochun0809 is offline
post #2 of 4 Old 08-13-2012, 09:40 AM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
Your iMac has built-in optical audio out, which means the only way you're going to "hear" the real DD 5.1 or DTS out of it is to connect to something that supports it, i.e. something that has optical in. That something has to be able to decode the digital information, convert it to analog, route it to your speakers and drive those speakers.
If it doesn't support DD and DTS 5.1 inherently, then you're not going to hear it. At best you'll hear "pretend" surround, i.e. the Inspire will make sure "sound" is coming from all your speakers but it won't be correct or nuanced.
1. Buy a Griffin Firewave...
Piece of junk, don't bother. It didn't actually support true DD 5.1, it merely simulated surround sound and did that badly. Way back when, circa the G4 mac mini era, the only way to get true DD 5.1 passed to a device over firewire was with an M-Audio interface, and then only if you managed to get their drivers successfully installed on your Mac. (Which was no guarantee since M-Audio was very, very slow in adapting to new OS updates from Apple.) The Firewire Solo is what I used with my G4 Mini and a PowerMac, but I was so glad when Apple started shipping Macs with optical digital audio out. M-Audio was the only company that tried to enable this in OS X, since Apple didn't include this functionality inherently in its native firewire protocols.
Your goal in all of this should be "passthrough," to get the Mac to send the DD 5.1/DTS untouched to a device (like a real AVR) that's capable of decoding that digital audio information, processing it and then routing it to your speakers. The problem you have is that no matter what you do, the "processor" inside the Creative Inspire system, inside the sub which routes the signal to and drives the speakers, doesn't know what to do with digital audio streams...so whatever intermediate device you try to stick in between your Mac and the Creative Inpire sub input I fear will still only be able to send audio to the Inspire over a crappy 2 channel analog connection because that's the only kind of input it understands.
Don't bother, Apple doesn't support passing encoded digital audio output like DD 5.1 or DTS over USB anyway, so external USB DACs and devices like this Diamond Xtreme are a waste of time for movie audio. Your Mac will only send stereo PCM over USB, which means it doesn't matter what you have connected to the other end, that's all it will receive (true surround sound cannot magically be recreated out of a 2 channel stereo input, at best you'd get a low quality guess. Here again, there were M-Audio USB devices that did correctly pass DD 5.1 through, but they won't help you either.)
Well, for that to be true, you'd have to find a way to connect each of your Creative speakers to one of these decoders/converters, and bypass the built-in processor of the Creative Inspire, which probably isn't possible, but let's say it is...then, you'd have to trust these manufacturers that they have a real DAC chip inside their device that's capable of receiving and properly decoding DD 5.1 and DTS, the same kind of a DAC that's inside your typical AVR. Then what you hear might actually be the digital audio mix that was included on the original movie. Now, this last bit, that a device like this may have a perfectly adequate DAC chip inside it that's capable of decoding DD 5.1 and DTS just like a real AVR is possible--DAC chips were commoditized a very long time ago and are very, very inexpensive. And the inexpensive ones do such a good job that they are usually indistinguishable from extremely expensive gear! So it is possible converter/decoders like the ones you linked to could work, i.e. could pass the center-channel audio to the center front speaker as the director and sound engineer for the discs and movies intended. The problem I suspect you'll run into is your Inspire speakers don't exist on their own, they are not separate active or passive speakers, they can only work when all hooked up together as a unit through the sub, fed by the sub. If that's the case, then you're back to where you started, the Inspire will only see 2 channel PCM coming in because that's all it knows how to receive...and then it will create some sort of pretend surround sound on its own, again, because that's all it is capable of doing. Real AVRs are much, much better at this sort of thing, decoding digital audio directly from your Mac and managing different surround audio profiles.
What you want to do, is sell (or donate) your current speaker system and upgrade to a similar powered system that has an optical input, or much, much better, step up to big boy audio: do not spend any money on the Logitechs or any of these linked devices, instead buy your first real AVR and real speakers. Buy someone else's used equipment if you are on a tight budget, just make sure the AVR has optical inputs, something from 2004 or so should suit you just perfectly. Plenty of very good, very inexpensive equipment can be had via Craigslist as audiophiles and audiophools upgrade to the latest and greatest with HDMI inputs. Why not benefit from that? Once you have an AVR with an optical input then you can start gradually adding speakers as your budget allows.
chefklc is offline
post #3 of 4 Old 08-13-2012, 09:50 PM - Thread Starter
hochun0809's Avatar
First of all, I really want to thank you for such a patient to response with this detailed answer.
So what are you saying is the Griffin Firewave wont work for true 5.1 surround sound and it just upmix the sound from stereo to 5.1?
But it use ieee 1394 firewire, so even in that case, I wont actually getting true 5.1 sound?
So what I am getting is, the best solution is to get an real receiver to decode the signal and connect to those speaker, right?
Do you have any suggestion on receiver that is inexpensive but still able to decode DD/DTS?
I use VLC player in mac, If i using normal setting in VLC, is it decode DD/DTS to crappy stereo no matter what?
Or I need to tell VLC to pass untouched 5.1 signal via S/PDIF?
So whats the point of all those external 7.1 USB sound card on the market?
Do they just split the stereo to 8 channel or they actually do sth else?
This is the part I dun quite understand, why do I need to bypass the built-in processor of the creative inspire?
Let take this as an example.
Lets say I bought this,
Sewell Direct SW-29767 Digital to Analog Audio Converter
Then I set up like this,
iMac -> optical digital output using mini Toslink -> Sewell DAC -> connect the coaxial output to the back of the subwoofer of the speaker -> connect the other 6 satellite speakers from Subwoofer.
(so that i can control the volume of the whole set speaker via control on the subwoofer)
Will this setup make real 5.1 surround sound finally?
One last question, Is this the same as other DAC I found on amazon or it can act as receiver that decode DD/DTS?
DTS AC3 Digital Audio Decoder 6x RCA for Microsoft XBOX360 PS2 PS3
post #4 of 4 Old 08-13-2012, 09:52 PM - Thread Starter
hochun0809's Avatar
http://www.amazon.com/Digital-Audio-Decoder-Microsoft-XBOX360-X360/dp/B007S73DGQ/
Reply HTPC - Mac Chat
