The Travel Channel - AVS Forum | Home Theater Discussions And Reviews
Old 09-27-2012, 07:43 AM - Thread Starter
labmn2's Avatar
I am not able to get The Tavel Channel on my TitanTV EyeTV. Is there any way I can have this channel? confused.gif
labmn2 is offline
Old 09-27-2012, 08:12 AM
lovekeiiy's Avatar
Liked: 30
do you normally get the channel on your other TVs? If so, you'll just need to find the digital equivalent. This is assuming either your TV provider has it ClearQAM or you have the CableCard TV tuner for your HTPC.
lovekeiiy is offline
Old 09-27-2012, 09:18 AM - Thread Starter
labmn2's Avatar
Thank you, I have The Travel Channel on my TV cable provider.
labmn2 is offline
Old 09-28-2012, 08:45 AM
lovekeiiy's Avatar
Liked: 30
Maybe the your TV Tuner card manufacture provides the digital channel. I know Silicondust does for the ClearQAM channels. They may have expanded for the QAM channels since they have a cablecard boxes now.
