New Apple TV, I'm ready to return it - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-10-2013, 10:20 PM - Thread Starter
jamhdit's Avatar
Ok got a new Apple TV last week. Only because the salesman at best buy talked me into it. Got home and hooked it up to my Westinghouse flat screen TV, sorry don't know the model # at the moment. But it has two hdmi outlets so everything plugged in no problem.
Turned it on got a picture of the menu and went thru the set up including the updates software or firmware. All stemmed to be going well till I actually tried to use this thing.
Turned on Netflix and was able to toggle to the movie I wanted.
When I tried to play it it booted up then gave me a HDCP device error.
This is a older flat screen TV so is it possible it's not HDCP compliant.
So I can't even use this thing for the reason I bought it.
My question is will a HD FURY3 ADAPTER FIX MY PROBLEM.
I tried a older hd fury 1 adapter and it still didn't work.
Now here is the real kicker can watch Netflix on the Apple TV if I mirror thru my I pad. Not sure if I get the best resolution that way and also the IPad battery goes dead by the end of the movie.
I really don't want to use the mirror feature, mostly because I usually play with my iPad while I'm watching movies.
Any ideas how to fix this . Or should I just return it and get a much cheaper HMDI cord to plug into my iPad.
I'm sure the answer best buy will be to just get a newer TV.
John
jamhdit is offline
post #2 of 8 Old 01-11-2013, 12:21 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Me too! Would any one like it? Lol
zoro is offline
post #3 of 8 Old 01-11-2013, 08:14 PM
gring40's Avatar
How about a firmware update for the TV? The HDMI 'standard' is not as standard as one would think, and I had to update mine. In fact, I was a Beta tester for the update, after which they (Hitachi) released it online.
gring40 is offline
post #4 of 8 Old 01-13-2013, 09:45 PM - Thread Starter
jamhdit's Avatar
That was my original idea. Firmware update. Till I went to wresting houses worthless website and got no response from multiple emails
jamhdit is offline
post #5 of 8 Old 01-18-2013, 06:29 PM
Brian Hampton's Avatar
Quoted: 584 Post(s)
Liked: 312
I would like it.
Brian Hampton is offline
post #6 of 8 Old 01-21-2013, 08:03 PM
ultimate's Avatar
This i probably not the best solution, but I watch Netflix and Hulu Plus on an old Dell computer monitor that I'm fairly sure doesn't support HDCP. I use an adapter to convert the HDMI signal to VGA (unfortunately 1024x768) and stereo out via RCA plugs. It works well for my needs, but then it's my kitchen TV so it's not that big a deal. I think I paid about $35 or $40 for it through Monoprice. I have also used a similar converter for component video out and got a better resolution, but the picture wasn't centered. I still use that in another venue, but I preferred the VGA one for my kitchen TV.
Dennis Whiteman
Check out HDTVOK.COM
ultimate is offline
post #7 of 8 Old 01-24-2013, 11:12 AM - Thread Starter
jamhdit's Avatar
Thinking of using an older HD fury 1
And the audio outs on the Apple TV
jamhdit is offline
post #8 of 8 Old 01-24-2013, 03:47 PM
lovekeiiy's Avatar
Liked: 30
..My question is will a HD FURY3 ADAPTER FIX MY PROBLEM.
I tried a older hd fury 1 adapter and it still didn't work. ...
Wait, you stated you already tired the HDFury1 and didn't work. So why would it still be a choice?
In theory, any of the HDFury should work to handle the HDCP issue. I used to use a HDFury2 with an old RPTV to connect an HTPC. I had used it, while testing, to a PS3, and it worked. But I was never under the impression the HDFury did HDMI out. I didn't keep up on the HDFury newer products, so it's possible they now do it. According to HDfury.com for HDMI, you need to get the HDFury4., which sells for $400 to $500. The HDFury3 sells for $250 to $300. All prices are from the HDFury store.
I know those prices are cheaper cheaper than a new TV. But looking at you're trying to hook up an AppleTV, I question the economics. I don't know the size of your TV and what you're trying to accomplish with the AppleTV. If it's just access to Netflix and similar applications, not iTunes access or Airplay, I would try a Roku. They're the same price or cheaper, depending on model, to the AppleTV. This still may run into the issue, but I haven't using two original Rokus and Roku XD (2nd generation Roku).
On a similar note, you may be able to get a newer HDTV such as a Westinghouse, LG, or Vizio that does have the smart apps for maybe a few hundred more dollars than the cost of what you're proposing and the AppleTV. I'm not exactly enamored with the idea of a new TV if the one you have fits your needs.
If you have component inputs, you could try getting old Roku or AppleTV.
lovekeiiy is offline
Reply HTPC - Mac Chat
