Pioneer 8G and Mac mini screen res ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-28-2013, 10:36 AM - Thread Starter
Dickeymint's Avatar
Hi have recently had my pioneer 428xd THX calibrated for use with my oppo 103 and Mac mini. The problem I have is that if I calibrate the mac don't use 1080p I can't select the calibrated settings on the tv if I select 1080p it does not fit the screen
If I use overscan it pushes the icons of the screen .....
How can I setup the mac to fit the screen so I can select the THX calibrated settings
Dickeymint is offline
post #2 of 3 Old 04-29-2013, 08:06 AM
g4s
g4s's Avatar
Not sure I understand the question but if you have a recent Mac Mini with HDMI out, there is an Underscan slider in the display settings. When you slide it to the right it will shrink the video output down to fit your display.
g4s is offline
post #3 of 3 Old 05-16-2013, 02:58 PM - Thread Starter
Dickeymint's Avatar
Thanks for the reply unfortunately its a 2010 Mac mini therefore it's DVI to HDMI.... No slider 😞
Reply HTPC - Mac Chat
