EYETV EXPORTING ISSUES PLEASE HELP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-22-2013, 11:12 AM - Thread Starter
fernandor987's Avatar
Hello,
I am trying to export files from eyetv to my desktop but I can't change the exporting options. The bubble that says "options" when I choose to export a file is shaded grey and I can't click on it. Please help, I need to be able to change the exporting options in order to export my clips in to Final Cut Pro X
fernandor987 is offline
post #2 of 2 Old 08-23-2013, 03:46 PM
rreini's Avatar
Some of the exporting formats give you options to adjust the output; some don't. I don't believe that the H.264 format that you're showing on your screen gives you any options. It behaves for me just as it's behaving for you. You'll have noticed that it's in the category of "Native Format (no re-encoding)", which makes sense. Try selecting a different format for export.
Roger in DTW
rreini is offline
Reply HTPC - Mac Chat
