Has anyone used MacGo's Mac Bluray Player software? What do you think? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 09-29-2013, 06:22 PM - Thread Starter
bommai's Avatar
Quoted: 192 Post(s)
Liked: 48
Here is MacGo's website.
I recently bought an external USB2.0 bluray drive from amazon and have been pleasantly surprised. It works very well. It cost only $35.
I would like to backup some of my Bluray movies into my external hard drive. MacGo claims they can play the lossless audio through the Mac's HDMI port or thunderbolt. Is this really true? I thought Macs were not able to do that. Anyone with a newer mac want to try this software out. My iMac is from 2007 and cannot do this. But I am able to play blurays through my USB bluray drive and this software with lossy audio.
bommai is offline
post #2 of 16 Old 09-29-2013, 10:31 PM
Ted Todorov's Avatar
I'd love to know how well MacGo works. I have an internal BD drive on my MacPro and have been using the MakeMKV + VLC method of playback. Lossless audio is not a concern, just digital DTS/DD out via optical-- my receiver does not support HDMI -- I have optical going to the receiver; HDMI to the TV, and in this respect no different from my Oppo BD player. The Oppo has trouble opening its tray, and I have sworn I am not getting another set top player ever again, thus my interest.
Also I'd love to know if MacGo ignores region coding, which MakeMKV/VLC does.
Ted Todorov is offline
post #3 of 16 Old 09-30-2013, 04:34 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
DVDFab Media Player plays back BD's with menu support.
It apparently uses XBMC under the skin, with BD menu support likely proprietary code.
I use it all the time (un-encrypted discs). Supposedly a version 2 is right aroud the corner.
qz3fwd is offline
post #4 of 16 Old 10-07-2013, 09:43 PM
Sommer3's Avatar
Yes, I've tried it with my Mac Mini and an OWC BluRay Player (~$60) and prior to that an internal Computer BluRay that I jury rigged to work through a USB (via converter/power system).
If I recall, you can download a trial copy, the only caveat was some of the BluRays had to be loaded on the computer after the trial ran out, otherwise it worked as well or better than DVD Fab.
I will state that trying to back-up a BluRay even to hard disk was not an easy process and may be limited in the Trial Version.
Dave
Archivist
Sommer3 is offline
post #5 of 16 Old 10-07-2013, 11:15 PM - Thread Starter
bommai's Avatar
Quoted: 192 Post(s)
Liked: 48
I used the trial version also. But I don't have the mac to test lossless audio. Do you have a hdmi receiver with audio capability that you can test you Mac mini with?
bommai is offline
post #6 of 16 Old 10-11-2013, 12:18 AM
geeji's Avatar
Macgo Blu-ray Player works fine on most Blu-ray disks of multiple regions with some caveats :
1) It does NOT support Blu-ray menus (contrary to what they say on their web site).
Macgo announced this support for a version 3.0 initially due in July, then missed the deadline twice, and since then all mentions of that update have disappeared
2) It needs an active Internet connection for decoding Blu-ray disks
3) Player will sometimes crash on some disks, including DVD ones
Basically, the trial version works exactly as the paid one, so try it before buying it.
geeji is offline
post #7 of 16 Old 12-01-2013, 02:30 AM
geeji's Avatar
The latest Macgo Blu-ray Player v2.9.x supports Blu-ray menus... kind of : there is a Preferences option where you can switch Menus support ON (default is OFF).
But it is labeled as "beta" and rightly so : I tried 2 Blu-rays, none worked, the Player hanged.
May be in 6-12 months ?...
geeji is offline
post #8 of 16 Old 12-27-2013, 04:46 AM
moorecoty's Avatar
The Mac Blu-ray software can finally access the Blu-ray disc menus. Not "beta" any more.
moorecoty is offline
post #9 of 16 Old 12-27-2013, 06:16 AM
geeji's Avatar
How many Blu-rays did you try and how many menus worked flawlessly ?
geeji is offline
post #10 of 16 Old 12-29-2013, 03:51 PM
pab1219's Avatar
How do you know that you have completely open the File? When the Blue play button appears? As you can see I'm not Savvy with this . I bought a Pioneer Blu-ray Burner BDR-XD05W have it plug into a usb port. Bought the MacGo Player registered it click Open File,not sure it is Opened. Please HELP. THANK YOU.
pab1219 is offline
post #11 of 16 Old 12-29-2013, 04:11 PM
bitonio's Avatar
Hi bommai,
I purchased the software few weeks ago.
My mini is hooked with a Yamaha AV receiver with an HDMI cable.
Mini is unable carry HD audio under OS X (Mavericks but I own it since Lion - same result).
Best you can do is DTS and Dolby Digital whatever is the software. The limitation doesn't come from MacGo but from Mac (OS or Hw, I am not sure at this point).
I opened a support ticket because my Blu-Ray discs with Dolby True HD didn't output any sound (total channel mix mess in fact) in 5.1 while DTS Master Audio was correctly downgraded to DTS. MacGo claims they can get HD audio through HDMI. My 4 years-old Mini can't with OS X.
I've read some Mini users that succeed to get HD audio using PowerDVD on Windows.
bitonio is offline
post #12 of 16 Old 12-29-2013, 11:07 PM
geeji's Avatar
It is unfortunately a well known limitation of the early implementations of HDMI on the Mini : you could not get digital sound out of it.
It has been corrected on the latest Mac Minis (starting 2011 if I remember correctly).
AFAIK, since it is a hardware limitation, booting under Windows would not change it.
geeji is offline
post #13 of 16 Old 11-11-2014, 01:28 AM
Liked: 0
I updated Macgo Blu-ray player to the latest version with which I watched two Blu-ray movie under "Blu-ray menu mode". Yes, it worked.
DevinMariah is offline
post #14 of 16 Old 07-13-2015, 08:42 PM
januza's Avatar
Quoted: 179 Post(s)
Liked: 107
I have a late 2012 Mini and have bought a USB bluray player... The mini is connected to my ONKYO AVR with HDMI... If I use PLEX I get DTS etc as I believe PLEX is handling all the audio.
However using my bluray and any bluray software I can cannot get any other sound than stereo.
What am I doing wrong here? Using the Macgo and changing sound setting i can see on the BD that the only formet it finds it TrueHD which would be perfect but my AVR only plays stereo
If I use ROKU, PLEX from MAC MINI, AC Ryan, PS3 my AVR picks up the correct sound stream but not using my USB Bluray...
any suggestions on what I do wrong?
januza is online now
post #15 of 16 Old 07-14-2015, 08:21 PM
januza's Avatar
Quoted: 179 Post(s)
Liked: 107
MACGO is crap!
Was playing around with it yesterday.. DVDFAB is not impressive either.
I tried
http://www.leawo.com/blu-ray-player-mac/
and bingo. Now it plays with DTS and all... Works well.. Has BD menu and all.. Only thing is that the virtual remote is kinda weird.. but for a free program it beats all the paid ones that I have tried so far!!
post #16 of 16 Old 07-18-2015, 01:26 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Originally Posted by januza View Post
MACGO is crap!
I tried
I agree completely. Leawo BD player is my goto video player on OSX Snow Leopard. DVDFab was pretty good but I am stuck on an earlier release as the developers started using function calls not avaliable on SL and I dont want to upgrade my operating system just for a couple programs......
qz3fwd is offline
Reply HTPC - Mac Chat
