Mac Mini 5.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-13-2013, 07:36 AM - Thread Starter
macman13's Avatar
Hi, right now I have been using my Mini with 2.1 audio through a 3.5mm to red and white, and I want a way to hook up my mini to my receiver and get 5.1. I have tons of BluRays and TV shows with 5.1, but I am only getting 2.1 right now. Here is my Mini: http://www.everymac.com/systems/appl...009-specs.html
Here is my receiver: https://www.google.com/url?sa=t&rct=...53899372,d.aWc
2x HDHomeRun Prime - 3CC
Sharp 65" TV; Sharp 46" TV; Panasonic 42" TV; Sony 40" TV; Sony 32" TV
WMC HTPC Server: Intel Celeron G1840, 4GB RAM, MSI H81M-P33, 1TB
Main HTPC: Mac Mini 2.3Ghz i5, 8GB RAM, 500GB, 1TB, 2TB, 3TB
XB360 WMC Extender, Ceton Echo, Roku 3, Apple TV 3
macman13 is offline
post #2 of 5 Old 10-13-2013, 12:47 PM
chefklc's Avatar
Quoted: 25 Post(s)
Liked: 24
chefklc is offline
post #3 of 5 Old 10-13-2013, 08:20 PM
lovekeiiy's Avatar
Liked: 30
it's hard to say what options you have. At a minimum, what was said above. Just make sure to change your sound drivers in the settings to digital if it's not autodetected. I have done this with my last 2009 Mac Mini in both OSX and Windows 7 and Windows 8
If you have newer mac mini, and a appropriate AVR, you may be able to use HDMI. Maybe even get 7.1.
lovekeiiy is offline
post #4 of 5 Old 10-17-2013, 07:43 AM
807recordings's Avatar
Quoted: 29 Post(s)
Liked: 69
I have had the VLC player lock my connection, even after killing the connection to 2.1 before on the optical output. Not once either, nor am I totally sure why. Either way just required a reboot of the mac mini and everything worked again.
So far VLC was the only app I found that sent the 5.1 information, and output in midi/hardware control goes to digital.
807recordings is offline
post #5 of 5 Old 10-21-2013, 09:03 PM
jdanforth's Avatar
Liked: 25
Have you tried XBMC?
jdanforth is offline
Reply HTPC - Mac Chat
