Mac Mini and Color adjustment. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-03-2013, 12:20 AM - Thread Starter
Evildude's Avatar
Quoted: 31 Post(s)
Do any of you know how to manually adjust the Gamma, Brightness and Contrast in the Mac Mini's ColorSync Utility? I have a 2011 Mac Mini i5, 2.3 GHz and 8GB of Ram. The blacks are just way too dark, no matter how much I mess with my TV's controls.
I would also like to know if there are any HD patterns I can use to correctly calibrate it.
Evildude is offline
post #2 of 3 Old 11-03-2013, 09:40 AM
Immaculate Grand Phoobah
grubavs's Avatar
Location: on the noisy end of the Half Moon Bay, CA Airport
Quoted: 40 Post(s)
Liked: 32
Not sure if this is what you want to do... Apple doesn't give numbers, just sliders... but:
- Open Display Preferences in System Preferences
- Select "Color" button
- Select "calibrate" button (and you may want to deselect "Show profiles for this display only")
- Check "Expert Mode - This turns on extra options."
- Select the Continue" button, and off you go.
You can make several different display profiles and choose between them. They'll be stored in the original "Color" window.
Not my president!
grubavs is online now
post #3 of 3 Old 11-03-2013, 09:49 AM
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Originally Posted by Evildude View Post
...I would also like to know if there are any HD patterns I can use to correctly calibrate it.
Certain DVD's include a calibration routine. If you have a DVD drive in your Mac, perhaps one of these will help. I can't remember which of my DVD's has this and I'm not motivated enough to go search, however.
Craig
Pvr4Craig is offline
Reply HTPC - Mac Chat
