MythTV for Mac OS X - AVS Forum | Home Theater Discussions And Reviews
post #1 of 51 Old 11-10-2013, 05:58 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
I am pleased to announce that MythTV 0.27 is now available for Mac OS X via MacPorts*.
MythTV is an open source software system that enables your Mac (OS X 10.5 or later) to be a digital video recorder and media centre. Key features:
  • Watch and record digital TV, including HDTV.
  • Pause, skip, and rewind live TV shows.
  • Completely automatic commercial detection/skipping, with manual correction via an intuitive cutlist editor.
  • Intelligently schedules recordings to avoid conflicts.
  • Schedule and administer many functions remotely via a web browser.
  • Multiple user interface themes to choose from plus artwork and metadata downloaded from web sources.
  • Flexible client/server architecture allows multiple frontend client machines to access content served by one or more backend servers (although the most common installation consists of a single computer running both the client and server together).
On OS X, however, the choice of tuner hardware is limited but does include SiliconDust's popular HDHomerun series. Also, Myth cannot support digital rights management and therefore certain channels may not be available. Typically these are premium cable company channels such as HBO, etc. Note, too, that PPC machines are not supported nor are older Core Solo Macs (pre 2007).
Myth has been available on OS X for over 7 years but primarily as a frontend connecting to a backend running on Linux. With MacPorts, the goal is to make it as easy as possible to run the complete Myth system (frontend and backend) on Macintosh. Presently, you still have to enter a few commands via the Terminal but cookbook-style instructions are provided. The following wiki pages provide more details:
http://www.mythtv.org/wiki/MacPorts
http://www.mythtv.org/wiki/Building_Myth_for_Mac_with_MacPorts
MythWeb.27 should be updated on MacPorts very soon.
Craig
*MacPorts is a package manager application that brings thousands of opensource software packages, including MythTV, to Mac OS X. Pre-compiled binaries are available for current OS X versions where permissible.
Pvr4Craig is offline
post #2 of 51 Old 11-10-2013, 06:29 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Stuck Here on Install:
Verifying checksums for faac
Error: org.macports.checksum for port faac returned: faac-1.28.tar.gz does not exist in /opt/local/var/macports/distfiles/faac
Error: Failed to install faac
Please see the log file for port faac for details:
/opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_audio_faac/faac/main.log
Error: The following dependencies were not installed: faac freetype libpng zlib lame libass enca fontconfig pkgconfig fribidi libcdio libcddb popt libdvdcss libxml2 logrotate gzip texinfo p5.12-datemanip p5.12-yaml-syck p5.12-dbd-mysql mysql5 llvm-gcc42 cctools cctools-headers ld64 dyld-headers libunwind-headers llvm-3.3 libffi llvm_select gcc_select openssl readline tcp_wrappers p5.12-dbi p5.12-clone p5.12-sql-statement p5.12-params-util p5.12-test-simple p5.12-http-request-ascgi p5.12-class-accessor p5.12-libwww-perl p5.12-encode-locale p5.12-file-listing p5.12-http-date p5.12-html-form p5.12-html-parser p5.12-html-tagset p5.12-http-message p5.12-lwp-mediatypes p5.12-uri p5.12-mime-base64 p5.12-http-cookies p5.12-http-daemon p5.12-http-negotiate p5.12-lwp-protocol-https p5.12-io-socket-ssl p5.12-net-libidn libidn p5.12-net-ssleay p5.12-mozilla-ca p5.12-net-http p5.12-www-robotrules p5.12-io-socket-inet6 p5.12-io p5.12-socket6 p5.12-lwp-useragent-determined p5.12-net-upnp py26-lxml libxslt py26-setuptools python26 db46 db_select libedit python_select sqlite3 py26-mysql py26-urlgrabber py26-curl curl curl-ca-bundle qt4-mac-mysql5-plugin qt4-mac dbus jpeg libmng lcms tiff taglib cmake x264 yasm
Joseph S is offline
post #3 of 51 Old 11-10-2013, 07:51 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Sorry about that! It appears the faac port was modified (along with a tonne of other ports) at just about the same time as you attempted the install. Try:
Code:
sudo port clean faac
followed by:
Code:
sudo port selfupdate
and then have another go at installing Myth. Worst case, wait an hour while the changes propagate through the MacPorts servers and try the above again.
Craig
post #4 of 51 Old 11-11-2013, 11:57 AM
Joseph S's Avatar
Quoted: 12 Post(s)
Thanks. Got a little further but still didn't install.
Building llvm-gcc42
Error: org.macports.build for port llvm-gcc42 returned: command execution failed
Error: Failed to install llvm-gcc42
Please see the log file for port llvm-gcc42 for details:
/opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_lang_llvm-gcc42/llvm-gcc42/main.log
Error: The following dependencies were not installed: p5.12-dbd-mysql mysql5 llvm-gcc42 openssl readline tcp_wrappers p5.12-dbi p5.12-clone p5.12-sql-statement p5.12-params-util p5.12-test-simple p5.12-http-request-ascgi p5.12-class-accessor p5.12-libwww-perl p5.12-encode-locale p5.12-file-listing p5.12-http-date p5.12-html-form p5.12-html-parser p5.12-html-tagset p5.12-http-message p5.12-lwp-mediatypes p5.12-uri p5.12-mime-base64 p5.12-http-cookies p5.12-http-daemon p5.12-http-negotiate p5.12-lwp-protocol-https p5.12-io-socket-ssl p5.12-net-libidn libidn p5.12-net-ssleay p5.12-mozilla-ca p5.12-net-http p5.12-www-robotrules p5.12-io-socket-inet6 p5.12-io p5.12-socket6 p5.12-lwp-useragent-determined p5.12-net-upnp py26-lxml libxslt py26-setuptools python26 db46 db_select libedit python_select sqlite3 py26-mysql py26-urlgrabber py26-curl curl curl-ca-bundle qt4-mac-mysql5-plugin qt4-mac dbus jpeg libmng lcms tiff taglib cmake x264 yasm
To report a bug, follow the instructions in the guide:
http://guide.macports.org/#project.tickets
Error: Processing of port mythtv-core.27 failed
Joseph S is offline
post #5 of 51 Old 11-11-2013, 12:52 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Building llvm-gcc42?
What version of OS X are you using and which version of XCode do you have installed? For good measure, which model Mac are you installing on? The llvm compiler suite should already be installed on any platform where it would be needed.
Could you please confirm that you did the following steps after installing XCode?
  • (from http://www.macports.org/install.php)
  • Apple's Command Line Developer Tools are found at the Apple Developer site, or they can be installed from within Xcode 4 and 5. Users of Xcode 3 or earlier can install this by ensuring that the appropriate option(s) are selected at the time of Xcode's install ("UNIX Development", "System Tools", "Command Line Tools", or "Command Line Support").
  • Xcode 4 and later users need to first accept the Xcode EULA by either launching Xcode or running:
  • xcodebuild -license
Craig
(Apple's changed the process of obtaining the Command Line Tools a couple of times; can be very confusing.)
post #6 of 51 Old 11-11-2013, 01:50 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Mac OS X 10.9 Mavericks (13A603)
Xcode 5.0.1 (55A2053)
Late 2012 Mac Mini 2.5 GHz Intel Core i5, 16GB RAM
I just installed the Command Line Tools after your latest post, might have been reinstallation. Not sure. Obtained through webpage link in Xcode menu.
Got further after that, then stuck here:
---> Computing dependencies for mythtv-core.27
---> Dependencies to be installed: p5.12-dbd-mysql mysql5 p5.12-dbi p5.12-clone p5.12-sql-statement p5.12-params-util p5.12-test-simple p5.12-http-request-ascgi p5.12-class-accessor p5.12-libwww-perl p5.12-encode-locale p5.12-file-listing p5.12-http-date p5.12-html-form p5.12-html-parser p5.12-html-tagset p5.12-http-message p5.12-lwp-mediatypes p5.12-uri p5.12-mime-base64 p5.12-http-cookies p5.12-http-daemon p5.12-http-negotiate p5.12-lwp-protocol-https p5.12-io-socket-ssl p5.12-net-libidn libidn p5.12-net-ssleay p5.12-mozilla-ca p5.12-net-http p5.12-www-robotrules p5.12-io-socket-inet6 p5.12-io p5.12-socket6 p5.12-lwp-useragent-determined p5.12-net-upnp py26-lxml libxslt py26-setuptools python26 db46 db_select libedit python_select sqlite3 py26-mysql py26-urlgrabber py26-curl curl curl-ca-bundle qt4-mac-mysql5-plugin qt4-mac dbus jpeg libmng lcms tiff taglib cmake x264 yasm
---> Verifying checksums for mysql5
Error: org.macports.checksum for port mysql5 returned: mysql-5.1.72.tar.gz does not exist in /opt/local/var/macports/distfiles/mysql51
Error: Failed to install mysql5
Please see the log file for port mysql5 for details:
/opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_databases_mysql5/mysql5/main.log
Error: The following dependencies were not installed: p5.12-dbd-mysql mysql5 p5.12-dbi p5.12-clone p5.12-sql-statement p5.12-params-util p5.12-test-simple p5.12-http-request-ascgi p5.12-class-accessor p5.12-libwww-perl p5.12-encode-locale p5.12-file-listing p5.12-http-date p5.12-html-form p5.12-html-parser p5.12-html-tagset p5.12-http-message p5.12-lwp-mediatypes p5.12-uri p5.12-mime-base64 p5.12-http-cookies p5.12-http-daemon p5.12-http-negotiate p5.12-lwp-protocol-https p5.12-io-socket-ssl p5.12-net-libidn libidn p5.12-net-ssleay p5.12-mozilla-ca p5.12-net-http p5.12-www-robotrules p5.12-io-socket-inet6 p5.12-io p5.12-socket6 p5.12-lwp-useragent-determined p5.12-net-upnp py26-lxml libxslt py26-setuptools python26 db46 db_select libedit python_select sqlite3 py26-mysql py26-urlgrabber py26-curl curl curl-ca-bundle qt4-mac-mysql5-plugin qt4-mac dbus jpeg libmng lcms tiff taglib cmake x264 yasm
Joseph S is offline
post #7 of 51 Old 11-11-2013, 02:28 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Wow, nothing is going right for you...even fetching/checking a source code zip! wink.gif Are you behind a restrictive firewall?
Possibly the file was temporarily unavailable? You might try:
Code:
sudo port clean mysql5
and then try to install myth again.
Could you please provide the following log file:
I think you should be able to attach the file here (paperclip icon). If not, please open a ticket on the MacPorts issue tracker and we'll deal with it there.
post #8 of 51 Old 11-11-2013, 02:42 PM
Joseph S's Avatar
Quoted: 12 Post(s)
That didn't work. Here's the file.
main.log.zip 2k .zip file
No.
Also just updated to Xcode 5.0.2 released today
Joseph S is offline
post #9 of 51 Old 11-11-2013, 03:20 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Great. One of the servers that mirrors files for MacPorts has gone away. I've posted to the macports-users mailing list to determine how to handle this. Hold tight.
BTW, MacPorts tries to pick the 'closest' mirror site and you were directed to easynet.be. Whereabouts are you located?
Craig
post #10 of 51 Old 11-11-2013, 03:22 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Las Vegas
Joseph S is offline
post #11 of 51 Old 11-11-2013, 06:10 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Looking a little more closely, this is a MySQL mirror, not MacPorts. It is still weird that it chose a mirror in Belgium, though. You can clean and try again--maybe MySQL will direct you to a closer mirror. Hopefully one that is actually working!
If you really want to proceed, you can download the required file manually, and put it where MacPorts expects it, by doing the following:
Go to
http://dev.mysql.com/downloads/mysql/5.1.html#downloads
Select
Version 5.1.72
Platform Source code **
Download
Generic Linux (Architecture independent), Compressed Tar Archive **
Click Download
then click "No thanks, just start my download"
Move the file to
Then proceed with installing Myth.
Craig
post #12 of 51 Old 11-11-2013, 07:19 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Can't find the architecture independent version. Placing the 64bit version yields checksum errors. Noted in error message that myth 27 installer is looking for this file "mysql5-5.1.72_0.darwin_13.x86_64.tbz2" which doesn't exist on the servers. They have darwin_12 but not darwin_13
Attempting to fetch mysql5-5.1.72_0.darwin_13.x86_64.tbz2 from http://packages.macports.org/mysql5
---> Attempting to fetch mysql5-5.1.72_0.darwin_13.x86_64.tbz2 from http://lil.fr.packages.macports.org/mysql5
---> Attempting to fetch mysql5-5.1.72_0.darwin_13.x86_64.tbz2 from http://mse.uk.packages.macports.org/sites/packages.macports.org/mysql5
You also can't just click on link, have to connect to the "http://packages.macports.org" then find the folder
Joseph S is offline
post #13 of 51 Old 11-11-2013, 08:04 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
You have to change the "Select Platform" pop-up menu to "Source Code" to show the appropriate download file (which will then be at the bottom of the list).
The "Attempting to fetch..." lines you've quoted are MacPorts checking to see if a pre-compiled binary (built by MacPorts) is available. The terms of the license for MySQL 5.1.72 are such that MacPorts has to build it from source; hence we need the source code tarball. We can't use the pre-compiled binaries from MySQL as they would install in the 'wrong' place and not be accessible by other MacPorts tools. Myth access the database via Qt's MySQL plugin and also allows access via Perl and Python scripts. MacPorts provides all these bits of software.
BTW, much of the software on MacPorts IS available as a pre-compiled binary for 10.6, 10.7 and 10.8 and therefore installs much more quickly than if everything has to be built from source. Unfortunately, that's not going to help you right now in installing on Mavericks. Apple supports the MacPorts project with hosting and other hardware but I don't know when they'll set up the Mavericks builder.
When you do get the build going, I'd be interested in how long it takes. I've never done a build from the ground up without some parts being delivered pre-compiled. At least you have a fairly healthy machine to do the work!
Craig
post #14 of 51 Old 11-11-2013, 08:34 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Almost completed and then hit another error... (mysql part took about 7-8 minutes)
---> Dependencies to be installed: qt4-mac-mysql5-plugin qt4-mac taglib cmake x264 yasm
---> Configuring qt4-mac
Error: org.macports.configure for port qt4-mac returned: incomplete operator "="
in expression "${MINOR} = "9""
Error: Failed to install qt4-mac
Please see the log file for port qt4-mac for details:
/opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_aqua_qt4-mac/qt4-mac/main.log
Error: The following dependencies were not installed: qt4-mac-mysql5-plugin qt4-mac taglib cmake x264 yasm
Joseph S is offline
post #15 of 51 Old 11-11-2013, 09:04 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Hmm, need the log again:
Craig
post #16 of 51 Old 11-12-2013, 01:06 AM
Joseph S's Avatar
Quoted: 12 Post(s)
main.log.zip 1k .zip file
File Type: zip main.log.zip (831 Bytes, 46 views)
Joseph S is offline
post #17 of 51 Old 11-12-2013, 07:28 AM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Well, you exposed a boo boo* in a change that was made to the Qt4-mac port yesterday. The maintainer has pushed a fix this morning and it takes around a half hour to propagate through the servers, so by 09:30 ET this morning, it should be available. To get it, run:
Code:
Then have another go at installing Myth. Note that Qt4-mac is HUGE and may take 1 hour+ to build.
Appreciate your patience in working through these glitches.
Craig
* The line
Code:
} elseif {${MINOR} = "9"} {
should have been:
Code:
} elseif {${MINOR} == "9"} {
post #18 of 51 Old 11-12-2013, 11:49 PM
Joseph S's Avatar
Quoted: 12 Post(s)
main.log.zip 8k .zip file It took about 50 minutes for qt4-mac... but hit one last error
Building mythtv-core.27
Error: org.macports.build for port mythtv-core.27 returned: command execution failed
Please see the log file for port mythtv-core.27 for details:
/opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_multimedia_mythtv-core.27/mythtv-core.27/main.log
Joseph S is offline
post #19 of 51 Old 11-13-2013, 05:46 AM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
One of the Myth devs tells me that he had a similar problem and solved it by downloading and installing the XCode Command Line Tools from Apple's Developer Connection website rather than having XCode do the install. You will have to register for a (free) ADC membership in order to get access to:
https://developer.apple.com/downloads/index.action
BTW, folks on the macports-dev list noted that there has always been a new release of the Command Line Tools for each new release of XCode but that the tools sometimes lag by a few days. You've got the brand new version of XCode but the Tools related to XCode 5.0.1. Conceivably, that is part of the issue.
Craig
post #20 of 51 Old 11-14-2013, 01:17 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Well, I did a fresh install of Mavericks, XCode and MacPorts...and the build failed in the exact same spot as you. From some googling, it appears that the underlying issue is related to the Command Line Tools version and affects several bits of software. It is _possible_ that people upgrading to Mavericks (rather than doing a clean install) _might_ not experience this problem. I don't have enough time to try that route.
I'm created a ticket in the MacPorts Tac system. I'm crossing my fingers that Apple will update the Command Line Tools and fix this...
http://trac.macports.org/ticket/41371
Craig
post #21 of 51 Old 11-21-2013, 09:42 PM
ckoepf's Avatar
I would like to comment on the errors that Joseph was having as I was having the exact same problems.  However, my situation is only a little different since the machine I installed MacPorts on to install MythTV is still Mountain Lion.  I was able to remove the most recent version of Xcode which was 5.0.2 which also removed the command line tools that I installed from the preferences window.  I then logged into my developer account (created a while back just to access certain things) and I download Xcode 4.6.2 from April 2013 along with the Command Line tools package from April.
I tried re-installing the mythtv package again and things are building and installing correctly.  Mysql was downloaded and built correct and it's now working on the rest of the dependencies.  I will report back if there are any additional errors or problems, but it's looking good now.
I don't think this is an option for Joseph though, since he said he was on Mavericks.  Xcode 4.6.2 probably won't install on Mavericks.  I suppose it's worth a shot if all other options are failing.
[Edit]Installation completed with no errors.  I won't be able to confirm that everything runs correctly tonight as it's been a LONG day and I'm headed off to be.  Looks like the Apple command line tools was the issue for sure.  I wish Joseph some luck with this install.[/Edit]
ckoepf is offline
post #22 of 51 Old 11-23-2013, 07:55 AM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Thanks for the report. Just yesterday, I was setting up a new 2012 Mini (Core i5) running 10.8.5 with XCode 5.0.2, freshly installed. Built and installed the MySQL database and Myth software from scratch without an error or hiccup.
Regarding Mavericks, it does appear that there is currently a mismatch or bug with the current XCode Command Line Tools. Several MacPorts packages are failing to build with much the same errors reported. I think this one is in Apple's hands to fix. Either that, or somebody much smarter than me!
Craig
post #23 of 51 Old 12-06-2013, 05:41 AM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Craig
Mavericks problems are now fixed. The main issue is too arcane to go into here but MythTV now builds successfully on OS X 10.9.
Craig
post #24 of 51 Old 12-07-2013, 12:19 AM
Joseph S's Avatar
Quoted: 12 Post(s)
Thanks. It is now built. Getting stuck working on the starting backend
mysql5 -u root -p < /opt/local/share/mythtv/database/mc.sql
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
I've tried the user password, machine root password, and "myth" all with same error
Based on step through guide from here:
Joseph S is offline
post #25 of 51 Old 12-07-2013, 07:00 AM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Try
Code:
mysql5 -u root < /opt/local/share/mythtv/database/mc.sql
When set up from scratch, there is no password for the root user on the MySQL database.
Craig
post #26 of 51 Old 12-07-2013, 06:54 PM
Joseph S's Avatar
Quoted: 12 Post(s)
Still getting access denied with above
Joseph S is offline
post #27 of 51 Old 12-07-2013, 09:05 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
So, you must have set a password for root and forgotten it? You can try:
http://dev.mysql.com/doc/refman/5.1/en/resetting-permissions.html
However, if you don't have anything recorded in your database, another approach is to blow it away and start again. I *think* the following will work but I haven't tested it--I don't want to nuke my database!
Code:
sudo port deactivate mysql5-server mysql5
# removes the MacPorts MySQL software from /opt/local
ls -l /opt/local/var/db/mysql5
# check for remaining databases, should have directories for mysql and test; maybe mythconverg
echo DANGER WILL ROBINSON !
sudo rm -ri /opt/local/var/db/mysql5/*
# wipe out the remaining contents, NO UNDO, don't mess up the spelling.  USE AT YOUR OWN RISK
sudo port activate mysql5-server mysql5
# reinstall the software, should be very fast
Now start over with the install...
Craig
post #28 of 51 Old 01-08-2014, 10:26 AM
airdrummer's Avatar
i'm running the f/e on my mini core duo, but it cannot play smoothly unless nothing else is running:-\ yes, i know my h/w is woefully underpowered;-) but eyetv & vlc have no problem playing smoothly when for example i'm screensharing in from my laptop, playing mtv's recordings on an nfs mount/gig ethernet. right now i'm doing port upgrade outdated while watching live tv w/minor choppiness;-)
i'm not familiar w/how the f/e communicates w/ the b/e, but it seems it's much less efficient than eyetv/nfs...i can watch 2 live tv windows simultaneously & smoothly. and when there is minor choppiness, the sound is unbroken. myth f/e drops sound when it can't keep up w/video, making it unsat:-\
airdrummer is offline
post #29 of 51 Old 01-08-2014, 06:21 PM - Thread Starter
Pvr4Craig's Avatar
Quoted: 68 Post(s)
Are you using mythtv-core.25 from MacPorts or the .app bundle (which version)?
What is the source of the recordings that don't play smoothly? North American broadcast? 1080i or 720p? If 1080i, check which deinterlacer you're using; some add a lot of overhead.
I think it is more likely that EyeTV is better optimized for 32-bit Mac environments since that is what was current when it was being actively developed! Myth on OS X works quite well on Core2 Duo or later machines. The mythfrontend log may also give some clues as to why a particular recording does not play smoothly.
Craig
post #30 of 51 Old 01-08-2014, 08:30 PM
airdrummer's Avatar
the .app bundle: v0.27-1-g5b917e8, as i've already gone to 0.27 on the backend (which i built under linux) so it _can_build on i386;-)
the "port upgrade outdated" just finished (>6hrs;-) and the "port install mythtv-core.27" of course won't build:
Code:
Error: mythtv-core.27 cannot be installed for the configured build_arch 'i386' because it only supports the arch(s) 'x86_64'.
any chance i can get -arch i386 working?
any:-)
so where can i find the mythfrontend.app log? of course it wouldn't be in /var/log/mythtv;-}
Reply HTPC - Mac Chat
