EyeTV misbehaving after upgrade to Mavericks - AVS Forum | Home Theater Discussions And Reviews
Old 06-06-2014, 02:24 AM - Thread Starter
hotchoc's Avatar
Hi all,
I have a 2.3Ghz i5 Mac Mini with a finely tuned setup consisting of EyeTV (diversity tuner), Plex and Remote Buddy with a Harmony Remote.
It has been working perfectly for a long time now. I also have Plex and Eyetv set to use different Spaces in Mission Control.
I was on Mountain Lion until two days ago when I finally decided enough time had passed after the release of Mavericks for issues to be sorted out.
Checked a few places like this to see if there were any issues and it seemed safe to go ahead.
I upgraded to Mavericks and everything seemed to go smoothly, but now I'm getting a few issues with EyeTV -
Firstly when opening it or switching to it, sometimes I will just get a black or blue screen, sometimes I will get the TV image but the video is paused and the audio is continuing.
Switching tuners will sometimes fix it, but other times not.
In addition, sometimes the menus are only partially accessible by remote. They might appear, but I can't navigate them.
HAs anyone else experienced anything like this? All apps are up to date. I have turned App Nap off for all apps.
Cheers!!
hotchoc is offline
Old 06-06-2014, 08:32 PM - Thread Starter
hotchoc's Avatar
In addition it seems that plex is now having trouble - stuttering sometimes and not playing audio. I've checked that it's audio settings are correct. I
hotchoc is offline
Old 06-07-2014, 11:58 AM
Ted Todorov's Avatar
I didn't have any *new* problems with EyeTV in Mavericks: it was a bugfest in Mountain Lion and the exact same bugfest in Mavericks. Different tuners from you. The biggest bug for me was it constantly recording the wrong channel. Anyway, TWC killed clear QAM and I ended up moving from EyeTV to TiVo + cTivo
Ted Todorov is offline
Old 06-07-2014, 12:43 PM - Thread Starter
hotchoc's Avatar
Thanks Ted, I'm in Australia, so I'm using OTA, but I'm not sure that is relevant.
I'm noticing some beach balling and recurring errors in Console, so something isn't happy!
hotchoc is offline
