TV will see the mac, but the mac will not see the tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-29-2004, 03:52 AM - Thread Starter
daylight28's Avatar
toshiba 57h93 built in tuner
i have a 57h93 toshiba hdtv w/built it tuner. it will see the mac but i can't get the mac to see the tv.
under the play side it shows 1 connection but 0 on the record side.
is there a setting i'm missing?
thank you
daylight28 is offline
post #2 of 5 Old 09-29-2004, 04:37 AM
bfdtv's Avatar
daylight,
Do you have CableCard? There is a bug with CableCard on Scientific Atlanta systems that will prevent recording. Of course, you can't record DTV/HDTV cable channels with a PC or Mac anyway, because they don't support 5C encryption.
bfdtv is offline
post #3 of 5 Old 09-29-2004, 05:10 AM - Thread Starter
daylight28's Avatar
Not using cable for HD, taking ATSC off air with the built in tuner. the 57h93 does not have the cable card, the h94 does.
I have the h93.
post #4 of 5 Old 09-30-2004, 03:23 AM - Thread Starter
daylight28's Avatar
i can't get it to work! need to invest in a dvr.
post #5 of 5 Old 09-30-2004, 07:53 AM
bfdtv's Avatar
For people to help you, I think you need to supply a bit more information -- like the steps you used to setup recording on the Mac.
bfdtv is offline
Closed Thread HTPC - Mac Chat
