Mac Mini + DVI + Sony KV-34XBR910? - AVS Forum | Home Theater Discussions And Reviews
Old 01-14-2005, 03:39 PM - Thread Starter
jkb081759's Avatar
Hi,
Can anyone who knows Apples + DVI tell me what chance I have on getting an Apple Mac Mini connected to my Sony KV-34XBR910 via the DVI connector? Oh yeah, and get an acceptable high definition display (720p or 1080i)?
John
jkb081759 is offline
Old 01-20-2005, 11:33 PM
momocool's Avatar
I am also interested in a reply for this question.
I also have a Sony XBR910 and would like to use a mini Mac using it's DVI output with my TV, to browse the Internet Wirelessly.
momocool is offline
Old 01-21-2005, 11:35 PM
Ray Parkhurst's Avatar
I used a Samsung SIR-T165 with DVI out with XBR910 for 6 mos and found that the Sony was not really set up well for DVI. Component looked better on that set from the Samsung. Black levels were all wrong and I had no adjustability for gamma on the Samsung. I tried to set up HTPC on the Sony but it had >6% overscan and this cut off a significant part of the desktop (half the start menu, desktop icons, etc) and I could never find settings for PowerStrip that would let me see the whole desktop. The scan rates on the Sony are pretty picky so you don't have much flexibility in PowerStrip. I was never brave enough to go into the Sony service menu and adjust the overscan to solve the problem, but I think this might be the only way to make it work as HTPC monitor.
Ray Parkhurst is offline
Old 01-22-2005, 04:39 AM
jsb_hburg's Avatar
Hello,
You can use SwitchResX to create a custom resolutions on the Mac and see Carlos' post in this thread about overscan control using the latest ATI driver.
Joe
Going "over the top" with OTA, Netflix, Drobo FS and Apple TV!
jsb_hburg is offline
