USB Bluetooth - AVS Forum | Home Theater Discussions And Reviews
Old 01-25-2005, 05:24 PM - Thread Starter
absolutezerok's Avatar
Will a usb bluetooth adapter work on this machine? Like the linksys usbbt100?
http://www.linksys.com/products/prod...id=581&scid=36
It doesn't need to be this model I am just wondering if this ideal will work
absolutezerok is offline
Old 01-25-2005, 06:15 PM
Marshall F's Avatar
I think so. You can either have it pre installed internally or use this type in the USB port. I'd vote for the internal version, although I'd be curious to see the ranges on both.
"Time's up. Had your chance. Muffed it." ~Lord Scrumptious
Vintage Audio
What is bio-diesel?
VW TDI Forum
Ted's of Beverly Hills
Track Flights
Marshall F is offline
Old 01-25-2005, 06:32 PM
jsb_hburg's Avatar
I have the D-Link BT USB adapter that I bought for my old 17inch Widescreen iMac (Luxo-type). I am now using it on a 1.25 G4 eMac. Panther makes it easy to set up. If you haven't ordered yet, I'd vote for internal, too.
Joe
Going "over the top" with OTA, Netflix, Drobo FS and Apple TV!
jsb_hburg is offline
Old 01-25-2005, 08:18 PM - Thread Starter
Thanks, I noticed that they dropped the BTO price to 50$. I might get one of these from CompUsa though as a friend works there so I may not be able to get internal.
Old 01-26-2005, 09:57 AM
Compromise's Avatar
Yes, I purchsed two of these to extend the range of my Treo650 to control iTunes. Works great up to about 75 feet inside my house with the 650. Had to resync some devices.
And by the way, got them from Dell for $39 each.
Boat name: Summer Compromise; Power train: twin 490 HP (w ATI Prochargers); A/V: sufficient
Compromise is offline
Old 01-26-2005, 07:14 PM - Thread Starter
Yeah thats why I asked, I found them for $20 on ebay. Still cheaper than $50 from apple.
