S-Video signal quality - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2005, 01:39 PM - Thread Starter
ronnang's Avatar
Can anyone report on the signal quality on the S-video output? I need to connect it to my widescreen 854x480 resolution plasma (sorry - no available VGA/DVI input) - will the quality be good enough?
ronnang is offline
Old 01-27-2005, 07:23 PM
Marshall F's Avatar
would you list a model number for your plasma?
Just guessing that a 480i signal would not look very good.
Marshall
"Time's up. Had your chance. Muffed it." ~Lord Scrumptious
Vintage Audio
What is bio-diesel?
VW TDI Forum
Ted's of Beverly Hills
Track Flights
Marshall F is offline
Old 01-27-2005, 09:51 PM - Thread Starter
ronnang's Avatar
It's the panasonic TH-37PW5.
So maybe a DVI->Component showing 480p would be a better option (if possible). Anyone who knows if it is possible?
ronnang is offline
Old 01-28-2005, 07:41 PM
Marshall F's Avatar
The mac comes with a DVI-I - VGA adapter.
Your TV has RGB input.
Get a VGA to 3/4/5 bnc adapter.
VGA to component takes a bit more to convert. Don't be confused in that the component and BNC inputs look the same.
http://www.superfi.co.uk/index.cfm/p...roduct_ID/1411
Vintage Audio
What is bio-diesel?
VW TDI Forum
Track Flights
